Question about Magellan RoadMate 2200T GPS Receiver
Magellan does not turn on. Can we reset?
No power. device does not turn on. 'any suggestions?
    President:
  • 1,111 Answers
Yes, you can try the reset but before you try that..plug it in to a known good charger (like the car charger has a green light to tell you its working)
once plugged in, press and hold the power button for upto ten seconds...if that fails, try the reset on the left side under the flap...depending when your 2200 was made, it will either be a pin hole where you can use a paper clip to reset it, or if its an early model 2200 it will have a slide switch that should be toward the down position..to reset turn unit on, then either slide the switch up, wait a second or two..then back to the down position then try and restart it...if its the pinhole, just depress the reset with a paper clip, then try and restart it by pressing and holding the power button for up to ten seconds.
these 2200t are also known to have faulty power ports that i can help you with should the above advice fails.
let me know if you need further help
bill
Posted on May 10, 2010
  • Richy_T Dec 10, 2010
    Sitting here, my 2200T just powered up randomly. Then down again. What's the deal?
  • Ben Dover Dec 10, 2010
    hi Richy_T
    the following advice pertains to the following magellan gps systems.
    Magellan 800, 860, 2000, 2200t, 2500, 3000, 3050, 3100, 3140, 4000, 4040, 4050 and 6000t
    i fix these and many other magellan gps daily so when considering my advice , please understand i do not google my solutions.
    assuming your car charger is working (the little green light is on) and your magellan still wont start up after holding the power button while its plugged in for up to ten seconds and still does not start..read below
    this is actually a very common problem with these magellan power ports...they are poor quality from the factory and always and i mean always fail..the new ports that you find on ebay are 100% better then the factory port.
    if your able to replace that power port yourself, you can get one HERE, if not, ask the fellow that sells them for help.
    due to some dubious "experts" on fixya, im not permitted to help you directly, but please follow the link above to get further help.
    let me know if you need more help or info
    Bill
    EX
    Standing Member of G.O.T.
I have a Magellan Road Mate 5220-LM and it was working yesterday. When I got back to my house. I noticed it was flickering off and on. What should I do?
Hello
First of all try a hard reset
Slide and hold the power switch for more than 8 seconds.
If your device is connected to a rear view camera i suggest you disconnect and reconnect it.
May 24, 2015 | Magellan GPS
My magellan 1700 won't turn on, even after I reset it and put in a new battery
if you have a volt ohm meter see if theres voltage at the power adapter plug
May 12, 2014 | Magellan RoadMate 2000 GPS Receiver
How do you reset a magellan roadmate 1220?
As a general rule, for Magellan RoadMate models the RESET BUTTON is on the right side inside a small hole; the use of a pointed object (tip of a pencil, a ball-pen, etc.) is required to apply pressure on this button in order to perform the RESETTING PROCEDURE.
You may also can try to hold down the POWER BUTTON for 10 seconds to power off the device; then repeat the same procedure (holding down the POWER BUTTON) for other 10 seconds to power on Magellan RoadMate.
Mar 08, 2011 | Magellan RoadMate 1220 GPS Receiver
Magellan Roadmate 2036-mu will not find satellite signal at all. It straight out of the box. tried having it in clear view of the sky, and still nothing. Any suggestions?
With the GPS turned ON; slide the power switch to turn it OFF and continue to hold it for another 20+ secs. Release the switch and restart the GPS. It should try to locate the satellites, if it still is not able to find after reset then this could be a hardware problem with the GPS.
Feb 04, 2011 | Magellan 2036 GPS Receiver
Reset my Magellan maestro 4040
it could have a faulty power port, but try this...plug it in, then press and hold the power button for up to ten seconds
If that fails,
bill
Jul 17, 2010 | Magellan Maestro 4040 GPS Receiver
WILL NOT TURN ON
Use a cell phone charger from motorolla razer, it is not wired correctly and the magellen turns on with an error, unplug the magellan from the cell phone charger and it will reboot.
Apr 25, 2009 | Magellan Maestro 4250 GPS
Has no satellite tracking
i had the same problem i hooked it up to the usb on my computer then power cycled it( reset then turn on then hold the power button for 15seconds) i did that about 3 or 4 times and then it worked
Apr 05, 2009 | Magellan Maestro 3225 Car GPS Receiver
Magellan Maestro 3100 only get logo and black bar
did you hit the reset button in that little hole on the left side of the unit?...press it with a bent straight paper clip wire and it should reset properly
Mar 24, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Magellan 310 Signal Won't Lock In
Turn on the power while holding down the right arrow. This will reset the unit. You will have to reset the location, date, and time.
Nov 26, 2007 | Magellan GPS 310 GPS Receiver
Magellan RoadMate 2200T GPS Receiver Logo
277 people viewed this question
Top Magellan GPS Experts
Jungle Ghost
Jungle Ghost
Are you a Magellan GPS Expert? Answer questions, earn points and help others
