Question about Panasonic CT-27SL13 27" TV
I have a panasonic ct-27sl14 It was fine early in the morning went to work come home and it won't turn on.Tried the romote then the power button on the tv.Check the outlet getting power.Plugged the tv back in still would not turn on.Puzzled my son says you can help.Thanks T J
  • 308 Answers
SOURCE: PANASONIC CT-36SX12 IT FLASHED ON, TURNED OFF, AND NOW DOESN'T WORK AT ALL
If you're lucky, the main fuse just opened up. It takes a 6.3 Amp slow blow type. Otherwise, it could be a defective voltage regulator and related parts in the power supply I would guess.
Posted on Feb 11, 2007
premtech
  • 934 Answers
SOURCE: Tv will not turn on
This set has a common problem with th main fuse opening for no other apparent reason... One of the few exceptions to my corner-stone statement that a fuse is never the cause only a symptom..
Don't replace it though with the same type grade, use a 6.3a slo-blow gma type - available at Radio Shack... Try that and if everything works you're back in business.. If not we nee to find a cause...
Bill
Posted on Dec 08, 2007
  • 4234 Answers
SOURCE: PANASONIC 32" CT-27SL14 model
This is a problem with the pincushion and convergence circuits. Are you planning on repairing this yourself? If so, I'll look up the circuit designations and parts. If not, expect a parts cost in the $15 range plus the local labor rate.
Dan
Posted on Jul 03, 2008
SOURCE: panasonic CT-32SL14 flat screen tv stopped working
I dont know if this will help anyone....but I opened the TV up and found a blown fuse right wherer the power cable connects. I replaced the fuse and while doing so noticed alot of dust and what seemed like part of a spider web. I got a can of compressed air and cleaned it up. Once I put in the new fuse the TV worked perfectly.
Posted on Aug 12, 2008
Raditronic
  • 196 Answers
SOURCE: tv lock
PRESS POWER SWITCH AND ACTION FOR 3 SECOND
Posted on Sep 10, 2008
Panasonic CT-27L8SG displays gray screen and white hoizontal line
Is it still under warranty?
If not I would find a good TV Service Shop and have them check out the power supply as there more than likely a 'Capacitor' much like a battery that is going bad.
Blessings,
A/V Media Guy
Nov 22, 2009 | Panasonic CT-27SL14 27" TV
Ct 27sl14 has all 4 corners dark and the whole picture is rounded looking
there are 3 caps i round that could cause this.
C457 100mf/25 volt
C455 100mf/35 volt
C816 100mf/50 volt
the first 2 are in the vertical circuit,last one in the power supply.
Sep 24, 2009 | Panasonic CT-27SL14 27" TV
Not receiving commands from the remote. (Panasonic Panasonic CT-34WX54 HDTV)
Your using a universal remote from what U am understanding, Two solutions for ya
1)diffrent remote all togeather from radioshack
or
2) the Tv's IR is not working
Apr 22, 2009 | Panasonic CT-27SL14 27" TV
TV won't turn on. (Panasonic 1080i HDTV)
By the sound of it its a dead power supply im afraid :( It is very common for them models at that age very common... it may be cheaper to fix then buying a new one but ill let you decide that one but yea theres hundreds of people that have the same problem with them panasonic's bummer dude :(
May 04, 2017 | Panasonic CT-30WC14 30" TV
Tv wont turn on
take your tv to technician who can check your power supply, if your power is coming on and off, than a problem is not as big. firstly let him check a ht of a supply constantly, your supply is cutting.
Nov 03, 2008 | Panasonic CT-32SC13 32" TV
My ct-30wx54 30" tv has no power
A little more details before this occured 1) Was there any bad weather in your area before this happened? 2) Is the unit surge protected? 3) Was there any type of zap sound the last time you turned it on before the power went out?
Sep 27, 2008 | Panasonic CT-30WX54 30" TV
TV Has no picture
http://www.bruzziforum.com/vbf/showthread.php?t=79
Panasonic probably uses the same code on your model.
Jan 11, 2008 | Panasonic CT-27HL14 27" TV
No video/audio when TV is turned on..
This set is popular for the main voltage regulator to be bad. If you have a meter check the input voltage . it should be between 135 to 159 vdc. Now pin 4 should be aroud 125 to 130 when you switch the set on. Hope this helps Good Luck
Jun 02, 2006 | Panasonic CT-27SL14 27" TV
Panasonic CT-27SL13 27" TV Logo
553 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
