Question about GE DCVH515GF Gas Dryer
Belt came off
I need to know how to put the belt back on right over the pully & motor
  • 10,319 Answers
Before you attempt to reinstall check the tensioner for this belt. There is a reason for the belt to come off
The pulley where the belt slips onto may have a flat spot on it or a worn bearing
Posted on May 09, 2010
Needing to see diagrahm of belts and pullies to fix tiller
tensioner pulleys run on the back of the v belts
most tillers move forward by the action of the tillers bur occasionally they can be belt driven
that may be the spare pulley if you have a pulley on the axle
otherwise run the belts direct to the tillers with the tensioner pulleys running on the back
would need to know make , model and year to get a diagram of the belts
May 08, 2016 | Garden
NEED TO PUT THE DRUM BELT BACK ON ASAP
The other pulley is spring loaded it puts tension on the belt.
Pull the pulley back and the belt will slip ight over then release the tension pulley and your done!
Apr 17, 2014 | Haier HLP140E Electric Portable Dryer
The belt for the dryer is not in place and the dryer is not longer spinning. how would i fix that? There is also a piece with a wheel on it that i cannot figure out where it goes but looks as though it is...
Look up "Tension Pully & Belt Diagram" on internet for your dryer on google or Dogpile. You should be able to find how to
put the Tension Pully back where it belongs & how to thread the belt through it and back on to the motor drive shaft. Check different sites for the right picture for your dryer. Here's a picture to get you started. Good luck,
Sep 13, 2010 | Kenmore 500 6952 Dryer
Diagram of pullies and belts on 86 toyota mr2
If you are talking the a/c pulley and alternator pulley, I am pretty sure the belts are different sizes (different number of ribs in the belt). So, you can just look carefully at the ribs and put the right belt on the right pully. from memory, the A/C belt goes on first and all the pullies towards the front of the car are used for that belt. The Alternator belt goes on next, and all the pullies from the crank shaft toward the back of the car (from the crank pulley) go to that. I could have those reversed, but the ribs on the belt will show you for sure. have fun!
Mar 06, 2010 | 1986 Toyota MR2
Belt came off hotpoint washer
hello mam
before trying please check the belt tension. and if you inspect the threads are visible on the belt which will be seated on the pully please change the belt and to put it back
1.plase the belt into the motor pully first. and then using a screwdriver hold the belt into the drum pully slowly rotate the drum as you rotate the drum you should hold the belt along the pully.
Oct 04, 2009 | Washing Machines
Belt came off, don't know how to put belt back on
The platter should lift off and allow you to see the motor, drive pully's, and the belt. You should be able to put the belt back on the platter pully and then around the motor pully and the just align the platter back up with the spindle and gently lower it back into place. If the platter won't just pick right up off the spindle, look for three screws that hold it down to a triangular shaped support underneath. When you remove those screws, the platter should lift right off and allow you to see the drive pully and motor and belt. Good luck, and be gentle.
Sep 28, 2009 | Audio Players & Recorders
How do i replace the drive belt on philco dryer model:pdes6a8w3
you need to open the front & leave the drum hanging, place the belt on it , grooved side down , pull the belt thru the opening under the pully. spring the pully back so you have more slack in the belt , enought to place the belt over the motor pully. replace the front & go
Aug 21, 2009 | Dryers
I need a diagram for a 97 jeep 2.5 l belt install
Hello, I hope this helps, check underneath your hood, there should be a sticker with a diagram on how the serpentine belt goes on. If you don't have it, let me know I will send you one. Take care, God Bless.
Willie
ECSracing Team
Aug 14, 2009 | 1997 Acura CL
The water pump
ok this is fun lol.jack the car up and put it on a jack stand,then you will have to pull the drivers side tire off.now you need to put a jack under the motor and unbolt the driver side motor mount. lower the motor down it will only go so far.now for the fun part.you got pull the crank pully off there is one bolt in the center of the pully.once you get that off pull the timing cover off top and bottom. there will be 2 belts one is the timing and one is for the water and oil pump. the water pump it the one closest to the back of the motor. it would be best if you replace the timing belt since your already in there.make sure you get ALL the old gasket off the block.you dont want to have to do it twice.oh yeah loosen the tensioner pully to pull off the timing belt it right above the crank one bolt in the center also.if you didnt move anything you should be able to put the new timing belt back on with now problems if you did move something then you got to put it back in time to do that make sure the #1 cylinder is top dead center of the compression strok then turn the cam gear till where its says up on the spoke is pointing up.after that put everything back together and you should be good to go. hope this helps if you have anymore questions just let me know.have fun lol
Jan 15, 2009 | 1991 Honda Accord
Hotpoint WD640P - Fitting a new belt
Put belt on motor pully first then turn big pully around!Like fitting bike chain.
Oct 11, 2008 | Hotpoint Aquarius WD63 Front Load...
Open Questions:
GE DCVH515GF Gas Dryer Logo
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
