Question about Belkin (F5D5231-4) Router
Wireless connection hello, my comp is hard wire connected to wireless G router. other comp is not connecting via usb wireless because the vista is not accepting it and not conneting....
    Problem Solver:
  • 7 Answers
Your wireless set up for super G ? So i think the first problem is configuration e standard mode for wireless. Set up only 54 g.
Second search for your factory wireless usb new driver for windows vista.
Good Luck.
Posted on Mar 28, 2008
SOURCE:
I just bought and set up a LaCie Wireless Space 1TB as a NAS + router but can't get several computers to connect wirelessly to it. I did get one HP laptop running windows XP to connect just fine. But I...
Is this your first router or you are replacing an existing one with this? If you had a router setup before don't name the wireless network the exact same as your old one unless you go into your wireless properties on all your wireless machines and delete saved profiles.
What kind of security are you using on the wifi? wep, wpa wpa2? If you are using wpa2 and have not updated all your computers to the latest service packs for windows you can have some issues as well. Some routers don't work well with ps3's, try setting the router security to wep and make a ten digit password.
Also the Dell XPS M1530's are known for bad performing wireless cards. You may be able to obtain an updated bios firmware from Dell's website to help fix this though i'm sure it's not the cause of why you can't connect to this router.
See if this helps, if not respond and I will give some more tips.
Chris
Aug 24, 2011 | Computers & Internet
I'm using a Netgear WGR614 router that is working fine to connect to the internet via Comcast only when I'm hard wired. However, I'm not able to connect wirelessly. I can see the available network, I have...
I am guessing you are using a new computer with windows 7?
I find the router works great with PC's running XP or vista; only my new w7 doesn't connect either!!!
Jan 02, 2011 | NetGear WGR614 Wireless Router
Just installed Win-7 router driver is missing I think My router is not detected checked all connection all are ok
1 Try running the software in Vista mode.
2. Go to the manufactures web site and check for firmware updates for the router.
3. the router should connect without upgrade when hard wired via the Ethernet cord.
4. you didn't designate if you are truing to connect wirelessly or via the RJ45 cord.
Apr 27, 2010 | Belkin F5D7234-4 Router
Cant connect old comp to new router
go to > control panel >network connections > in left hand pane.under Network Tasks..click..Create A New Connection... that will start a wizard and will guide you thru the process. you will also need to install the drivers as well for his computer to be able to use the modem/router.
i hope this has helped
Sep 09, 2009 | HP Pavilion a330n (Refurbished)...
Belkin wireless G router and MicroNet Realtek RTL8187B USB
I got the answers (for free) from Belkin's excellent technical support.
Many thanks.
Jun 18, 2009 | Belkin (F5D7230-4) Router (587009)
Can't connect DSi with same security as comps
hello, yes i had the same problem, but i had it with many other computers, the way i solved it was going into the router settings and click the "restore default settings" then turned the router off for 15 seconds (for a fresh reboot) then when i had to set everything up again i got all my computers on the router and im able to add more without running into that same problem once again, or for a simpler solution try disconnecting the wireless on the computers and replugging them in.... that works sometimes as well
May 01, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Cannot connect lap top or printer wireless and also connect to the internet via AT&T motorola modem
yes. Here is Linksys' page on how to:
http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=3687
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Apr 12, 2009 | Linksys Wireless-G WRT54G Router
Wireless
Make sure the Vista driver for your wireless G USB adapter is installed. If not, you can download it from the manufacturer's website
Mar 27, 2008 | Belkin (F5D7230-4) Router (587009)
Vista OS can't connect wireless to Dlink DI-614+ rounter
yes it does but what exactly is this it's your comp that's not connecting to your wireless network..so here try these steps...
first click start>click in start search>in that box type in services>it gives you an option of services on the same start menu at the top click on that...
it will take you to a new screen that says services at the top on that screen you need to scroll down at the bottom and look for wlan auto configuration rt click on it and click start if start is greyed out press restart....
close services down..
click start>click connect to form the start menu> and check it gives your network name in there .if it says anything like no network found in range. pls make sure that wireless switch on your laptop is turned on...
if still you're not able to connectr it's a concern with the drivers of wireless adapter on your comp genrally on new comps its quite common get the drivers reinstalled....
Feb 18, 2008 | D-Link AirPlus DI-614+ Wireless Router
Can not connect to router via a wireless connection.
You could try to manually set your IP address in the TCP/IP, the gateway and your ISP DNS
Jan 23, 2008 | D-Link DI-624 Air Plus XtremeG Wireless...
Belkin (F5D5231-4) Router Logo
51 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
