Question about Coby MP-C7085 MP3 Player
My playlists will no longer sync using Windows Media Player.I have always used WMP to automatically sync my playlists, but now I can't seem to be able to add new playlists to my player, edit existing playlists within the player, or delete existing playlists in the player. I can edit/delete/add them using WMP and the sync menu, but when I sync the device the changes don't carry over to the player.
  • 1 more comment
  • rangergirl03 May 10, 2010
    I'm sorry, I don't understand what you're telling me. I don't use music from another source. I download it from either Amazon's MP3 service or from Rhapsody's MP3 service or I rip it using WMP onto my one computer. I then create playlists with those files. I have always been able to sync playlist files to the player using this method until just recently.
    I do apologize, I'm unsure how it happened but my player is not an MP-C7085. It's an MP-705 4G.
    My playlist files are not syncing to my Coby MP-705 4G. The individual music files themselves sync and play perfectly, but the playlist files no longer show up in my device. I have reset the device and have formatted the device. Winamp isn't recognizing the device as a portable and Windows Media Player appears to syncing correctly but yet the playlist files--not the music files but the playlist files--themselves are not showing up.
    Sorry, but it didn't work. I'm wondering something...is my computer still recognizing this player as an MP3 device? In WMP and in the device manager it was labeled "USB Disk Device" instead of Coby. Could this be part of the problem? If so, can you help?
  • Coby Master
  • 3,247 Answers
Reset device to factory setting. See pages 13 and 43.
http://www.cobyusa.com/files/manuals/MPC7085_MN.pdf
It is possible your WMP is now no longer version 10.
Find out if a firmware upgrade is available from
http://www.cobyusa.com/?p=doc
Hope this helps. Please post your comment so that I can help further with your problem.
Posted on May 11, 2010
  • Sam May 12, 2010
    In continuation with my comments posted on 11th May...
    I cannot see the comments posted by other fixya.com experts and also your feedback when I respond to your problem.
    I am assuming the user manual links I posted are actually for your model. ( i cannot find MP-C705 4G on the Coby site.)
    What is the device shown in the My Computer screen on your pc?
    If it is showing as a USB storage device and not as Coby Audio device then it has lost the MTP Files (Media files).
    Best to check the operations on page 37 of the user manual and confirm if you are able to follow the steps required to setup the sync operation with the WMP 10.0.
    --cmmiuser01
  • rangergirl03 May 12, 2010
    It is showing up as a USB storage device not a Coby media player. You talk about it losing its MTP files...is there any way to get those
    back or is the device just busted? My Media Player is 11.
    None of the manuals and things I've found have had any helpful information. I called Coby and they only had for me do what I've already tried--resetting the device and formatting it. I've also uninstalled it through the device manager on my computer and reinstalled it as per one of the experts on here, but it's still only showing up as a USB device.
  • 713 Answers
Hi,this solution will definately solve your problem;
Connect the player, open device manager, right-click on COBY under Portable devices, click "Uninstall", wait till it removes COBY from the hardware list,disconnect the player, press the reset button behind your device to reset it,afterwards,plug it back in - Windows will find it and install proper drivers for you.
problem solved
THANKS AND TAKE CARE
Posted on May 10, 2010
    Guru:
  • 1,049 Answers
WMP will only allow you to sync the device with one computer and one program, itself...if you copied additional content from another source, newer versions of WMP will stop the sync feature from working.
To fix this you will have to copy the music to the local drive, add it to your WMP library, re-sync the MP3 player to WMP, and then rebuild all your playlists witht the new songs.
I don't think WMP 7 and before had this issue. It was added as a form of DRM to discourage using the MP3 player to pass music to other machines.
  • NA NA
    NA NA May 10, 2010
    Napster and other online stores like Rhapsody, Amazon Unbox,
    Blockbuster, CinemaNow etc use Windows Media "plays for sure" DRM
    system. Ironically, this doesn't play for sure, only when it desn't think you've changed the files in some way. Unfortunately, while it could be
    syncing somewhere else that changed your music, it could also just be a little file corruption. As a test to see if this is your issue, if you remove the temp files that track the device, all your problems will temporarily go away.
    The first thing you’ll need to do is go to Control Panel \
    Administrative Tools \ Services for XP and look for the services that
    start with “Windows Media Player”. (Make sure Media Player is closed
    too) Click the stop button for each and make sure that all of the services
    that start with “Windows Media Player” are stopped before you continue.
    Next, open up an explorer window and paste in the following path into
    the address bar.
    %USERPROFILE%\Local Settings\Application Data\Microsoft\Media Player\
    You’ll see a bunch of files in the folder. I’d advise moving all of
    these files to another directory somewhere else, but you could also
    delete them if you were daring enough. Then restart. Now when you restart Windows Media Player, you should be able to add
    music to your library again.
    This has happened to me several times on songs I legitimately purchased, so I now strip the DRM completely rather than deal with the grief. DRM removal software can help you with it, as they strip
    the DRM protection (playback license in fact), convert music or video
    to various formats that can play on various players and remove the proprietari-ness of WMP.
    I know Aimersoft Music Converter and Aimersoft Media Converter are
    such professional DRM converters, one for music only, another for music
    and video both.
    I think your would find WinAmp also works very well as a WMP replacement, regardless of the DRM and can import from WMP.
  • NA NA
    NA NA May 10, 2010
    Most MP3 players are both a USB device and an MP3 player. But cell phones like Blackberries do give you the choice of mounting or not mounting the drive in the system as well. You may want to check whether, if like a cell phone, it has a USB drive mounting option. If it does, it's possible you might have to turn it off.
How can you listen to music
First, you will have to transfer the music to the mp3 player. You can transfer music and pictures to your player using Windows Media Player. YOu can download it from here:
http://windows.microsoft.com/en-US/windows/products/windows-media-player
Once you have installed WMP, reboot and plug your mp3 player. By default, Windows Media Player automatically loads all the music and picture files stored in your My Music and My Pictures folders into the library. If you add new files to these folders, they will also be automatically added to the library. Then you will have to synchronize your mp3s player with WMP.
You can sync your music and pictures to your player using Windows Media Player. Simply connect your player to your computer using the supplied USB cable, set up sync, and you will be ready to sync your media library to the player. When you connect your player to the computer for the first time, Windows Media Player automatically selects the sync method (automatic or manual) that works best for your player. Automatic: If your player has sufficient storage space (at least 4GB of free space) and your entire media library can fit on your player, your entire media library will be automatically copied to your player as soon as you connect it to your computer. Manual: If your entire media library cannot fit on the player, then you will be prompted to manually select specific files or playlists that you want to transfer to your player.
Once you have transfer the music you want-unplug the player from the computer and that's it. If you have more doubts, you can download the manual from here:
http://download.p4c.philips.com/files/s/sa6045_37/sa6045_37_dfu_aen.pdf
Feb 10, 2011 | Philips GOGEAR SA6045 MP3 Player
How do you download music to an mp3 player from a cd?
Normal audio CD tracks should be converted to mp3 files onto the computer's hard drive, first.
This is called ripping or RIP function.
There are several programs that can RIP audio CD.
It is important to convert music into the correct bitrate for the player to match for playback. (192 kbps is good quality and often used)
You can use Windows Media Player 10 or 11 for conversion.
When you use WMP 10 or 11 and the player is detected in the program:
1. Tell the player were your music library is: setup your music library.
2. Create a playlist; make playlist name and add mp3 files to the list.
3. Synchronize the playlist with mp3 files to the player.
If the player cannot be detected in WMP 10 or 11, but only can be viewed as a removable disk in "My Computer" : use the "copy and paste" or "drag and drop" method to put mp3 files from the computer onto the player.
When needing more help, don't hesitate to write a comment in this reply.
May 01, 2010 | Coby MP-C653 MP3 Player
Wen i delete music from the library in windows media player it also deletes it from my philips gogear mix how do i stop this
Playlists to sync on the player can be set in Windows Media Player.
When selecting the Library or Sync tab in WMP full view, the GoGear is visible on the left side in the list.
The player can be either connected seeing the player's icon or not connected seeing the player's map name.
Right click the GoGear Mix and select Setup Sync...
The box, Sync this device automatically probably is selected.
Prevent the player from unattended synchronizing by unchecking this box: Especially when you're removing lists on the computer frequently.
Setup the the playlists to sync first and synchronize manually after that.
Temporary "Sync this device automatically'' must be selected, to be able to edit the playlists to synchronize.
On the right half of the Device Setup screen there''s the "Playlists to sync''.
Under playlists to synchronize, first remove all playlists or those you are going to delete in the library, before synchronizing.
When needing more information, just post a comment.
Jan 06, 2010 | Philips GOGEAR SA6045 MP3 Player
Flash mp3 (MC4004) F"n thing making me mad!
When the player shows up as a detected device in Windows Media Player 10 or 11, the MC4004 will try to synchronize the playlists that are on the player with those on the computer.
It is possible that playlists on the computer:
1. have been removed or
2. are no longer in the library for synchronizing
Synchronizing can be set automatic or manually in WMP.
When you right click the player in the list in WMP, selected Library or Sync view, you will be able to setup the sync mode of
the player.
For more help look in the help function "Help with Sync" under the Sync tab in Windows Media Player.
Need more assistance ? Just post another comment.
Jan 04, 2010 | Audio Players & Recorders
How do I to add a playlist
It's funny how Sony phrases it - you must use Windows Media Player 11 to transfer playlists to your device, but it may not work properly. Go to the Sync tab of WMP 11 - notice how it says drag playlists here to synchronize to your device. Once you have dragged the playlist over, hit Start Sync.
Mar 07, 2009 | Sony NWZ-E436F MP3 Player
How do I create playlists?
The manual, etc is available at www.p4c.philips.com
You will have to, unfortunately, set up your Windows Media Player for Auto-Sync (has definite drawbacks - inclduing: adding songs, pictures, etc that you DON'T want into the GoGear). Playlists can only be synchronized to your player via “auto sync”. Autosync will automatically synchronize your Windows Media Player library content and your player content each time you connect your Player to the PC. If you use the “manual” sync option the tracks in the playlist will transfer to your player but the playlist itself will not.
Nov 23, 2008 | Philips SA5125/37 MP3 Player
Big problem with play lists
According to the manual for most GoGear's, you have to have automatic synchronization enabled in Windows Media Player for the playlists to transfer correctly.I still have not been able to verify if this is true, since I have been able to transfer playlists fine with and without auto-sync engaged.
I haven't tried a 3115 specifically, but with an SA4111 and an SA5125, I just created the playlist in Windows Media Player 11, right clicked on the playlist name after it was created, selected "Add to Sync List," and then "Start Sync" with GoGear connected. I used this method, because it seemed more likely to add the songs AS A PLAYLIST rather than just dragging and dropping the tracks WITHIN the playlist.
As I look more closely at the documentation for the SA3115, however, it does not have the same playlists options as other GoGear's - it seems to limit you to Playlist-on-the-Go. I know that the GoGear will not recognize folders that you create in Windows Explorer, so that option is out. You can connect the GoGear, and see if a Playlists folder appears in the left-hand pane underneath the icon of the GoGear in the Sync tab. My gut feeling, however, is that this player is just not as equipped as other GoGear models for playlist transfer. I'll go back to the lab on tuesday and see if I can find anything new.
-Tha Mp3 Doctor
May 25, 2008 | Philips GoGear SA178 MP3 Player
Zen Touch mp3 player isn't able to play tracks in windows media player 11
im not sure but i think you have to create the playlist first then transfer to mp3
Feb 20, 2008 | Creative Labs Zen Touch MP3 Player
Putting music in different folders
Within WMP 10 create a few playlists and drag/drop music files to the appropriate playlist (drag whole albums or individual songs). When you have constructed and filled your playlist(s) connect your player, open the sync tab, and drag the playlist(s) to the sync box. Click sync and smile. ;)
Jan 12, 2008 | Creative Labs Muvo V100 MP3 Player
Puting playlists on my sansa
You have to set the playlists to auto-sync with the device. That is the only way they work with WMP 10. Best of Luck.
Oct 05, 2007 | SanDisk Sansa e260 MP3 Player
Coby MP-C7085 MP3 Player Logo
71 people viewed this question
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
