Question about Gold Medal 2011EB Pop-O-Gold Popcorn Maker
Modell 1618ets pumps oil all the time - Gold Medal 2011EB Pop-O-Gold Popcorn Maker
VW 1.6 2002 MODEL CLASSIC POLO OIL LIGHT PROBLEM
Either you have a faulty oil pressure switch or the pick up screen of the oil pump is clogged. I would change the switch first as it's 10 bucks not expensive then go on from there
Feb 05, 2018 | Cars & Trucks
How to replace the oil pump as no oil is coming onto the chain
WELL AS U DIDNT INCLUDE ANY MAKE AND MODEL , I CANT BE SPECFIC , BUT B4 U JUST GO INTO REPLACING PARTS , HAVE U TRIED TO CLEAN IT ?? IVE SEEN LOTS OF NO OR LOW OIL PROBLEMS OCCUR WHEN SAWDUST GETS JAMMED INTO CHAIN BAR , AROUND OIL GROOVE( NEXT TO MOUNTING NUT) , A QUICK TEST OF PUMP IS TO RUN SAW WITH BAR AND CHAIN REMOVED (NOT FOR LONG TIME!) AND SEE IF OIL PUMPS OUT HOLE
Nov 15, 2016 | Garden
How does chain oiler work?
On most models there is a worm gear on your crankshaft that turns the gear of the pump. The pump is a shaft with a flat side at the tip inside of a tube/housing that spins and goes slightly back and forth like a syringe pumping the oil to bar/chain. Most of the times the oil pump gear gets stripped (depending on your model) causing it not to oil.
Hope this helps
Feb 16, 2016 | Garden
Change the oil pump in a f-150 4.6 2002 model
Ford F150 5.4L Timing Chains and Guides Oil Pan Oil Pump ...
? 5:08
https://www.youtube.com/watch?v=BgvGjfzrRjU
May 10, 2014 - Uploaded by dezertol
Ford F150 5.4L Timing Chains and Guides, Oil Pan, Oil Pump, Cam ... i am looking into changing the oil pump myself... did you try removing the intake ... I need help with my timing for i 3v4.6 mustang gt, im about to take of my ...
Ford 4.6L, 5.4L, 6.8L Engines -Melling Oil Pumps - YouTube
Nov 04, 2015 | Cars & Trucks
HOW TO CHANGE A OIL PUMP ON A BMW 316I M43 1995 MODEL
Low oil pressure? It's not your pump. It the crankshaft bearings. I have never replaced an oil pump for low pressure. Always the bearings. I have replaced them because I did the rebuild or someone just wanted a high pressure pump. Don't waste your time on just a pump, only to have the same results. If you really like the car and it is worth it to you. Build the engine...It is 30 years old.
Jan 19, 2015 | BMW Cars & Trucks
Volvo s40 1.8 noise from housing on rocker cover
The lifters are hydraulic on this model and as a result they are noisy for about the first 15 minutes after cold start. As a precaution I would just make sure to check your oil level as being really low on oil will cause the rockers not to pump up with oil as well. Oil pressure causes the rockers to expand under pressure via the oil pump. If the car has extremely high miles I would maybe have the oil pump replaced during next timing belt job.
Jun 10, 2014 | 2002 Volvo S40
Prime oil pump, 231 engine
You don't give the year and model, and I'm sure its not a Cutlass Ciera if it has a 231.
Usually its a good idea to pack the gears with grease or vaseline to help prime the pump. Since the pump is mounted on the outside of the engine it can be very difficult to get oil from the sump into the pump gears for the first time.
Jan 30, 2013 | Oldsmobile Cutlass Ciera Cars & Trucks
Replacing Oil pump in Ford Expedition
the oil pump is on the crank behind the balancer and timing chain cover:
REMOVAL
1. Remove the timing chain.
2. Remove the oil pan.
3. Remove the three (A) oil pump screen and cover bolts and the (B) oil pump screen and cover.
4. Remove the two oil pump bolts and the oil pump.
INSTALLATION
1. Clean and inspect the mating surfaces.
2. Install the oil pump and loosely install the two oil pump bolts.
3. Install the oil pump screen and cover and install the three oil pump screen and cover bolts.
4. Install the timing chains.
5. Install the oil pan.
Apr 25, 2012 | 2003 Ford Expedition
I just bought a replacement pump today. Model
The oil will be in the stainless steel or silver colored part of the pump. If there is no access to this part then the oil is put in there by the manufacturer. I believe the small red plastic plug you speak of covers the overheat blow off valve. Just leave it. When you run the washer for a long time you may see some water spill out of there. The only way to change the oil is to separate the two pump sections. Not advisable without some knowledge and the correct tools
Aug 11, 2009 | Annovi Reverberi RMV2.5G27D Pressure...
I have a problem with a toyota rav4 2005 model. the oil pump is not working even after changing it several times.
Though I may have said this at least a hundred times to various people, Oil pumps do not fail...In close to forty years I can count those that have on two fingers.(out of many hundreds) Oil pressure is regulated by your engine bearings...worn bearings permit pressure drop and lower supply to upper parts of the engine.If you have a bearing problem you can change the pump as many times as you like and it won't help!
Jul 26, 2009 | 2004 Toyota RAV4
Gold Medal 2011EB Pop-O-Gold Popcorn Maker Logo
118 people viewed this question
Top Gold Medal Kitchen Appliances - Others Experts
Oloyede Monsuru
john h
Tom Chichester
Are you a Gold Medal Kitchen Appliances - Other Expert? Answer questions, earn points and help others
