Question about Maytag Dryers
My dryer still heats, but the drum doesn't move. Is this going to be a costly repair, the dryer is about 20 years old and this is the first problem I'm ever had with it.
  • 1,476 Answers
If you got 20 years out of your unit I would definitely keep it! You need a new drum belt. You can get it at http://www.repairclinic.com . They also have videos which show how to install the part. Let me know if you need more help. Thanks for using FixYa and for the generous rating.
hardrocko
Posted on May 09, 2010
Drum not turning. There is heat. Opened machine found broken belt. Drum will not turn by hand. What would it cost to fix?
in the package of the new belt, the belt for the dryer the instructions are right on or in the package, if not normally you take the front and possibly the top of the dryer 1st.... off slide the belt over the drum, and the insert it through the tensioner and then unto the motor. you have to make sure the belt has tension on it this will show it will be able to move the drum.... you can download maintenance manual form here
http://www.slideshare.net/avermapub/miele-gas-dryer-t9820-service-manual
price depends where you purchase it.. $ 20 to $ 45
Sep 25, 2014 | Miele T9800 Electric Dryer
What's your problem?Squealing Speed Queen dryer
The drum of the dryer has a belt that turns the drum while in operation. These belts are not hard to replace and if your old belt is still attached you can visually see how it is positioned on the drum. However, there are also at least three rollers that carry the drum allowing it to rotate as it is being turned by the belt. These rollers are also not that expensive and are relatively easy to replace. Since the machine is 20 years old you may experience some problems finding the parts (maybe not)> You can check with the company via the internet and find out. Just give them the model number and a description of the part. The pulley that is attached to the shaft of the motor that drives the belt that turns the drum could also be worn out. Replacing the pulley on a machine that old can be trying but not impossible. If you have a technician check out and make repairs on these potential problems it probably cost well over $180 but if you have any mechanical ability you can probably do the job yourself if you can locate the parts. Just make sure the machine is unplugged from an electrical source before removing the back and the rest is just work.
Dec 12, 2011 | Speed Queen Dryers
We have an older dryer (ultimate care - super plus capacity) 12+ years old. It no longer "heats". Drum is still turning. I am assuming it is a thermostat - how much do those cost to repair?...
When it doesn't heat it could range from the timer to the heat element to the thermostat or even the motor so it could be as little as $125-350 to repair.
Aug 12, 2011 | Whirlpool Dryers
The drum in my Kenmore gas dryer (over 20 years old) will not spin around. There is still heat, but clothes will not spin around. Does the belt need to be replaced or should I get a new dryer altogether?...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Apr 18, 2011 | Kenmore Dryers
Kenmore electric dryer, power on, drum doesn't turn. Help? can I fix this myself or do I have to call out for repairs. About how much will this cost, or should I replace, it's about 12 years old. Thankx
check the belt that goes around the drum and the idler and motor pulley. if it is broken replace it. when installing the ribs on the belt go down against the drum. a new belt is somewhere between $10-$20. you can do this easily yourself.
Oct 11, 2009 | Kenmore Dryers
Gas Dryer won't produce heat
Hi, thanks for the inquiry.
It's most likely a thermal fuse. Basically, the voltage has to go through the fuse before it goes to the ignitor.
It should only cost you about $90 to repair if a technician comes out to fix a fuse.
I wouldn't try to repair it unless you have some knowledge of electrics. If your dryer is less than 12 years old, I would recommend you fix it. Hope this helps.
Best of luck :)
Aug 25, 2009 | Whirlpool Dryers
Hello my dryer is only 3 years old. Last night it stopped drying. The drum will turn and the light comes on. It is an electric dryer. What might be the problem. Thanks.
Have you tried a different cycle? The thermostat that controls heat has failed. There are more than one for the different heat settings. Try a different setting, then go from there.
Jul 01, 2009 | Dryers
Changing gas whirlpool dryer heating ailment
Before you do that try this pull the unit out from the wall remove the venting from the back run a load and let the hot air go intop the house if it drys fine you have a plugged vent going to the outside and it will need to be cleaned out (This is the most common problem for long dry time)
Apr 13, 2008 | Whirlpool LER5636P Electric Dryer
Dryers Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
