Printer printek web password
I need to remote conect to printer, when i access by web and try to make login in the network configuration, the printer ask me by password, and i dont now it, can u help me?
  • Anonymous Apr 01, 2014
    i have a richo 202 sn netwrok printer .. prinr is ok with working...whn i get to scaning... thy told scaning destination???? wht u mean by scaning destination ??? and web image password (login) of richo 202 sn
  • geo george
    geo george Apr 01, 2014
    i can get printer nd printed well.... but i cannot acces scanner... while i am attempt to scan .. they show ` scan destination ` this is the actual problem
  • 55 Answers
You can access this networked printer by their IP address
just connect through printer's IP address and you will get your printer access...
Posted on Mar 28, 2008
Clear access control list on a Ricoh copier
you need first to print the printer configuration list, you will see from which to which ip address you may connect. (example from192.168.1.1-192.168.1.13)
then you will set on your laptop or pc some address that is in the range of access control list, also set the printer ip address in the range of access control. than connect them to connect to the machine by and the laptop/pc with a FTP/LAN
(cross)cable or connect them with a network-switch. Then open a web browser on the laptop/pc and in the address bar write the ip address of the printer. it will open the web page of the printer, login with: user name: "admin" and password:"blank" . find the acces control setting and clear them. set them all with zero. (example: 0.0.0.0-0.0.0.0). if you need further help please write a replay.
Oct 17, 2014 | Ricoh Office Equipment & Supplies
Tip
Steps to Configure Static IP Address for Epson Wireless Printer
The IP address is a specific number allocated to a device, which is connected to your PC network. If you require configuring a static IP address for your Epson printer, it can be possible by using the network configuration menu that you can access via the Internet browser on a connected system. To do that, it's necessary to know your printer's existing IP address. If you have a password protected the device, then you must know the username and password credentials to access your Epson printer network configuration menu. You can call at the Epson Printer tech support phone number and get expert's assistance to do that in a proper way.
Find Epson Printer's IP Address
    1.Click the 'Windows Start' button and choose the 'Control Panel' on any system connected to the similar network as your Epson printer.
    2.Double-click the 'Printers and Faxes' option and then find the Epson printer that you want to configure a static IP address for in the printer list.
    3.Right-click on the Epson printer from the list and choose the 'Properties' option.
    4.Click the 'Ports' tab and find the printer to configure a static IP address. Click on the printer to select it.
    5.Click on the vertical bar between Description and Port and shift it to the right to expand the Port column. Find the Epson printer's IP address under the 'Port' column, which is a series of numbers divided by, resembles and periods 192.168.1.2.
      1.Open up your favorite Internet browser on the system connected to the similar network connection as your printer for which you need to set up a static IP address.
      2.Input the printer's IP address into your browser address bar. Click the 'Enter' button.
      3.Enter your printer login information. If it's not password-protected, enter 'admin' text into the 'Username' box and leave the password field vacant. Click the 'OK' button, followed by the 'IP Configuration' tab to sign into the Epson wireless printer settings page.
      4.Find the 'IP Address Configuration' or 'TCP/IP' section and adjust the value from 'Auto' to 'Manual' or 'Static.'
      5.Input the static IP address that you need to allocate to the Epson wireless printer into the provided boxes. It forces the network to assign the selected IP address to the Epson printer every time it tries to connect to the computer.
      6.Click the 'Save' button to apply the settings and close the browser.
      Additional Tips:
      Configuring a static IP address for the Epson wireless printer is not a complicated process if you are a tech-savvy user. However, if you can't set static IP address for your printer even after following these steps, you must avail the help and guidance of technicians that can be possible via the Epson technical support phone number. They will assist you step-by-step to configure IP address of your printer in an efficient manner.
      Source: http://bit.ly/2lJLWxS
configure static ip address for epson wireless printer-yxa4stq55mknsqg0b4p2yanw-2-0.jpg
on Feb 15, 2017 | Epson Office Equipment & Supplies
When I go to my browser on my Polaroid tablet, it
The guest access password would be assigned when you (or somebody) installed and configured your router.
In that case, you would need to look at your router configuration to find the password. This is usually done by directing your web browser to your router by typing in a web address something like http://192.168.1.1. After you connect and login, you will see screens that show your router configuration and you are looking for something like "wireless access" or "guest access". You will need to know the administrative user id and password of your router to see these screens.
Perhaps you already have other computers or devices (printer, Wii, Roku) connected wirelessly in your home. In that case, use the same wifi password that you used to connect those devices.
If, in fact, *nobody* configured your router (you just brought it home and plugged it in), then the default configuration will be active and you could find the default password in the documentation, either printed or online.
In any case, you could get better answers if you said what brand and model of router you are using.
Maybe your router came from your ISP (telephone or cable company) and they configured it. In this case, you could call their tech support line and ask for the password.
Sep 08, 2014 | Computers & Internet
I forgot admin password
To reset the SWS (SyncThru Web Service) password:
  1. Press the Menu button.
  2. Press the right or left arrow until Network appears, then press OK.
  3. Press the right or left arrow until Clear Settings appears, then press OK.
  4. Select Yes and press OK.
  5. After the printer finishes clearing the network settings, unplug it for a few seconds then plug it in again.
  6. All network settings (including the SWS password) will be reset. If you had manually configured IP info or were connected to a wireless network, you will need to re-enter those settings now.
  7. The login will default back to admin and the password will be sec00000.
Note: If you did not change your password or this is your first time trying to use the SyncThru service, the default SyncThru user/password is admin/sec00000.
Dec 17, 2012 | Samsung SCX-6345N Printer
Trying to conect printer to web
The wep number is the security password for your wireless network, if your internet access is through a wireless access point access point then the wep key is usually found in the setup page of the router/access point.
I hope this helpsRegardsGrant
Nov 13, 2011 | Office Equipment & Supplies
Cant connect wireless dont know network key (password)
you can find this network key or password or wep key, inside your modem configuration page. to do this.
1.use a pc that is conected to the modem
2. goto start then run and type cmd press enter.
3. type ipconfig and press enter.
4. the defualt gateway is like 192.168.2.1 or some thing like this. enter this into internet exploere or firefox adress bar and press enter.
5 you should be inside your routers configuration pages.
6 navagate till you find the wireless security settings.
7. look for wireless wep key.
this is what you need ot enter into your printer to conect to wireless network.
Nov 30, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Conecting a laptop to a c250
if you connect directly, then you have to use crossover cable. or if you just want to print, use USB cable.
Apr 23, 2008 | Konica Minolta bizhub C250 All-In-One...
How do I reset access password?
Thanks. I actually found out that it had never been configured - here is the standard factory access info: All Oki network printing devices support configuration changes via a standard web browser such as Internet Explorer or Netscape Navigator. When applying a configuration change to a device the user is prompted for a user name and password. The following details should be entered: User Name: root Password: last six digits of the MAC address* *You can find the MAC address on the network summary web page or by printing off a menu from the printer.
Nov 22, 2006 | Okilan 8100e Print Server
1,760 people viewed this question
jasbo
jasbo
