Question about Epson Stylus CX6600 All-In-One InkJet Printer
Won't print seems to be communication problem between Presario 6000 running XP and the printer. Printer will copy but will not print from computer.
  • Anonymous Apr 24, 2008
    I changed the black ink cartridge on my epson stylus 6600. My printer will print when pushing the button, but will not print from the computer. It worked fine for several days after I changed the ink cartridge, but now it doesn't. I don't know if the two are related.Can you help?
I would suggest uninstalling the printer, and it's software. Then follow the instructions from Epson to reinstall the printer. I would reboot the system after uninstalling the printer. The reinstall it and the software.
Posted on Mar 01, 2009
Printer will photocopy but will not print from my computer.
I have changed the inkjets.
Posted on Apr 03, 2008
6ya staff
SOURCE:
How can I get my mac to communicate with my printer?
reinstall the printer driver from the manufacturers web site as a lack of communication indicates a driver problem
next click on the printer > properties>compatibility tab> click box and highlight operating system on the computer and >apply
Jul 24, 2017 | Epson Workforce 615 AllInOne Printer
S405 printer won't communicate with computer when trying to print
First, make sure that the firmware of your printer is up to date. Just go to http://bit.ly/ghfW8H to download the firmware update.
If the firmware update doesn't help, try to uninstall the Lexmark driver and download an updated driver online at http://bit.ly/rtOKTx. Just choose the Operating System of your computer.
Also, if your printer is connected to your network, try to set a static IP to your printer to prevent it from getting a different IP.
Dec 12, 2012 | Lexmark Interpret S405 Wireless All-in-One...
Hi - my x4550 lexmark printer wont print, can you help?
If your printer won't print when you're making a copy using the Copy button on the operator panel, it could be due to your ink cartridges. Try to re-seat your ink cartridges into the printer and make sure they are properly seated.
If you're not able to print from your computer, it could be a communication problem. A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if usb-connected), reboot your computer and unplug/replug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Try to print again.
You may refer to this article for Wi-Fi connection issues: How to identify a Wireless Communication Problem and Resolution Tips
Aug 11, 2011 | Lexmark X4550 Multifunction Wireless Color...
When printing message says x2650 cannot communicate with computer
It seems there is a possibility of a problem with the printer itself, or perhaps the cartridges. You should first self-test the printer. Since we are unsure where the problem exists, we must do eliminative troubleshooting to rule out parts of the printing system. The self-test allows us to rule out software and the cable by testing the hardware by itself. Please note that this is not a "fix," but rather a diagnostic test to determine if your hardware is at fault.
Next, try this printer self-test by following the steps given below:
1. Please turn OFF the printer.
2. Press and hold the "Color copy" button.
3. Now, turn ON the printer.
4. Once you see "0" on the display, release the "Color copy" button.
5. Press the Up arrow button until "2"appears on the display.
6. Press the "Black copy" button to start the self test. Once the page has printed, the printer will stop printing.
The self-test should at least print out a set of either black or color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with the color cartridge installed by itself. (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed.) If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, let us know. This includes any print quality issues, we need to know if the problems you have with your black or color are based in the printer, or communications with your computer, or the computer's software.
If the self-test prints your test bar(s) clearly, the printer hardware is not at fault. The issue may be a communication problem, or perhaps a software conflict.
However, please let me know the windows operating system installed on the computer. This information is required for us to troubleshoot the issue further.
Please let us know the name and version of the operating system (Windows XP / 2K / NT, Windows Vista, Mac) that you are using on your computer. This information is important for us to troubleshoot the issue further.
Apr 13, 2009 | Lexmark X2650 All-In-One InkJet Printer
Kodak G610 printer dock won's communicate with computer
You know I had this same problem for a while as well. The only solution I found was that I HAD to use the Kodak Easyshare software in order to print anything with it. (That was the case with my XP desktop and my Mac laptop...). But sometimes it still would not spool properly and would require unplugging the printer and plugging it back in to reset.
Jan 24, 2009 | Kodak EASYSHARE G610 Thermal Printer
Zebra S300 printer pauses without printing additional copies
I Use driver from Nice Labels
http://www.nicelabel.com/downloads/nicedrivers/zebra seems to work fine
Dec 05, 2008 | Zebra Stripe S300 Thermal Label Printer
Lexmark x5470
When you got this message were you trying to scan?
What I want you to do is a copy. Doing a copy will generally not require you to be hooked to the PC.
Scanning and Printing all require communication from the printer to the computer. Failure in communication can either be something on the computer, something wrong with the cable or rarely something wrong with the printer.
I'm assuming you have done the following:
1. Power off your printer and your computer.
2. Unplugged the power from the printer
3. Unplugged the USB cable from both the printer and the computer.
4. Reconnect the USB cable to the printer and the computer.
5. Plug the power back into the printer and make sure the printer is on.
6. Turn on the computer.
Those are general troubleshooting steps that can be done for any communication problem.
If you have done all of those try this:
Press and hold down the Windows key on the keyboard, and then type the letter R.
Type "devmgmt.msc" and then click OK on the Run dialog.
Find the item Universal Serial Bus controller.
Click the + sign next to the word Universal Serial Bus controller.
Do you see USB Printing Support?
Yes:
Right-click on USB Printing Support, and then click Properties.
Does the Device status say “This device is working properly.”?
Yes:
Have you tried uninstalling and reinstalling the software?
No:
Click the Troubleshoot button to try to resolve the problem.
Does the Device status now say “This device is working properly.”?
Yes:
Try your print again (might need to restart)
No:
Might have a problem with your Printing Support
No:
Let me know - if you have a problem with your printing support you'd really need to contact your PC MFG for help - but you can always try uninstalling the USB Printing Support and reinstalling it (only if you have your disks that came with your printer).
Sep 10, 2008 | Lexmark X5470 All-In-One InkJet Printer
Computer isn't communicating with my printer
computer is not communicating with my printer i unplugged the usb port i and i resart the computer
Aug 31, 2008 | Nikon COOLPRINT Thermal Printer
Computer will not communicate with printer
Go out to Lexmark web site and look for a vista update in their software download section. So this should solve your problem.Most of the cds which come with equipment do not contain vista software and drivers.
Aug 06, 2008 | Dell 962 Photo All-In-One InkJet Printer
Epson Stylus CX6600 All-In-One InkJet Printer Logo
141 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
