Question about Curtis DVD8078
Need a replacement cideo connector the little orange thing under the back panel
  • 5,138 Answers
Call Encompass Parts Distribution 1-800-638-3328
Posted on May 09, 2010
Have a 2005 pontiac grand prix gt and the fuse for the interior lights found in the interior fuse panel (passenger side dash) immediatly blows when replaced. fuse blows before it is even inserted i need a...
Hello
Do you have lighted visor vanity mirrors? If so disconnect them both and recheck the short. I have found the hot wire rubs through due to lowering the visor, this shorts out the interior light circuit. Never use a higher amperage fuse than what came out, you risk starting a electrical fire, have seen this happen 1st hand.
Nov 03, 2011 | 2005 Pontiac Grand Prix
Right rear brake light/turn signal sometimes works, sometimes it doesn't. have tried replacing bulbs, the socket, still have same problem
Make sure the new socket is properly grounded. The black wire is the ground wire. Sometimes the wire[s] get loose at the turn signal switch connector. Remove the plastic shroud from the steering column directly under the steering wheel. The wire to be concerned with is orange with light blue tracer.This is the wire for the right rear turn & brake. It may be loose in the connector. Wiggle & gently pull on the wire. If it comes out of the connector, the little tang will need to be carefully pried out a little bit to make it lock when pushed back in place.
Feb 15, 2011 | 1999 Ford Expedition
How to replace heater core on 1995 eldoado
You first remove the bottom dash panel on the passenger side. Then remove the glove box (6 screws). remove the little panel on the back of the back of the glove box and disconnect the air bag connectors. Disconnect the connectors for the trunk, gas tank and the glove box light. Pull glove box out.
on the passenger side under the hood against the firewall, remove the two hoses connected to the heater core.
now back inside the car.... remove the connectors and airlines connected to the box, remove the lever on top of the black box. remove retaining screws and push out of way. two screws hold cor in. remove and replace. revers ord
Oct 14, 2009 | 1995 Cadillac Eldorado
Lincoln airbag light blinks 3 2 times for 3 times then stays on
could be your clock spring, or a loose connection somewhere under your seats
Jul 21, 2009 | 2002 Lincoln LS
How do i turn off the orange light on the vizio tv, it won't go off after the tv is turned off?
That little fella is only turned off by unplugging it. If all those little lights in America could be turned off we could do with one less nuclear power plant. If unplugging it is not an option, my wife's solution is to cover it with a piece of black tape.
Jul 08, 2009 | Vizio L32 32 in. LCD HDTV
Signal wiring for 74 sportster
CONNECT IT BETWEEN POWER SUPPLY AND THE SWITCH. POWER IN ONE SIDE POWER OUT THE OTHER
Dec 03, 2008 | 1979 Harley Davidson XLH 1000 Sportster
ERSD36S09 Dual Fuel Dacor; broiler doesn't work
I had a similar problem. My broiler wouldn't light but the igniter was glowing. It turns out this igniter has to glow virtually white hot. If it's red or orange it probably needs replacing. I bought a new one from Appliance Parts Pro's. However, when I look at pictures of these things they all look exactly the same. My guess is all appliance manufacturers use the same unit.
To change it on the Dacor you need to pull off the back panel. Loosen the unit inside by removing the screws and shake the wires so someone else can see which ones. Disconnect the wires from the connectors and tape a piece of thickish string to it. This allows you to pull it out from inside the oven and have a way to get it back in past all the little turns and corners. My replacement had bare ends so I cut off the old connectors and soldered them to the new unit. However, I would guess you could use wire nuts instead.
Nov 18, 2008 | Dacor Epicure ERD30 Dual Fuel (Electric...
Procedure for removing door panel on passenger side 1994 camry
Sure.
Pull off the triangle thing.
On the door, at the front edge, there should be 2 plastic caps. Remove them. Under the caps there are screws. Remove them.
On the rear of the door panel, above the latch, are 2 round things, with a smaller round thing in the middle. Press on the inner round thing, and pull the pin assemblys out.
Do you have a light on the door panel at the bottom? If so, pry it out with a small screwdriver (it's just a "press-fit"), and remove the wire connector.
Under the arm-rest, remove the big phillips screw that is hidden, about an inch back from the outer edge of the panel. You will see the hole.
Under the arm rest, remove the tiny plastic trim cover, remove another big phillips screw.
Remove the door handle: Remove the phillips screw. Slide the handle forward or backward to release it from the door metal. Undo the clamp from the lock rod to the handle.
Remove any screws at the very bottom of the panel, if there are any.
Starting at the bottom of the panel. pull straight out, to defeat the plastic clamps tht holds the panel to the door metal. Once the panel is loose, pull it up a bit to remove it from the window opening retainer. Finally, inside the panel, unplug the wiring harness to the window switch assembly.
If you need any more info, please comment back. And, Thanks for the FIxYa.
Nov 14, 2008 | 1994 Toyota Camry
BLACK SCREEN
I was finally able to fix it. It did take me a little longer than the 10 minutes as another as written:) I had trouble getting 2 of the little screws out, but finally succeeded. Then I saw the orange ribbon, but nothing seemed to be loose. At last I saw where it connected at the TOP, and pushed down the little black connectors which showed on both sides under the orange ribbon. I pushed it down as far as I could, put the back on the camera and turned it on! And it worked! Thanks so much for the tip. I am going to keep a little screw driver in the camera case along with the tip how to fix it in case it is a problem again!
Apr 25, 2008 | Panasonic Lumix DMC-LZ2 Digital Camera
Shuts down
it is due to problem in red cideo section. solution 1 supply to red video output& output itself 2 crt base loose 3 connector loose 4 red video sigal line from chroma ic to red cathode of crt. 2 red
Nov 13, 2006 | RCA 27V520T 27" TV
Curtis DVD8078 Logo
16 people viewed this question
Top Curtis Televison & Video Experts
Rommel Balcita
Are you a Curtis Televison and Video Expert? Answer questions, earn points and help others
