Question about HP Computers & Internet
When I log onto my computer it will not run any programs at all. The most it will do is open a window and say it's loading but it never actually does. I can't even get into the recovery program because it won't open.
  • 88 Answers
insert Windows XP cd and use recovery console, or try entering emergency mode by pressing F8 while computer boots.
Leave rate if I helped you, thanks!!
Cheers,
Mike
Posted on May 09, 2010
When istart the computer cant log in ,eventhough my user name and password is correct
A log-on loop on your Windows XP computer is a difficult situation where the computer never completes its boot cycle, restarting intermittently ad nauseam.
This issue indicates a major problem with the boot functionality of your XP system.
Restore the computer to working order by utilizing the repair and restoration utility on your XP system disk.
Insert the XP disk into the computer.
Restart the computer.
Press any key when prompted to boot from the disk.
Press "Enter" at the first screen and "F8" at the license terms.
Highlight the drive containing XP and press "R," repairing the operating system boot files and removing the log-on loop.
or
Windows XP sometimes has a glitch when you are logging in to your user account in order to boot the operating system.
The glitch logs you in and then logs you off the account.
This problem is usually caused by one of the programs that load during the computer's start-up.
Fixing this issue is a matter of ensuring that whatever program is causing the problem doesn't start up as soon as you start your computer.
or
Power on the computer and allow it to get to the user logon page normally.
There is no need to start up the computer in "safe mode."
Click the user who is having the issue and type in the user's password if one is set up.
Press and hold the "shift" button on your computer keyboard as soon as you see the tool bar load up at the bottom of the screen but before any other program has a chance to do so.
This stops any "Startup" program from running and logging you off.
Right-click the "Start" button on the bottom left of your screen.
Select "Explore" from the menu that appears.
Double-click "Programs" from the list on the left side of the window that pops up.
Double-click "Startup."
Select all the files inside the "Startup" folder by dragging a box over them.
Right-click anywhere on the selected files.
Select "Delete" to delete those files.
Note that deleting the programs from the "Startup" folder does not delete them from your computer.
All this does is make it so that these programs no longer start as your computer is starting so that any error in the running of the programs doesn't interfere with logging in to your account.
Hope this helps
Nov 13, 2012 | Dell OptiPlex 780 MT Desktop Computer...
There is a listing available somewhere in Windows wherein you can "quick launch" a program to have it mostly loaded when first turning on the computer ( or have the program deleted from such...
A program can not be 'mostly [or partly] loaded' actually. You can go into the program's settings though and see if there's a way for it to 'Run on Startup', which would load the program when your computer boots up. The only problem with this is that it can slow your computer down and make it take longer to boot up.
Aug 21, 2011 | Computers & Internet
Actually I don't know whether my problem is Toshiba problem or Windows problem. Occasionally while downloading or opening and application my computer gets stuck and gives busy signal and doesn't open or...
Hello
There are a few things to try.
1 run disk clean up.
2 run disk defragmentor
3 uninstall any programs your not using to free up space.
4 you may need to purchase some more ram or memory which will help the pc run faster.
Mar 22, 2011 | Computers & Internet
I log onto facebook, it redirects me to lite.facebook and the page then will not load it just goes white.. How do I fix it???
hi,
Pelase try this.
1. open internet explorer, tools - internet options - advanced - reset.
2.if it still doesn't work it could and malware issue, run a scan with http://mbam123.notlong.com/ . run full scan.
3. try to remove all the tool bars from add or remove programs.
Feb 17, 2010 | Microsoft Windows Vista Home Premium with...
My computer screen goes blank when I change the user
Hi, A(n) (recently) installed program is probably causing the problem, interfering with the service that takes care of the logon and -off process. To see if this is causing the problem, you can try the following:
Use this method if you remember around which date the problem started: 1. Click 'Start' -button 2. Type the following into the 'Searchbox': rstrui.exe 3. 'System Restore' opens 4. Select a date from which to restore your computer from. Needless to say, the date you choose should be a date on which you weren't experiencing the problem :-)
Use this method if you don't remember around which date the problem started: 1. Click 'Start' -button 2. Type the following into the 'Searchbox': msconfig 3. A system configuration window will show, where you can change the way Windows starts up 4. On the 'General' tab select the second option to boot diagnostically, loading only the standard devices and services. 5. Click 'OK' 6. Click on 'Reboot' 7. When you're computer has rebooted a message will show telling you that you've changed the way windows should start up and the system diagnostics window will show as well. 8. Since only standard devices and services have been loaded, try to logoff or change user and see what happens. If everything goes well, you know that a program, which should be a program you've installed before any problems started showing up, is causing the problem. If not, there's a corruption in the services of your operating system. 9. If everything goes well, you can start loading other services (from programs you've installed in your computer) one by one from the 'System configuration' window by clicking on the 'Services'-tab.
When you've found the the program that's causing the problem, delete it from your computer and select from the 'System configuration' window, 'General' tab the first option, for windows to start normally.
I hope this helps Good luck.
Cheryl
Jun 22, 2009 | Microsoft Windows Vista Home Premium with...
Forgotten password
when you press the power button keep pressing F8 and you should get a menu , select safe mode and let it load.. once it has loaded select the administrator account and it should log in ...( providing you havn't set a password) then just go to user accounts and change your password
May 29, 2009 | E-Machines eMachines T3830 PC Desktop
Loaded Sibelius 5 OEM onto my new computer - won't open
Hi. Try the steps in this web page:
http://www.sibelius.com/cgi-bin/helpcenter/chat/chat.pl?com=thread&start=422397&groupid=3&&guest=1
In particular:
If you go to the actual sibelius.exe file in C:/Program Files/Sibelius
Software/Sibelius 5 can you set Run as Administrator in
Properties/Compatibility?
Mar 20, 2009 | Computers & Internet
Trouble shooting in windows o/s, my computer not functioning properly.
hello mr. rajat kumar ......
firstly i want to say that please format your computer or don't use double click on your drives just right click on the drives and select the explore option now you can open your drives
ok mr. rajat are you satisfied with me?
Nov 01, 2008 | Microsoft Windows XP Professional With...
Computers & Internet Logo
32 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
