Question about Kenmore 15899 Built-in Dishwasher
How do you turn off lock on light.or unlock the dish washer.
  • 8,197 Answers
May I get the make and model # to help you more.
Posted on May 09, 2010
Electrolux dishwasher control panic locked - how do I unlock? Have tried pressing LOC button for 3-5 seconds and have turned circuit breaker on and off.
Pull out the dish washer and unplug the machine for about 30 minutes. Then replugin the machine and open door. This should reset the electronics on the washer
Oct 17, 2013 | Whirlpool 24 in. ADP5966 Free-standing...
My frigidaire fdb520rhb0 has the lock light on. How do you unlock it so the dish washer will run?
proceed with the test mode manual: see your instruction manual and do it. download the instr.manual free from www. fitness.manualsonline.com or www. retrevo.com
God bless you
Jun 29, 2012 | Washing Machines
Kenmore dish washer lock button blinks and doesn't run
Hi
Thanks for using FixYa. To unlock the controls Press and hold Air Dry/No Heat Dry for 5 seconds or until the light turns off. Please revert back for more help.
Rylee
Dec 23, 2011 | Dishwashers
The door wont open . I have tried to put it on for a cycle and you can here the the water for around 5 seconds then it stops and does nothing.
Check and make sure your pump or filter is not clogged, then next I would suspect you have a faulty door lock mechanism
More common issues with the door lock.
Is water hooked up to the washer?
The door will remained locked while draining water. If during installation the washer was plugged in and turned on without water hoses attached, the washer may attempt to drain for 8 minutes before the door unlocks. Let the washer run until the door unlocks. Do not turn off the washer or unplug the washer.
Does water remain in the washer after the final spin?
If water remains in the washer after the final spin, then the door will not unlock. Select Drain/Spin or Spin Only to remove any remaining water from the washer. The door should unlock at the end of the cycle. For models that have Rinse/Drain & Spin, push the Extra Rinse button to turn off the rinse to remove excess water.
Is the door locked and the Add A Garment light on?
If the Add A Garment light is on, then the washer door will unlock after the Pause/Cancel button is pressed once. Pressing the Start button will restart the washer at the same point where it left off in the cycle.
Is the door locked and the Add A Garment light off?
If the Add A Garment light is off, then the washer door will unlock after the Pause/Cancel button is pressed twice. The door will not immediately unlock while the cycle is running due to a possible high-water level in the washer, high-water temperature, tumbling or spinning. It may take up to five minutes for the washer to stop spinning and draining before the door will unlock. You will hear the door click when it unlocks.
Trying to gain access into a locked door can be a bit frustrating. Upon researching your question I found some links that may help you unlock your washer door. I attached all links below. I hope this helps!
http://www.managemylife.com/mmh/questions/204092-how-do-i-get-the-door-open-on-my-kenmore-washer
http://www.managemylife.com/mmh/questions/220303-does-front-loader-door-open http://www.managemylife.com/mmh/questions/134692-why-wont-the-door-open-on-my-kenmore-frontloading-washer
Jun 10, 2011 | Washing Machines
How can I get my lock on light off and turn my ultra dish washer on all buttons are disabled it is kenmore 665 15819
If the model number is correct, press and hold the "NO HEAT DRY" button for 4 seconds to lock or unlock the controls.
Aug 23, 2010 | Kenmore 15899 Built-in Dishwasher
My child safety lock is on my dish washer how do I get it off
For my old GE washer, there was a button with a lock icon. To lock/unlock it, you had to hold that button down for 10 seconds.
Hope this helps!
Aug 03, 2009 | KitchenAid KBLC36FKS Bottom Freezer...
I HAVE A FRIGIDAIRE DISH WASHER MODEL NUMBER FDB1500LFCO AND IT IS LOCKED HOW DO I GET IT UNLOCKED
You have to hold the button marked lock for 5 seconds I think it is the last one on the right. it has a little note just under the button.
Apr 29, 2009 | Frigidaire Dishwashers
The dish washer won't start
press the key with the lock button for 5 seconds. the lock indicator light should then disappear.
Jun 09, 2008 | Kenmore Dishwashers
GE Washer WSSH300GWW front loader washer CONTROL LOCK!!
Solution: Hold down the power and delay start button at the same time. In about 3-4 seconds a beep will occur and the red key lock will turn off. I think it is a problem in the machines firmware. I just guessed at what combination of buttons the engineers used to do a firmware reset. In any case it worked for me.
May 23, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore 15899 Built-in Dishwasher Logo
194 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
