I have a canon mp460 printer that i have just re'filled and i am still gettin the 'ink running low' message on screen. how do i resolve this problem?
    Master:
  • 518 Answers
On the maintanance screen is there a "Ink counter Rest" tab. It must be clicked on as soon as you put the cart back in.
I also got the following from a website out there:
1) Enter SERVICE MODE by pressing sequentially Menu Copy Scan Copy Copy or Menu Copy Copy Copy Scan (on some models)
2) Select TEST MODE.
3) Press ‘+’ 8 times till ‘Select [8]’ PRINTER TEST in TEST MODE.
4) Select 3. [EEPROM CLEAR].
5) Select 0. [INK COUNT].
6) Press the [OK] key.
7) Press the [Stop/Reset] key (returning to the state of 3)), and then press the [ON/OFF] key.
Hope that fixes it for Ya...
Geno
Posted on Mar 27, 2008
SOURCE:
I cant print it says I'm out of black link and I just replaced it and it's flashing E 1 6
From http://www.refreshcartridges.co.uk/igloo/clearing-canon-pixma-error-message-e13-e16/
Locate the STOP/RESET/RESUME button on your printer which is represented by a triangle within a circle on the body of your printer and is usually in red, white or black as pictured below. With the reset button located hold it down for at least five seconds and then release it.
Aug 02, 2015 | Canon PIXMA Office Equipment & Supplies
New ink cartridge and still getting error UO41
Error U041 is strictly a low ink error message, so it's strange that replacing the ink would not resolve it. Make sure the ink cartridges are inserted properly and the protective tape has been removed from the cartridge. If not, there might be an issue with the ink cartridges not being locked in place.
May 04, 2012 | Canon PIXMA MP460 All-In-One InkJet...
How to reset canon pixma mp145?
Besides service tool, you can use MPTool software to reset Canon printers MP series. This software support for canon MP150, MP160, MP170, MP180, MP450 and MP460.
Reset waste ink counter
To reset waste ink counter at printers canon pixma MP150, MP160, MP170, MP180, MP450 and MP460 there any 2 choice, that is :
  • Start with printer on then run this software
  • Click Reset Main (main) to reset waste ink counter and then click Reset Platen button (additional)
Dec 21, 2010 | Canon Office Equipment & Supplies
New ink jets showing low ink
Because they are cheap!
It doesn't make any difference your printer will still print. If you get a message saying out of ink, cancel it and continue printing, till you start seeing signs of no ink, then replace them.
Jun 05, 2009 | Canon PIXMA MP460 All-In-One InkJet...
'empty' ink cartridges - green prints!
just fill up all the catridge bcoz in colour printer anyone of them is not fill up the printout not coming properly , after filling the catridge just check
May 26, 2009 | Epson Stylus R265 InkJet Photo Printer
Waste tank is full, How do fix it, can I clean it myself?
Inkjet printers have a fibrous pad inside them that collects the waste ink from cleaning the print head. Over time, this pad fills up with ink and can no longer hold any more. When this occurs, the printer indicates a "waste ink full" error.
Replacing the waste ink absorption pads is something an authorized canon service facility can take care of for you. Once they are replaced, it'll be functional again.
May 15, 2009 | Canon PIXMA MP460 All-In-One InkJet...
Ink has run out message
Ink not made for your printer has risks. 20 years as Canon rep taught me this. Yields: are affected by resolution, type of paper, condition of print head, condition of ink jets, all ink jets and lasers are mfg'd under lisence to Canon. You have the best! Anytime supplies are cheaper, something is left out. used cartridges usualy leak air and drip ink ck for stains under print head. cartridge has used blotter also drips. Cheaper cartridges contain less ink, no free lunch. Fill it yourself 1 or 2 times and do it right. Put the printer in your shower for twenty minutes if you see excess leaked ink. Allow to air dry for a few days then install new cartridges. Run all the Nozzle checks and print head utilities. Touch nothing else on the inside. This will fix it or [email protected]#%k it up for good
Jan 04, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Error message on Canon MP160 flashing E-2-2 error message 5100
The error code refers to Ink Cartridge
Issue: ERROR: Error code 5100 appears on the computer screen
Issue: ERROR LED: E, 2, 2
1. Disconnect and reconnect power cord to reset the device
2. Remove Packing Material MP160 / MP180 / MP460
3. Reseat ink cartridge (MP160 / MP180 / MP460)
Nov 15, 2008 | Canon PIXMA MP460 All-In-One InkJet...
Error message U051 on canon MP460
Check the Label on the cartridge if it covers a certain area then you will get an error message. Compare it with a good cartridge the label should nearly touch the lugs at top end. Only applies to refilled Carts.
Oct 04, 2008 | Canon PIXMA MP460 All-In-One InkJet...
"Out of ink message" after refilling cartridges
The cartridges can be refilled but the ink level will be zero as they have a chip in them and at the moment. Canon have not yet issued a chip res-setter. You can cancel the message it gives, but you must fill them up as soon as they run out or it will not work again.
You can cancel the warning forever too. Look on Google, for it would be wrong to say on here as Canon do not recommend filling them.
May 20, 2008 | Canon PIXMA MP460 All-In-One InkJet...
Open Questions:
Computers & Internet Logo
135 people viewed this question
Ekse
Marvin
Marvin
