Question about Dell Inspiron 1200 Notebook
How do i start my dell inspiron over like i just purchased it clean off the whole hard drive?
  • 1,476 Answers
Open the CD rom drive while the unit is running and place your original recovery disc in the CD rom drive and turn the unit off. Reboot the unit and it should start from the CD. Follow the on screen instructions including telling it to reformat the hard drive. This will clean off the drive but anything you had will be gone. Let me know if you need more help. Thanks for using FixYa and for the generous rating.
hardrocko
Posted on May 09, 2010
How to Fix my Dell inspiron mini 1010 won't go past Launch Startup Repair or Start Windows Normally ,keeps looping back to same page.How do I fix when this model doesn't have a place to put a CD?
Do as it suggests, if you can, backup your data. Purchase a new hdd, fit it, load windows, download all drivers from Dell and use a usb converter to copy files back from the faulty drive.
Dec 17, 2014 | Dell Inspiron Mini 10 Notebook
Slow, stalls, freezes up
If your hard drive is too full, then your computer is going to perform slower. Delete old files which are not required.
Remove programs that you are no longer using. Delete temporary files.
Empty your recycle bin. Right click on Recycle Bin. Click Empty Recycle Bin>Yes.
Run an error check on your computer. The error check can remove errors that slow down your computer. If you are using Windows, you can do this by clicking Start>My Computer. Right click on your hard drive (typically c:) and then select Properties. Click the Tools tab>Check Now and then Start.
Clean up your registry. You can purchase software that will fix any registry errors on your computer.
Perform this computer maintenance on a weekly basis.
Apr 24, 2010 | Dell Inspiron 1501 Notebook
I have no problems..need larger hard drive for Dell Inspiron B130. Have only 15gb left. Is this a diffucult task? hump
Surprisingly the task of replacing the hard drive is fairly easy, as soon as you have purchased a replacement drive (make sure it's a IDE 2.5ins drive)
Just click on the link that i have provided bellow for instructions on how to remove the hard drive from the laptop and replace it >>>>
http://www.mrdimpy.co.uk/Dell%20Inspiron%201300%20Service%20Manual/hdd.htm
Regards.
Jan 06, 2010 | Dell Inspiron B130 Notebook
Inspiron 1521 is running hot
I recommend you check your air vents for dust buildup. Use an old toothbrush to clean the dust off the outside of the vents and then use one of those cans of compressed air meant for cleaning keyboards to blow air through the vents to dislodge any dust accumulated inside. Some laptops have more than one vent. Make sure to clean all of them. I once worked on a Sony laptop that I had to take apart to clean out all of the vents.
Jun 30, 2009 | Dell Inspiron 1521 Notebook
Dell inspiron 5150 primary hard drive disk 0 not found
You may find that either the cable is not connected properly or is faulty, or the worse case the mother board has problems (driver, chips, breakages)
May even be a power supply problem, as the power supply has many output points and different voltages that the HDD power out may have blown. If it has then the rest of the system will appear to be ok.
So first off, check the cables connections on the motherboard, and look for any breaks in the cables, and if you have a power meter of some sort check the power connection, or plug in another power connector, the ones with the same end are generally the same power outputs. The ribbon cable for the HDD should have 2 sockets for HDDs and you must connect your HDD to the end one.
May 14, 2009 | Dell (U0614) for Inspiron 5150 60 GB Hard...
IRQL_NOT_LESS_OR_EQUAL
1. purchase a 2.5" usb enclosure.
2. remove your hard drive and install in the enclosure.
3. plug the enclosure into a working computer and copy or move your important files onto working computer.
4a. reinstall the laptop hard drive and try a repair installation by booting from the XP cd. (if you are running xp)
4b. reinstall the laptop hard drive and try booting to Last Known Good Configuration. Press either the F5 or F8 key while rebooting to get to the menu.
4c. purchase a new hard drive and reinstall the OS using the reinstallation cd's
Dec 09, 2008 | Dell Inspiron 1501 Notebook
Dell Inspiron 6000
You could image or ghost the old drive, but you need to have access to it from another system with storage to save the information as there no way to have both drives installed in this model. I believe the easiest and preferred method would be to perform a clean install. You can use a borrowed OS CD provided you have your own product key. You could then get an external USB enclosure to connect your old drive to retrieve data.
Dec 04, 2008 | Dell Inspiron 6000 Notebook
Dell XPS M140 Very Slow In Booting Up and General Use
Run a check disc, or hard drive test in the bios, if any part of the test fails, then the hard drive is failing and will need replaced. Delete anything from the start up section of the start menu/programs, and download and run CCleaner form filehippo.com, it will help keep your computer clean and running fast/smoother. Also, are you using Norton? If so, remove it and use the AVG. You can find it at File Hippo as well.
Aug 16, 2008 | Dell Inspiron XPS M140 Notebook
Dell Inspiron 5100 PP07L hard drive
Did you accidentally buy a SATA notebook drive?
If so, this will not work in your notebook, it used IDE drives.
Jan 19, 2008 | Dell Inspiron 5100 Notebook
Dell Inspiron 1200 Notebook Logo
65 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
