The rca model r56wh76 had bad flyback which i ordered and installed.the power lite blinks a few times and thats it.no sound or anythink.like its dead.
  • 8,617 Answers
That model uses the 270125 flyback which hardly ever fails. It sounds like CP150, CP120 or CP114 is bad instaed. They are all located on the deflection board ( Where the Flyback is also)
Posted on May 11, 2010
  • J & S REPAIR Sep 24, 2014
    Why Was The Flyback Changed,If So Check The Horiz Output Transistor, It Might Be Shorted..
RCA R56WH78 Green LED Blinking
Ck 3 capacitors on deflection board cp150 2200uf 16v use 25v if it is puffed up on top it is Bad other 2 are 220uf 35v cp114 cp120 resolder all pinns on FBT flyback transfomer.
Nov 12, 2009 | RCA R56WH76 Projection Television
R56WH78 RCA TV FlyBack
Resolder all the pinns on the FBT chances are FBT is Bad they go out alot Call UED for Parts 1-800-648-6657
Oct 19, 2009 | RCA R56WH76 Projection Television
RCA R56WH78 No sound or video
there are 3 fuses by the flyback,check them.also look for bad connections under flyback-also check for a bad connection on the crytical safety cap.if all else fails deflection board part number is 272074,NTA thru rca but tristate module or pts electronics can repair it for you.
Sep 24, 2009 | RCA R56WH76 Projection Television
R56WH76 Failed Convergence Fix
OK on same circuit board as fuse up on the front part of board look at capacitor cp150 if it is swollen or puffed up it is bad 2200uf 16v use 25v and replace 2 other capacitors in same area cp114 cp120 220uf 35v.
D52W14 power button blinks 3 times
Yes make sure you get correct flyback,call UED 1-800-648-6657 see if they have part; also are you sure that is what is wrong?Check capacitor cp150 2200uf 16 v see if it is ok or if it is bad this cap if bad will keep set from coming on,and if it is bad there is 2 other capacitors that need to be replaced also.
Dec 13, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
D52w20 dead set
Thats the error code indicating that the flyback is bad. You can get a new replacement for about 50 bucks at the following link and they provide free shipping and free online instant messageing to explain how to change itIts actually a very easy and common repair for your model. You need flyback 259296.
heres the link.
http://servicemanuals.vstore.ca/
Jul 16, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
HAVE HD52W59 RCA 52" HD TV . I press power button to turn on the tv and it blinks a couple of times and thats it . Nothing after that . No picture or sound.
If it blinks 3 times when you press power then shuts off you need to replace the flyback. Very easy an inespensive repair/. You can get the replacement flyback for under 50.00 at the following link and they provide free tech support to help you install it by online instant messageing. You need flyback number 259296
Heres the link
Jun 30, 2008 | RCA Televison & Video
TELEVISON WILL NOT COME ON
sounds like the flyback is bad thats what a 3 blink code means . Its an easy fix you can get a new flyback at the following link and they will give free tech support to help you install it. You need flyback 259296 for your model. Heres the link.
Jun 16, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv repair
HV splitter and flyback are common failure items. Remove the HV lead from the HV splitter that comes from the flyback, Place that into a dry glass jar secured so it doesnt come out. Then try powering up the set if the set powers up without shutting down the splitter is bad.
Mar 14, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
R56WH76 rca
Sounds like the flyback transformer has a hole burned in the side
Nov 17, 2007 | RCA R56WH76 Projection Television
Televison & Video Logo
101 people viewed this question
Top Televison & Video Experts
