Question about Pool & Spa
My heater has not been used since last summer, i found the board to have corroision, i replaced but the unit would not kick on, no fan ,nothing.am i missing a step?
  • 8,404 Answers
Please check all the connections to all boards, switches etc. I am particularly interested in the water pressure switch ... can you verify it works with your volt/ohm meter?
Posted on May 09, 2010
Elco fireplace blower wont work
If your blower/fan blows air into a "box" with tubes that conduct heated air out through the screen, that assembly may have failed. I had one that burned out and had to be replaced.
Dec 03, 2013 | Leisure HOMEPRIDE Electric Fireplace...
Inside blower wont run
Sounds like you need a new board. Their are people out there that will replace the fan relay on these boards, but I have always just replaced the whole board with a new one. These boards can range from around $50 to $300 depending on which board it is. The way we always double check these boards are exactly the same way you have done it, only we use the 120v from the units transformer and bypass the board, if your fan comes on, your board is not sending the power through to the terminals. It would be different if nothing else on your system was working too. I hope this helps and good luck!
Jul 01, 2012 | Ruud Rheem Honeywell Fan Control Board...
Gmp 100-3 fan runs even when tstat is set to off an fan setting to auto. unit ran fine all summer in cool mode and was off for the last couple weeks. just notice the fan was on yeaterday. ran unit in...
Hello, one way to check is remove the green wire from the G termimal on the circuit board in the Furnace, if tn
His turns it off it may be a short in the tstat wiring or bad thermostat, if it does not turn it off the relay on tne control board is stuck and tne entire board must be replaced.
Sep 28, 2011 | Goodman GMS90703BXA Heater
Central Air unit fan inconsistent operation. Will run fine for hours or days then not kick on when called for resulting in icing of cold air exchange. Capacitor was replaced last summer, and flipping...
Those symptoms sound like a contactor - ralay not closing properly or the capacitor. In most situations, I would recommend they both be replaced, since it seems they fail close to each other.
Jul 26, 2011 | Heating & Cooling
I have a goodman gms9 gas fired furnace that does nothig.no led light,fans or anything.there is power to the unit and was working when shut down for the summer.
Look on the circuit board for a small fuse. Replace if necessary. take a small piece of wire and with the door safety switch taped down, jump out R and W terminals on circuit board. Unit should power up. You can also jump out R and G terminals and room air blower should turn on. If nothing, replace circuit board.
Nov 23, 2010 | Goodman GMS90703BXA Heater
Unit lights up and hums but does not blow air
mcdevito75 here, Sounds like the fan motor is haging up or needs to be replaced, try the switch on/off then on/off a few times see if the fan kicks on, if not see your local a/c repair shop, they come to the house.
Jun 22, 2010 | Whirlpool ACQ158XP Wall/Window Air...
Induction Motor continues to run.
pull the rubber hose off the pressure switch. and blow into the Induced draft motor housing if you cant you can pull the hose off the IDM and try to clear it with a small paper clip. reconnect and try again. you can also get the flash code off the board while the unit is running but not working.
Dec 11, 2008 | Goodman GMS90703BXA Heater
1998 Rockwood Tent Trailer
check connections -test and check ignition ,gas valve ,thermocouple for proper placement ,dirty or damaged
May 03, 2017 | Heating & Cooling
Pool & Spa Logo
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
