Question about Zanussi ZX99 / 5 Bottom Freezer Refrigerator
Help locating the start and run capacitor
Thus was suggested as being the cause of my recent fridge/freezer problem, though im not sure where to find it or what it may look like, any pointers greatly appreciated
  • 1 more comment
  • lavadasun May 13, 2008
    i have a freez-freezer ZX99/5,i had power failer on,everything was working fine before popwer failer,when i got power bach,freezer is working,but freez is NOT,i wonder if u could help.thank you,
  • robert samples May 11, 2010
    whats the fridge doing
    what is your promblem exactly
  • 67 Answers
Check your compresor motor if not working, first step 1, check the over load ic at side of your motor compresor have a plastic cover. 2, check your thermostat control inside the said unit, 3, check the fuse supply the motor. mostly no fuse, clean it and strat if no start, try to replace the ic overload, god bless boss_frnd@yahoo.com
Posted on Dec 13, 2008
Neff integrated fridge freezer. Intermittent fault. Sounds like compressor jerking on and off
Possible cause is start/run capacitor faulty.Do not run fridge please get a tech to confirm problem.
Jan 17, 2016 | Neff Refrigerators
My ctf1826ar freezer works great but the fridge is not cooling. Nothing is frozen or blocked. When the freezer door is open there is cool air that comes our of the vents in the fridge but when it is...
the frig part not cooling though the freezer works is usually caused by bad air flow due to restriction somewhere. check ur vent settings and make sure not defective, the door rubber insulation may also be defective and not sealing properly after closing? and thus cool air escapes? but if ur feeling noticing air flow from the freezer but not in the fridge, the flow is obstructed, if the flow is off and on, do u notice the sound of the fan always running or does it go off and then on, it may be defective, the only time fan should go off is when in defrost mode?
Sep 27, 2014 | Refrigerators
My freezer is on maximum but food is not freezing,what can be the problem
Tthe switch may be broken thus preventing it from changing or the freezer itself has a problem and in this case I suggest you either get a new fridge or get it fixed depending on how bad it is- hope I helped :}
Sep 13, 2013 | Gorenje K337MLB Bottom Freezer...
LG french door fridge - makes hideous noise - loose bearings? - whenever fan is running, which is several times an hour. Any idea what is causing it? Husband tried to grease the fan. It's really...
A broken fan blade can cause a noisy motor. or a buildup of ice can cause some noise. If thes aren't the case you will need to have the fan motor replaced.
Jan 04, 2011 | LG LRFD25850 French Door Refrigerator
I do not know how old the fridge is but the freeze is not freezing my food. It is very hot where I live not sure if that has to do with it. Also do not know which way to turn controls to make the freezer...
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Aug 07, 2010 | Hotpoint  14.9 Cu. Ft. Top-Freezer...
Where can i find the defrost cycle in my freezer? The coils were frozen up so I have defrost everything with a hair dryer. The fan is working but I want to check the defroster.
This timer is generally located in the under the fridge in the front or back. It's generally looks link a small square box about 3 inches square with a single round slotted dial. When you locate the timer using a flat head screwdriver simply turn the dial until you hear the compressor turn off a click. If the fridge is not running you can open the door long enough to warm it up and get the compressor started then turn the switch to make sure you have the defrost timer in the defrost mode. I would also suggest that you check the fridge hourly and make sure that it has started running again after a few hours. If you have a faulty switch this could keep the fridge from starting again. If the switch is faulty and the fridge fails to start by itself then simply rotate the timer until the fridge starts.
Also if your fridge is opened a lot or you live in a high humidity area this too can cause excesive icing.
www.appliance411.com/faq/howdefrostworks.shtml This link will give you a better understanding of fridge operations.
Aug 04, 2010 | KitchenAid KTRP22EK Top Freezer...
Display reads er and ff
Hi
Thanks for using FixYa. Error ff is freezer fan fault. This usually happens when either the rear board has gone bad or the freezer fan itself is bad and needs to be replaced. To check what is causing the error you can start with checking the fan which is located behind the back wall inside the freezer. Also check the rear board as it might not be putting the fridge into defrost long enough and is causing the ice to build up in the freezer and thus stopping the freezer fan from turning and so causing ff error. Leave the fridge unplugged for 24hrs which will melt all the ice then plug it back if still the issue is not resolved and you hear the fan running then it is the rear board that needs to be replaced. Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jun 30, 2010 | LG LRSC-26922 Side by Side Refrigerator
Freezer works, fridge does not. Also the sides of the fridge are really hot but not up the top near freezer section. Fridge has recently been moved. Thanks
Warm sides are usually caused by the condenser fan which is underneath around back not running. If it's not running when the compressor runs it will cause the problem you describe. You will need to remove the cardboard backing on the back of the fridge to access the fan.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
When it was moved, was it laid down? If it was it should be stood upright for 24 hours before being plugged back in.
Feb 13, 2010 | Refrigerators
Fridge is 12 years old or so and freezer has been icing up. The fridge is now suffering from global warming and is near useless, being the same temp as the outside air (it's summer here in NZ, yipee!). But...
IF THE FREEZER HAS FROST AND ICE NO COLD AIR WILL BLOW TO THE REF SECTION, YOU MAY HAVE A DEFROST ISSUE. UNPLUG THE REFRIGERATOR OVERNIGHT THEN TRY TOMAROW IF THIS WORKS IT WILL FROST UP AGAIN UNLESS YOU CAN LOCATE WITCH DEFROST PART IS BAD.AND REPLACE IT. HOPE THE SURF IS GOOD! ANYHOW
Jan 13, 2010 | Refrigerators
I have a Roper RT21LMXKQ00 Freezer wont freeze
The problem is a defrost problem. The freezer coil has frost on it and thus restricts the cold air from flowing. This affects the refrigerator as it gets its cold air from the freezer. The ice will not make if the temperature is above 12*F and this also is why ice cream is like mush.
Apr 23, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
Zanussi ZX99 / 5 Bottom Freezer Refrigerator Logo
126 people viewed this question
Top Zanussi Refrigerators Experts
Charles T Nevin
Charles T Nevin
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a Zanussi Refrigerator Expert? Answer questions, earn points and help others
