Back to:
Tags:
Sony Handycam DCR-TRV350 Digital-8 Digital Camcorder
Camcorder malfunction (by 2 users)
posted by parling on Mar 27, 2008
My camcorder which is a DCR-TRV 145E digital will not function apart from the open/close mechanism. It has an arrow pointing up sign flashing fast with the code C31 23 in the viewfinder which from the book indicates moisture. The book suggests leaving open with tape out for a while, but after three weeks it is still the same. Suggestions please.
Parling
Comment by parling, posted on May 26, 2008
Thank you but unfortunately I click on your link www.wvstephensblogspot.com but it tells me ..server not found ...any suggestions.
I have taken the camcorder to a Sony agent who wants £248. to repair it stating that the problem is 1 A78926597 Mech. block assembly £115.65.
1 Flexy assembly £25
Plus labour £64.65
Plus £45 non refundable estimate charge.
I have decided it is not financially viable to get it repaired . So much for buying the so called best.
Parling
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by edmfamile, posted on May 07, 2008
I am having the same problem. an arrow with the code C:31:23. We have no clue what to do? Help!
Best Solution
posted on May 25, 2008
Thanks for Trying (70)
warhol
Rank:Apprentice Apprentice
Rating: 70%, 1 votes
go to www.wvstephensblogspot.com easy fix is suggested there i tried it and it works
Rating Locked! (?) parling has rated this solution as Thanks for Trying
Thank You!
Was the solution helpful?
Show your appreciation by commenting on camcorder malfunction:
I don't want to Accept this solution
Can you Help with these Camcorders problems?
Sony Handycam DCR-TRV350 Digital-8 Digital...
my camcorder playback(vcr) at double speed, runs as if on...
I am going away on holiday and wanted to take my camera...
When I import from my Sony DCR-TRV350 into Imovie '06 or...
I have a sony digital 8 camera and i want to put my home...
dvd burning, from tape to dvd
Loading problems.
Repair Service
Find Camcorder Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
