Question about Culligan Under Sink Water Filter
How to change the water filter?
How do I change the water filter in my under-the-sink Culligan system? It's a D-40 replacement cartridge. I'm afraid to start, thinking I'll be unable to turn the water supply back on if I fail. Which way, for instance, does the existing cartridge case unscrew?. Since I'm unscrewing it the bottom from a stable top piece, is it clockwise? I think this is how I've messed up in the past.
Thanks guys, Meredith
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • Culligan Expert
  • 306 Answers
Meridith just remember this old adage whenever changing filters or unscrewing anything. It's always lefty loosey, righty tight.
RJ
Posted on May 23, 2011
I just changed my under sink culligan D30 water filter and there is a leak when I pressed the pressure button. What should I do to resolve this problem?
Well the simplest answer is the gasket isn't seated properly. The standard approach is to remove the cartridge, check for any foreign material (dirt, sand, grit, etc.), rinse with clean water if necessary and reassemble.
Sometimes these cartridge units can be fiddly to get the seals to 'seat' properly so once you're sure that the parts are together nicely then you can use a bit of pressure to tighten them up. They usually need to be fairly tight.
Mar 05, 2015 | Culligan Under Sink Water Filter
Change filters on culligan h-83
You can get replacement cartridges for all the H series through AC series RO systems on line from several suppliers. I use them and they work just fine.
RJH2O
Mar 20, 2013 | Culligan Under Sink Water Filter
For Culligan Aquacleer AC15, Carbon and RO filter oring to be mounted towards end of cartridge or manifold?
Here is a manual for a Culligan H-30. Basically the same unit. The diagram shows how to replace o-rings.
http://www.freshwatersystems.com/support/H-30.pdf
RJ
Oct 17, 2011 | Culligan Under Sink Water Filter
My culligan under sink RO walter system seems to have air in the fitlers when I changed the filters last time. When I turn on the filtered water it spits out for 5 seconds, with a little water a bunch of...
Run the tank empty of water at least 2x. This should take care of problem. You really should dump 2 tanks of water each time because carbon fines can get in the tank when changing new filters.
RJ
Jul 20, 2011 | Culligan Under Sink Water Filter
My system vibrates & resonates loudly when the ordinary tap is switched on. Also, water comes out of the filter tap when it isn't turned on, sometimes in a stream, other times constantly dripping. Have...
You are getting water feeding back to the kitchen faucet from the filter system. A check valve needs to be installed on the line feeding the drinking water system to prevent this. Excess pressure may also be causing these problems. An in-line flow restrictor may alleviate the dripping.
RJ
Oct 27, 2010 | Culligan Under Sink Water Filter
May need replacement of a filter or two of culligan under sink filtetrs. what is cost and can another co. do replacement?
I would not suggest having another company replace the filters. Here is a supplier that has Culligan filters I have used. http://www.uswatersystems.com
The pre and post filters should be replaced every 6 months and the membrane needs to be replaced when the product water drops to 80% TDS reduction (3-7 years). A sediment, carbon block and post carbon will typically be about $40-$50 for all three. A membrane will be $50-$100. I know Culligan is expensive but if you can not do this yourself it is best left to the company that knows the equipment.
RJ
Sep 21, 2010 | Culligan Under Sink Water Filter
I need to replace the filters on my culligan reverse osmosis ac30 and i got them mixed up...which one goes where
The Sediment filter goes in LEFT cartridge
The Block Carbon filter goes in the RIGHT cartridge
The Membrane goes in the CENTER cartridge
RJ
Sep 17, 2010 | Culligan Under Sink Water Filter
A replaced the Culligan 250A filters and now everytime you turn on the water from any faucet in the house you here 2 beeps.
I suggest installing an in-line check valve on the feed line to the Culligan filter and resetting the meter on the filter system. You may be getting water water feeding back out of the filter system when other faucets are run causing the meter alarm.
RJ
Aug 20, 2010 | Culligan Under Sink Water Filter
Have a SY 2650 under sink filter system that whistles
replace filter or bfore you go buy filter take out the filter and run the water to see if that salves it and if it does then change your filter
May 17, 2009 | Culligan Under Sink Water Filter
Culligan Under Sink Water Filter Logo
116 people viewed this question
Top Culligan Tools & Hardware - Others Experts
jmgerny
Level 1 Expert
Craig Butler
Craig Butler
Jim London
Jim London
Are you a Culligan Tool and Hardware - Other Expert? Answer questions, earn points and help others
