Question about Microsoft Xbox Console
My xbox will not turn on - Microsoft Xbox Console
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 66 Answers
Make sure all the cords are plugged in tight and if that dosnt work take off the front and make sure all the wires are tight and in the right spot and make surre the poer button to the inside is lined up with the power button on the inside.
Posted on May 09, 2010
Why does it keep shutting down after 5 min of playing a game?
Xbox Keeps Turning Off - Xbox 360 S - iFixit
https://www.ifixit.com/Answers/View/.../Xbox+Keeps+Turning+Off
iFixitI put up with it turning off of a couple of weeks and then the power cord blew up ... The slim edition of the classic Xbox 360 with a 250GB HDD and built-in Wi-Fi. ... After your description, I am starting to think that your power brick is the problem. .... in i cant donothing about if i was trying to play my gta4 in keep cutting off in 1 ...
Does Your Xbox 360 Keep Freezing? ' MyGamerXP
www.mygamerxp.com/xbox/does-your-xbox-360-keep-freezing/
Sep 14, 2015 - 5. Check Your Xbox 360 Hard Drive. Not only can the cache corrupt from .... I unplugged the console when it froze instead of turning the power off. ... hi my 360 keeps on freezing on any game i play and like the screen frezzes but .... It willnot, even after 6 goes, play, it freezes, and after about 2 mins, it ejects.
My 250GB Slim keeps turning itself off every 5 - 10 minutes ...
forums.xbox.com/xbox_support/f/7/t/156970.aspx
Xbox
Jan 17, 2016 | Video Game Consoles & Games
When I try to save on my 60gb hard drive it can't save.
This sounds like the hard drive is either permanently damaged or is not seated correctly in the Xbox. Please try the following to see if we can fix your problem.
1. Turn the Xbox off.
2. Remove the hard drive.
3. Turn the Xbox on.
4. Turn the Xbox off
5. Refit the hard drive.
6. Turn the Xbox back on.
See if this fixes it. If it does not then you may need to use the Xbox own format utility to try and recover the drive. If this does not work then it looks like your hard drive may need replacing.
Hope this helps
Dec 12, 2010 | Microsoft Xbox 360 Console
I dont know how to set up my xbox live with an eathernet cable can you help?
Hi there
Turn off the Xbox 360 by pressing the power button on the front of the console. Afterward, shut off your modem by unplugging its power cord.
  • 2 Insert one end of the Ethernet cable into the Ethernet port located at the back of your Xbox 360 console. After that, insert the other end of the cable into your modem.
  • 3 Replug the power cord into your modem to turn it back on. Once it is active, press the power button on your Xbox 360 to turn it on.
  • 4 Navigate to "My Xbox" then "System Settings." Afterwards, select "Network Settings" then "Test Xbox LIVE Connection." You will be notified on-screen if the connection is successful.
  • Read more: How to Set Up Xbox LIVE with an Ethernet Cable | eHow.com http://www.ehow.com/how_6714462_set-xbox-live-ethernet-cable.html#ixzz0xBK8Zctz
    GOODLUCK!!
    Aug 20, 2010 | Microsoft Xbox 360 Console
    How do you turn on an xbox 360?
    Simply press the big button that has green lights around in front of your console
    Apr 21, 2010 | Microsoft Xbox 360 Console
    Xbox 360 q1 and q2 lights going red
    i dont now because my xbox 360 do the same thang
    How to setup two wireless controlers to an xbox
    1. Press and hold the Xbox Guide button until the controller turns on. The Xbox Guide button is the round button with the green "X" near the center of the controller.
    2. Make sure that your Xbox 360 console is turned on. If your Xbox 360 console is not turned on, press the power button. The power button is the large round button on your Xbox 360 console.
    3. On the Xbox 360 console, press and release the Connect button. The Connect button is the small round button on the Xbox 360 console.
    4. On the controller, press and release the Connect button. The Connect button is the small button on the front edge of the controller, between the left bumper button and the charging port.
    5. After the Ring of Light spins and flashes one time on the controller and on the console, the controller is connected. The quadrant on the Ring of Light that remains lit indicates the position in which the controller is connected.
    6. Note If you want help connecting an Xbox 360 Wireless Controller to your Xbox 360 console, you can contact Xbox Customer Support. For more information about how to contact Xbox Customer Support, please visit the Xbox Support (http://www.xbox.com/support/) Web site.
    • The controller remains connected to the Xbox console even when you turn off the Xbox console.
    • The controller is connected to only one Xbox console at a time. You can connect the controller to a different Xbox console at any time, but your connection to the previously connected console is lost. You must repeat these steps to reconnect the controller to the original console after your connection to the console is lost.
    • The controller works within 33 feet (10 meters) of your Xbox 360 console. However, objects between the controller and the console may reduce this range.
    • If the controller does not turn on, the batteries may have to be replaced.
    Mar 22, 2010 | Microsoft Xbox 360 Console
    Why wont my xbox controller connect to my xbox
    You cant just Turn it on by the middle button you have to hold the middle button and the start button at the same time for 3seconds then it will turn on.
    Mar 16, 2010 | Microsoft Xbox 360 Controller
    Xbox 360
    This problem occurs when the Xbox 360 console experiences a general hardware failure.
    You can submit a console-repair request online at Xbox.com. However, before you submit your request, first try the following steps to verify the problem:
    1. Turn the console off and on. To do this, follow these steps:
      1. Turn off the console.
      2. Disconnect all the cables.
      3. Reconnect all the cables.
      4. Turn the console back on.
    2. Turn the console off and on without accessories. To do this, follow these steps:
      2. Disconnect any accessories that are connected. For example, disconnect all Xbox 360 controllers, all Xbox 360 Memory Units, and the Xbox 360 Hard Drive.
      3. When the accessories are disconnected, restart the console to determine whether the console or an accessory is experiencing the problem.
    If it does not work go here
    http://support.xbox.com/support/en/us/nxe/LiveIDSignIn.aspx?redirectUrl=http://support.xbox.com/support/en/us/nxe/registerdevice.aspx?step=repair
    May 22, 2009 | Microsoft Xbox 360 Console
    Sysem error E73 on Xbox 360
    Follow the steps below, Hope this helps
    1. Turn off the xbox 360, disconnect the cables wait for 20 seconds reconnect the cables and turn it back on.
    2. Remove the hard drive, turn on your xbox 360 without the hard drive.
    3. Re attach the hard drive and turn on your xbox 360
    4. If the steps wont resolve the issue, your console needs to be serviced. Contact Xbox Customer Support to check the warranty status of your xbox 360.. Good Luck!
    Mar 31, 2009 | Microsoft Xbox 360 Console
    My xbox 360 power cord box messed up....
    check your Audio/Video cable connection, sometimes those lights means that the plug isn't in the xbox/tv all the way
    Jan 06, 2008 | Microsoft Xbox 360 Console
    Microsoft Xbox Console Logo
    21 people viewed this question
    Top Microsoft Video Game Consoles & Games Experts
    marley mcelhinney
    Tre Elkins
    Martin Murray
    Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
