Question about Technics SL-PD887 5-Disc CD Changer
Volume Control?? There doesn't appear to be any volume control for the SL-PD887 5-Disc CD Changer. I managed to connect speakers but again without volume. I can play cds on this model through a television like a dvd player. What equipment would I need- a remote control? Is there one available for this model which is 10-12 years old? Thank you, David_Stuart99@hotmail.com
    Novelist:
  • 155 Answers
Unlike low-end hi-fi systems where you buy one box that does everything, the CD player you have is part of a component hi-fi system (i.e. you buy your CD player, tuner, amplifer etc. as separate items.) This is why there is no volume control. It needs to be connected to an amplifer. It's on the amp that you will find the volume control and where you connect the speakers. (When you connect it to your television, you are just using that amp in the TV instead.)
The CD player did originally ship with a remote control, but I don't know where you would be able to buy one on its own. You may find the the remote does allow you to alter the output level of the CD player, but you still need to connect it to a proper amp to get it to work.
Hope this helps,
Matt
Posted on Mar 27, 2008
My motherboard doesn't release an audio even if all the drivers are okey.
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speaker plug/outlets is usually at the back of the computer or if it
Oct 16, 2011 | Computers & Internet
I cant hear the music very well... it is very faint and i have my speakers plugged in. how do i turn up the volume? i cant find any buttons to do so.
CD changers don't normally drive speakers (the lack of a volume control and speaker connections being a HUGE clue). What are you using for a speaker amplifier?
Sep 18, 2011 | Kenwood CD-223M 200-Disc CD Changer
Have power but no sound come out
the drivers might have been corrupted by something foreign or you might have got a virus run your antivrus program
click start control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area
If you are having problems with you sound
also
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps you
Sep 02, 2011 | JVC Audio Players & Recorders
No sound
if you are having problems with your sound
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
also
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
make sure you have an earth ******** before touching any parts inside your computer
May 02, 2011 | Altec Lansing ACS 45.1 Computer Speakers
No audio drivers on my sl-85erv2 for win xp any help?
also
hope this helps
Apr 22, 2011 | Soltek X400A (SL-85ERV2-L) Motherboard
Problem with sound card AMD870 . I have configured 5.1 sound system and it works but suddenly it dissapears ... I mean disapears only center/ subs and rear speakers while front is still working....
also
hope this helps
don
Feb 24, 2011 | Asrock ASUS M4A87TD EVO AM3 AMD 870 SATA...
I dont have the remote. is there a volume control on the system?
No. Volume for external sound sources is usually left up to the preamplifier or amp.
The remote is available here for under $30...
http://remotes.com/remotes/servlet/rs?a=gmi&uuid=12969479069380&smodel=SLMC4&brand_pn=TECHNICS_SLMC4
Feb 05, 2011 | Technics SL-MC4 61-Disc CD Changer
On a sony cdp-ce275 5-disc cd changer where is the volume button or nob? we got one donated to our program but we can't control the volume
since it is a changer and not a receiver there is no volume as that is controlled by a separate amplifier.
Oct 03, 2010 | Sony CDP-CE275 5-Disc CD Changer
No volume
maybe he invert the connection of speaker with the antenna wire-try also to make system reset (on-off)----remove power cabel and reinsert it check volume control in high level.
Jul 31, 2008 | RCA 100-Watt Stereo System With 5-CD...
Volume is uncontrolable
Hi sounds like you have the audio out from the cd changer connected to the RCA/Phono out of the radio. double check that the output from the CD changer is going into the correct phono/rca connector regards Mark www.carradiospares.co.uk
Apr 04, 2007 | Panasonic CX-DP88 8-Disc CD Changer
Technics SL-PD887 5-Disc CD Changer Logo
238 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
