Question about Bosch Classixx WFC 2465 Front Load Washer
My washer has started being loud when it spins out and is draing . I was wondering why. I wondered if something was getting ready to break.
  • Bosch Master
  • 2,605 Answers
Welcome to Fixya gojigirl,
Have you checked the pump to insure nothing is in there causing the noise, or do you believe it is coming from the main wash basket ?
I would rule out anything being in the pump first ( you can gain access in the lower right hand corner in the front by removing the pump insert/filter, you may need to drop down the small door in the toe panel at the bottom ) before declaring the main bearings or motor brushes being worn which can sound pretty loud, but usually just in the spin cycle.
Let me know what you find out.
good luck
macmarkus :)
Posted on May 09, 2010
During the washing cycle there is a noise that sounds like something is "clicking" inside ( kind like washing something made of metal inside the drum). it is steady and lasts through the whole washing...
I would suspect that something is caught between the inner and outer drum, like a bra wire or something similar.
If it washes and spins o/k, then I don't think it is a fault with the washer.
It will probably break up, or find it's way into the pump filter.
Hope this helps.
Jan 21, 2010 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Bosch NEXXT 500 SERIES washer Makes knocking sound while spinning
during transport there are fittings installed to prevent damage to the machine. The shaft may have got bent but before panic sets in try to check 1. that there is a gap between the mahine and units
2. that the unit is leveled.
Aug 16, 2009 | Bosch Classixx WFC 2465 Front Load Washer
I have a top loading washer model #4420716...it will spin but make very loud noise I am wondering if a belt or something broke...it sounds like the basket is hitting the sides of the washer.
could be the brakes, if the loud noise is like a screech probably your brake rotor and lining need replacing.
Check and let me know.
Thanks.
Jun 16, 2009 | Kenmore 24032\24036 Top Load Washer
Grinding Noise
yes you are right the tub bearing has failed
May 21, 2009 | Estate TAWX700JQ Top Load Washer
15yr old Whirlpool Estate does not stop filling
umm well it is 15 years old so maybe its just ready to go. get a new washer machine.
Feb 10, 2009 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Maytag Neptune Loud Spin Cycle
im sorry,load spin cycle may be a bad spin bearing.remove lower back panel.look behind large black pully.if see rust ,water.metal fragments.thats it.cost a bunch to repair.ive done them 4 400 to 500$.God bless you ,tom
Dec 28, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washer spinning
Hi jmm119
Its hard to say what it is but it could be one of 2 things, either the belt ore the main bearing is gone. but my first guesss would be the belt.
brent
Sep 28, 2008 | Maytag Neptune MAH5500B Front Load Washer
Loud, abrupt noise immediately before a spin cycle
The belt should "give" about half an inch, or it is too tight or too loose............... Dont forget to get the plug off the wall before all this.
Dec 11, 2007 | Maytag MAH2400A Front Load Washer
Loud clicking during spin, won't spin full speed
manofred, you either have something in your pump or the coupler is starting to break up. Tip the washer back and take a look. See if there is a bunch of black debris under the trans. If so, your coupler is failing. The pump will come off with 2 clips and 2 clamps. Check to see if something is in the impeller. Check the attachments....Catriver...post back.
Feb 13, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Bosch Classixx WFC 2465 Front Load Washer Logo
236 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
