Question about Samsung SPP-2040 Thermal Photo Printer
Rafique:- Samsung SPP 2040 paper problem.
Thank you for your help. I have noticed that the rollers turn ok but the action that lifts the paper up to the rollers is not doing what it should. I am assuming that the paper lifter may in turn activate the front roller to feed the paper in. What therefore makes the paper lifter work? Printer is pretty much new. Mike
    Sergeant:
  • Samsung Expert
  • 406 Answers
If its new, You may contact nearest service center.
Posted on May 07, 2008
Printer shows error 13.01.00 and paper jam
Turn the printer around and lift the flap behind the paper tray. If you have a flashlight, get it. You want to watch the action of the paper pickup roller. By observing to see if it is rotating, slipping on the paper or whatever, you should be able to determine why the paper isn't feeding. A lot of times, it is as simple as the paper backstop has slid back and the roller can't grab the paper that is 2 inches out of reach. Since you've replaced the tray and paper, I would think you might have noticed that. Is the paper moving out of the tray at all?
Jan 25, 2010 | HP LaserJet P3005n Printer
The printer is 2-3 toner cartridges old and has developed a paper jam where the second sheet through stops almost immediately upon being lifted from the drawer. Is this a drum replacement?
Not a drum replacement, use a damp rag and wipe the rubber roller above where the paper is lifted, and also gently hold that damp rag on each of the exit rollers on top where the paper comes out as you open and close the front door to make the printer run for a few seconds. should help those paper jams.
Dec 28, 2009 | Brother HL-2040 Laser Printer
The rollers in my samsung spp-2020 are sticking
On most printers there's a "thing" near the rollers that grabs the paper. It's usually a flat piece of plastic with some kind of stuff on it that grips the paper. It's actually on the out bound side of the printer. You can re-glue the pad by super glue if the part isn't available.
Jun 21, 2009 | Samsung SPP-2020 Thermal Photo Printer
Samsung spp2040 printer
The roller of the paper pick up is rotating or no. If rotating and not taking rollers need a cleaning try this else change the roller.
Mar 24, 2008 | Samsung SPP-2040 Thermal Photo Printer
Paper won't feed on my Samsung SPP-2020
i had the same problem and replaced the ink cartridge and hey presto ! it worked
Mar 10, 2008 | Samsung SPP-2020 Thermal Photo Printer
Spp 2040 printer ribbon
  • Open the door on the right side of the printer.
  • Push "up" on the green lever above the ribbon cartridge. The ribbon should pop out slightly.
  • If it does not pop out, then try prying out the cartridge while pushing up on the grean lever.
  • Pull out the ribbon cartridge.
Feb 14, 2008 | Samsung SPP-2040 Photo Printer
ERROR INSTALLING FIRMWARE
See Working for me. In the fireware zip file. There is 2 firmware. One for model 2020 and one for 2040. Select the correct one for your printer model.
Dec 31, 2007 | Samsung SPP-2040 Thermal Photo Printer
Samsung SPP-2040 Thermal Photo Printer Logo
164 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
