Question about Philips Televison & Video
Dead set replace resistor in tv but still resistor running hot philip hd1918 c125
  • Philips Master
  • 12,061 Answers
FIRST, you Must get a service manual, then you need, equipment, an Oscilloscope is a MUST HAVE. Also a Multimeter, and soldering iron, a DE-soldering station, an anti-static wrist strap, (Any TV is extremely static sensitive). Now FIRST you must make sure the Power supply is 100% as if this is NOT then nothing else can be. Also there are safety considerations, any unit that can cause a Fire or Explosion, or both, needs to be attended to with the utmost care. As if it isn't done correctly, a catastrophe is indeed possible, Faulty sets can cause a fire, and a fire in the middle of the night, I believe is not good. And any person that has attended that set, will be held to account. Now with that understanding, I guess proceed if you wish. Troubleshooting say if it is shutting down, after a certain amount of time, of working and then faulting, then it is most definitely a "Thermal" problem, the way we "Find" problems such as this is "Freeze Spray" you use this on each component that is suspected of being the "Culprit" and you will soon,find that errant component. Now also not every fault is a Capacitor, I see many, many people that think, that Capacitors are always the "Culprit" now while that may be true in a few cases, a faulty Electrolytic Cap, or ordinary, Cap goes faulty, this is only a SYMPTOM, something has damaged those caps causing them to "Fail". One MUST always find the root "Cause", otherwise if you just treat, the SYMPTOM, the "Cause" will just make the "Symptom" come back, in short order, as the prime cause still, hasn't been fixed., Now Capacitors hate AC ripple, or Over Voltage. Thats it. Oh.. and Heat, if these Capacitors, are too close to a Heat Source, then thats a prime cause of failure. Resistors, hardly ever go faulty,and if they do, it is generally obvious. However it doesn't hurt to check values with our Multimeter. Remember though resistors are made, with up to 20% tolerance from stated value, as such, are not too critical, unless in Timing circuits etc. Always check, the Values, of resistors, as with any other component, with the power OFF. Now Diodes especially "Zener Diode", are another thing to check, those and ordinary "Signal Diode" should always be suspect. next we have Transistors and IC's. The Transistors MUST ALL be checked to see if they have a good, "Junction" this is done, with our meter set to "Diode Test" and usually are about 0.6 to 0.7. With IC's you must check, voltage levels, or Logic Levels, going in and out, have a look at the circuit diagram, and it will tell you what they should be. It is a good idea to always measure the Power Supply voltages, see if a "Rail" is Low, that will be because some component has gone somewhat or all short circuit, to Earth, now, if the "Rail" is Higher, suspect an "Open Circuit" component, like a Diode, or Transistor. The voltages expressed in the manual are spot on, ANY variation MUST be investigated. I have been doing all this for over 30 years now, and I do indeed wish, we could have a set of "Symptoms" and be ables to say.. "Oh that;s the so-in-so and replace this" however unfortunately this although does happen, most "Symptoms" can have literally tens, of "Causes" all often "Interlinked" One simply has to do a methodical troubleshooting procedure, and always think, "are my Voltages Correct" as this is how, you Fix the problem, by making them so. Keep up the good work. If that link above doesn't furnish a Service manual, it is imperative you get one, even if you must pay for it. It will pay for itself in about 2 mins. Now just replacing boards will most likely just end up with more faulty, boards, as related you MUST ensure that you have the cause of the event, before we change anything. I have seen so called, "Techs" replace every board, and virtually every component, and that STILL didn't fix it, because the "Fault, or Cause" lay elsewhere, and had not be repaired FIRST, you see that FIRST STEP, like everything in life, is, CRITICAL.
www.scribd.com/.../Philips-Training-Manual-TV-Plasma-Display-Panel-Chasis-FTV1-9 -
www.scribd.com/.../Philips-Training-Manual-TVHD-Chasis-L05HD
http://www.electro-tech-online.com/attachments/repairing-consumer-electronics/29958d1244193349-phillips-lcd-training-manual-pvd1075_lcdtv_training_handouts_244.pdf
These manuals a bove are service training manual, these are what you need, BUT for your exact make and model. perhaps these "Generic" manuals will work,Or find out what "Chassis" that set uses and get a manual for that, in it will be exact schematic diagrams, showing you how it work. Essentially, you must find out, WHY, that resistor gets got, usually something, feeding or being fed from, that resistor, is drawing too much current, overheating the resistor. Now this maybe normal, SOME resistors, especially if power resistors, van and do get quite hot, during normal use, ensure this in't the case. If it is NOT, than you will have to troubleshoot, as to why this is happening. Lift one end of the resistor, and check, that there are no, shorts partial shorts, bad semiconductors, etc. past that point. Resistors are used to reduce current flow, and as voltage dividers.
Posted on May 09, 2010
Should i change a burned resistor for a better one?
It sounds like you have other problems that're causing that resistor to get too hot, Angie. Carefully check for any other components that are also getting hot when that resistor gets hot.
Aug 11, 2014 | Philips 42PFL5603D/F7 LCD TV
Need a philips magnavox ps1966 c125 owners manual
i have a bad reception how can i fix this?
Oct 09, 2011 | Philips PS1966C 19" TV
I have a philips magnavox model HD1918 C125 that only has a jack for cable/antenna. How do I hook up a DVD player?
Go to a tv repair store, they sell RF Modulator that is made to work with your tv, and comes with everything you need to get hooked up and running, and is reasonably priced.
Jan 28, 2011 | Philips Televison & Video
My philips 46pp9302 picture looks green ive lined up the blue and red colors but dont know whats wrong.....help
The tv have a problems known as a convergence problems,it dead.The tv color lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board have dead parts.The 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost like $300-350 for parts and labors.
Oct 27, 2010 | Philips 46PP9302 46" Rear Projection...
My Philips 60inch widescreen rear Projection the picture color is blue and red how can i fix it
Tv problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignment,have colors shadows or 3D pictures.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u $300-350 for parts and labors.
Oct 12, 2010 | Philips 60PP9202 60" Rear Projection...
Philips 21'' L01.2A AB Chassis; Dead, Standby LED off.
it.s possibly a fuse, or a resistor, or regulator or all of the above
Jun 08, 2009 | Philips Magnavox 27MS343S 27" TV
MY TV is dead!
There is a install kit 483531057673 for this model when the set is dead. The kit will contain 7404 and the Horizontal Driver Transformer 5402 along with resistors that will limit stress on 7404 and includes complete instructions.
Jul 09, 2008 | Philips 27PT6441 27" TV
Televison & Video Logo
21 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
