Question about Milwaukee Tool Case Heat Gun
My case 360 trencher feels underpowered and when trying to dig it actually stalls the motor. what could be the problem. The bearings on the chain front and back are good.The trench actualy stalls the motor when lowering the chain into tne ground to dig and feels underpowered when creeping along.
The dig boom will not raise or lower on a 1020 walk behind trencher
Craig, I do not have a lot of experience with trenchers, if hydraulic operated not enough oil/check reservoir,, one of the valves/controls may be stuck, you will have to follow line from boom cylinder and trace it back to the valve and dismantle and repair. Secure boom as to not harm you or others.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Apr 13, 2016 | Cars & Trucks
How do I adjust the trencher chain. It's loose. I would think there is a grease fitting, but can't find it.
trencher chains run fairly loose as tight chains break when the teeth hit rock as for a grease nipple , there is probably not one as it would break off while digging
Feb 18, 2016 | Garden
How to ajust the timing chain on Yamaha big bear motor a tv
You will need to find the timing marks and have the firing specifications to line it up. Most timing marks have the Top Dead Center position marked with a large raised triangle mark. Take out the spark plugs and use a pencil with an eraser to determine (by feel) when the piston raises all the way up the cylinder... this is the TDC position. Line up the chain so that the TDC triangle corresponds to the actual piston travel inside the cylinder. Once you have them aligned, dial back the timing the few degrees specified in the manual. Put the plugs back in and fire it up. It it sounds "off" then repeat the process, something wasn't aligned correctly.
Mar 06, 2015 | ATVs
Trying to find parts manual or parts
Find the serial number and model number. Give Vemeer a call and they will be able to give you the part numbers. Probably give you a schematic as well.
Jul 15, 2014 | Vermeer V1150 Trencher
I have a 4x4 1999 gmc suburban 1500 with a 5.7 motor and an automatic transmission. when my suburban is in 2 hi, i can sometimes put it into reverse and it will not move but make a grinding noise. then i...
unfortunately what it sounds like is the transfer case like you suspect. inside are bearings and gears and a chain what happens is the chain will stretch and cause this problem it will actually jump the teeth on the gears, you will need to have the chain replaced in the transfer case. sorry to have to tell you this but i hope it helps.
Feb 13, 2011 | 1999 GMC Suburban
My delta sander stalls while sanding on the belt.
Mine was underpowered from the get go. I have since sold it. Keeping it well lubricated does help though.
Jan 23, 2010 | Delta Machinery 4x6 Belt/Disc Sander
Weak perfomance,saw about stalls with 1/4" plywood
Most of the little 10" motorized saws are way underpowered. Take it back to Sears and get your money back. Go somewhere where they'll let you try it out first. Get a Ryobi from Home Depot. I've had one for years and it will rip a 2x4 all day long.
Nov 01, 2009 | Electrical Supplies
Cracked case on a yamaha yzf450
You need an engine as by the time you noticed the oil leaking, it was too late. If you have a cracked crankcase, get a motor.
Jun 11, 2009 | 2003 Yamaha YZ 450 F
Milwaukee Tool Case Heat Gun Logo
131 people viewed this question
Top Milwaukee Tool Air Tools & Compressors Experts
John Trevino
Geert Deschamps
Are you a Milwaukee Tool Air Tool and Compressor Expert? Answer questions, earn points and help others
