Question about Nintendo Wii Console
Was having trouble with the wii remotes needing to be reset and struggling with that now wii will not turn on at all
  • 33 Answers
Well that is a console error if its still under warrenty or you don't want to take it apart send it to nintendo but if not take it apart clean the board will electronic surface cleaner of if it looks burnt sodering will be required.
Posted on May 09, 2010
Just changed the batteries in the remotes.and getting no signal when pointing at the screen to play games
sir think your remote is not working properly... you better try to reset your remote for your nintendo wii console... this is how you can reset your remote...
  1. How to Reset Your Wii Remote
    • 1 First you will need to check a few things, just to make sure what the actual problem is.
      *Check to see that all cords are properly plugged in.
      *Make sure the sensor bar is properly center above or below your tv set.
      *Make sure that nothing is blocking the signal to the sensor bar.
      *Make sure that the batteries in the remote are in good working order.
      *Make sure that there are no wireless devices close by that might be interfering with the signal.
    • 2 If after all this the remote is still not working then it probably needs to be re-synced.
    • 3 Turn off and unplug your wii console for a few minutes.
    • 4 *Turn the power back on and when you see the the safety screen open the small flap on the front of the wii console. Inside you will find the red sync button. Press and hold the red button down for 15 seconds.
      * Then remove the battery cover from the wii remote, inside you will see another red button.
      * Press and release the red button, the blue lights on the remote will start blinking.
      * Quickly press and release the red sync button on the wii console.
      * The remote will stop blinking and it should now be synced.
or visit the links below
Read more: How to Reset Your Wii Remote ' eHow.com http://www.ehow.com/how_4527749_reset-wii-remote.html#ixzz1OyHyruvP
if you think this help you please rate me by that it will help me to... thank you in advance...
Jun 11, 2011 | Nintendo Wii Console
Tip
How to snychronize a Wii Remote to the Wii console
A lot of people have trouble synchronizing their Wii Remotes to their Wii console. I have written a short tutorial on how to do this.<br /><br />Figure out which scenario is similar to yours and proceed with the solution-<br /><br />1) When you turn on the Wii console and press any button on the remote no lights light up at all. This is because the remote is dead, you must replace the batteries in the battery compartment on the underside of the remote. If the controller is using a charge pack you need to put the controller on its charger.<br /><br />2) When you turn on the Wii console and press a button on the controller all four lights blink a couple times then turn off. This means the controller is not synchronized. If your controller has ever been previously synchronized all you need to do is press the 1 and 2 buttons at the same time and it will sync up.<br /><br />3) If option 2 doesn't work then this means you are preforming a first time synchronization with the remote. While the Wii console is turned on you should open the little compartment that is just below the disc tray. Then you should press the little red button. After pressing the red button you should open your Wii Remotes battery compartment, remove the batteries and press a similar little red button inside of the compartment. Put the batteries back into the controller and the controller should be synchronized! <br /><br />If none of these solutions are working then the problem is a technical issue with either the Wii remote or the Wii system, you should contact technical support for more information.<br /><br />I hope this helped with the synchronization of Wii Remotes!<br />
on May 16, 2011 | Nintendo Wiimote & Nunchuk Controller...
My Wii remote wont work how do i reset it?
The Wii turns on but the remote won't connect to the screen...all lights working also, bought a new sensor bar and still nothing...???
Turn on the Wii console, when at the home screen press any button on the wii remote, if the lights on the wii remote remain dark then it needs new batteries.
If the lights all light up at the same time then stop this means you are not synced. Press the 1 and 2 buttons at the same time to sync, this will work if they have been synced before.
If your four lights still blink blue then you need to open the little compartment on the console that is right below the disc tray. Inside is a little red button, press the button. Now open your battery compartment on the wii remote and take out the battery, then press the red button inside. Put the battery back in and the controller should sync up. If you are still having trouble you will need to contact Nintenedo Technical Support.
Hope this helped!
May 16, 2011 | Nintendo Wii Console
Made a loud noise and then wouldn't turn on t.v.
you need to reset the configuration and it also happens when the systems been on for a long time unplug the main power supply for 30 mins and try again. hope this helps and also try and clean the disk and let them dry.
Dec 31, 2009 | Nintendo Wii Console
I am having trouble turning to the right, left
go into settings in wii menu look for remote settings and change it there it could also be your not in right place for sensor bar
Aug 18, 2009 | Nintendo Mario Brother Kart Remote Control...
Problems with a Wii game
if you are in the mulitplayer mode and still have trouble adding the remote then try syncing the remote with the wii first by pressing the home button then go into the wii remote settings on the bottom then re-sync each control. Then try going back into mulitplayer mode and try again or while the screen is on when you want to add more players press the '+' button.
Dec 28, 2008 | Video Game Consoles & Games
Remote Issue
small chance of it being broken probaly battery probloms had the same problem for three days
Dec 28, 2008 | Nintendo Wii Console
Wii turns on but has no picture or sound
You could try resetting it by taking out the motherboard battery.
It is on the bottom at the back under a plastic cover.
You may need a tri wing screwdriver to remove the cover.
Try taking this out for a couple of hours and it will reset it.
Hope this helps,
Mowcius
Jul 04, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
54 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
