Question about Sharp SF 2020 Copier
How to empty toner box
How do you empty the toner box
  • 328 Answers
Open front cover remove toner cartridge release copier open drum unit ,pull out you can see waste toner box
Posted on May 29, 2010
Replace new toner and displeyd mesages "chesk waste toner box". i remove waste toner box and cleaned waste toner in drum unit. no result...
the top of the waste toner container must be cleaned 100% from the toner because it should be a light sensor that has to pass through it , if its spoiled with toner the light cannot pass through it ,so i recommend you to empty the waste toner container first and wash it with water and drying it well before using it again.
Feb 20, 2016 | Kyocera FS-2000D Laser Printer
Reset Waste Toner
If your machine is displaying "replace waste toner container" then you can empty the waste toner box & reset the machine.
If you open the front door you will see a large black box & above this a small rectangular green button. Pressing this button will release the black box. The box will then lift upwards from the machine. At the bottom of the box you will see a round, clear plastic bung, remove the bung & empty the waste toner into a suitable bag or container. Once emptied, the bung can be re-fitted, the waste box can be inserted back into the machine. Locate the waste box into the 2 slots then push the waste box firmly back in place until it latches. Turn the machine off & on using the switch located to the left of the waste box in the bottom left corner of the inside of the front door. This should reset the machine. Be careful when disposing of the waste toner, it is flammable so do not dispose of in a fire. Hope this helps.
Dave.
Feb 19, 2016 | Sharp MX-3501N All-In-One Printer
I keep getting a message install waste toner box and close all doors, i have tried all that and the message keeps coming, the waste toner box is empty.
remove the toner, check if there is any debris perhaps also blowing in the guides of the toner. Give it a shake and refit it.
Close the doors and if you still get the message you need to replace the empty toner
Mar 11, 2015 | Office Equipment & Supplies
I have Konica Minolta C652. I emptied toner box & placed it back but then the screen is telling me to install toner box & close all doors.
In the middle of the Box there is a see thru dark plastic , a lip , that goes inside the the sensor , when the box gets full of toner it blocks the light that goes thru it, when you emptied the box the plastic inside was still dirty, Replaced box or clean the box from inside
Dec 17, 2014 | Konica Minolta Office Equipment & Supplies
Waste toner box
If you can empty it you should be able to reuse it. Be VERY careful when emptying it, toner is the finest dust you have ever seen and can become a cloud in the air if not handled carefully, landing on everything and making a giant mess.
May 22, 2014 | Dell Office Equipment & Supplies
Reset Waste Toner in a Brother
  1. Remove the full waste toner box per manual.
  2. Wear breathing protection as there will be toner dust in the air.
  3. Place flat in a work area and remove the 6 screws retaining the black box cover and carefully remove cover with box still flat on the work area. Be careful, the box is full of waste toner powder.
  4. Dispose of the waste toner by tipping into waste container, being careful not to inhale the powder. Use a blower or vacuum to remove final traces of waste toner from the box and clean all surfaces with a clean cloth.
  5. Place the box flat on the bench and inspect the clear sight-glass at the front. Inside will be a black flag which should be down on the bottom of the sight glass. If not, there is still waste toner in the front of the box which needs to be shaken or blown out.
  6. Replace the cover and 6 screws and replace the waste toner box in the printer.
  7. If error message still says replace waste toner box, then you need to check the sight glass again. The flag must be horizontal at the bottom of the glass or it is not completely empty.
Jan 24, 2014 | Brother WT300CL Waste Toner Box
Excess waste toner
For MFC-9840, it was simple to find and empty the box (http://www.howtofixcomputers.com/forums/printers/brother-mfc-9440cn-waste-toner-box-reuse-288524.html) and assume it is equally easy to do once you locate the box on your model.
Jul 09, 2013 | Dell 1350cnw Colour Laser Printer
Replace/Install toner waste bin error message of samsung clp315
The toner box is probably full. The toner box is a clear box on the left side when you open the front cover. The box has the labels Y, M, C, and K on it. Pull it out using the tab at the bottom. find a place to empty it. You can do this by turning it upside down and gently tapping it. If the box is full some toner may be outside of the box causing the sensor to be blocked even after it is empty. You may want to clean the box, toner cartriges and inside the cavity with qtip, tissue paper (without lotion), or air.
Oct 21, 2010 | Samsung CLP 315 Laser Printer
I have a c652 biz hub keeps coming up waste toner box konika minolt printer
To replace the waste toner box, open the front door above the paper drawers. The waste toner box is on the left hand side (usually). Your supplier should have supplied an extra waste toner box. Slide out the 'full' toner box. Replace with an empty one. This should register that you have installed an empty waste toner box. If not, turn off the copier and after a minute or two, turn on the coper again. [If you want to be environmental friendly, the toner box has a small slide cover approximately 1-2cm long (usually on the upper face at the rear as you remove it). Place this end in a plastic bag, slide open this 'cover' and rotate the toner box 180° so this is facing down. Care needs to be taken to prevent the 'waste toner' from flying everywhere. Gently agitate the box until all the waste toner (a grey color) has spilled out. (Approximately 600-800gms) Carefully seal the bag and dispose. An industrial vacuum cleaner can be used to remove the residual toner, clean down the waste toner box with a soft rag and it is ready to re-use.]
Sep 02, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Toner Empty Message won't go off
check that the toner is inserted correctly, reboot print.
Aug 27, 2007 | Konica Minolta magicolor 2430 DL Laser...
96 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
CheckitRight
CheckitRight
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
