Question about E Sky Flight Simulator Training Kit
Have the new belt cp 1 and constant enthusiasm in the left side can not hardly worth poletiti immediately fall by ELISA and Gance new
  • 15,935 Answers
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Aug 17, 2010
Turntable belt keeps falling off.
Hello, How old is the belt? It is possible that you might need a new belt. Just like a rubberband, it can stretch and with age, it starts losing it's elasticity. If that's the case, then the belt would fall off.
I would check with the manufacture to see if they have replacement belts. They can't be that expensive and it would be worth a try.
Hope this helps.
Best wishes.
Mac =)
Mar 12, 2014 | Crosley CR248 Turntable
"check gauges" ligh comes on.
i have 08 , and full docs. 06 is pre 07 major changes.
when alternator quiets(i didnt say bad, even the belt can slip or fall off?
the battery is weak, 12.6vdc rested is charged, yours is not charged
and running its 13.4 to 15vdc if not.then its one of these.
check all fuses first.
1: bad battery. (one cooked cell and curtains.)
2: bad wiring to altnerator (or it's fuse,.hint?)
3: bad alternator.
4: bad PCM (i think reg is in the PCM. alldata.com, look)
the regulator is designed to not attempt to charge a damaged battery.
this is so the voltage does not spike and blow up $5000 worth of electronics, (new not , wrecker parts prices)
did you fail to scan it, the PCM will report vast numbers of errors. on this . scan the PCM.
see those errors. (bet battery low, and more)
no engine stated, and that is KEY on call cars.
some have different PCM and charge paths. fact.
Feb 21, 2014 | 2006 Jeep Wrangler
Nordictrack commercial 1600 treadmill drive belt keeps slipping off the front roller.
Hi Brent,
I do suggest ringing Icon Fitness and let them organize a tech to look at the machine.
Dec 12, 2013 | Nordic Track Exercise & Fitness
Belt falls off
see the next steps and fix it. God bless you
Drive Belt
Remove the screws or bolts securing the ends of the pedals to the crank axles. Slide the ends of the pedals off the axles. Remove any screws or bolts securing the left and right disc shields to the base unit. Pull or pry the disc shields off the base unit and set them aside.
Remove any screws or bolts securing the left and right side shields to the base unit. Detach the side shields and set them aside. Examine the interior of the base unit and locate the drive belt.
Pull the drive belt free of the crank pulley, flywheel and any other pulleys. Discard the old drive belt and install a new belt in its place. Turn the crank axles by hand to confirm that the belt will turn smoothly when the device is in use.
Dec 18, 2012 | Schwinn 150 Upright Bike
Had tensioner pulley and serpentine belt replaced on my 2002 Ford Escort ZX2,, NOW BELT KEEPS WANTING TO FALL OFF ?
had the same problem with my newyorker u need to get a cover that sits on the bottom tensioner and the side one they are a little hard to get on but it's worth it I haven't had a problem since
May 23, 2012 | Cars & Trucks
New feed belt will not track evenly. Belt is loose on left side & tight on right, but if I tighten the left side to pull it flat, it tracks off to the right immediately. I tried reversing the belt in...
Could be the belt, sometimes they get glued together wrong and they don't track, or its the tension wheel/ track wheel.
It looks like one of the stationary rollers might have a small adjustment
that you can do, hard to tell looking at the diagram,
but if you can adjust this tighter on the right side it should track the belt back to the left, so check and see if any of the rollers or holder of the rollers can be loosened and moved a hair to get the track to the left so the adjust track can make it track straight.
If you still have the old belt, put it on, if it works then there is a problem with the new one and it is not the machine.
Feb 12, 2010 | Delta 31 - 255X X5 18'' x 36'' Drum Sander
How to align new belt, the belt works to one side when it is turned on
Hi Michelle,
Typically, you'll need a 3/16" allen wrench or a similar size allen wrench, you may have been provided one with your machine.
1. unfold your unit (as applicable)
2. at the end that you just laid down, there's typically two allen screws, one on each side of the belt
3. Turn your treadmill on, 3 rpm or so.
4. Adjust the allen screws and watch the belt track one way or the other.
for instance, if you tighten the right side screw (turning it CW) this will pull the roller closer to you, tighting the belt on the right, this should make the belt move to the left - since it is NOT as tight.
5. adjust the left side the same way if you want the belt to go right
6. if you need to tighten the belt, alternate both screws CW until the belt is tight.
7. conversely, turn the screws CCW if you need to loosen the belt.
Added note: be sure to use some belt lubricant as directed by your user's manual, to prolong your treadmills life. Belts run about $100 and most people will throw their treadmill out, before spending that kind of cash on it. so,..it's worth the $10 to buy the lubricant!
Enjoy! and I hope you stick with it!
Bry
Jan 26, 2010 | Exercise & Fitness
Hi there I am trying to replace a belt on my old dryer how hard is it
If you have a NVL333EY which you posted under, I'd rate the repair a 4 on a scale of 1 - 10 in difficulty. That Hotpoint model is actually manufactured by Frigidaire / Electrolux and sold through GE as a Hotpoint. (Hey, it's a global economy, right?)
Disconnect power to the dryer. Use a putty knife to push in the seem of the front panel with the dryer top to release the dryer top, allowing it to swing back. You may be able to use a phillips to remove the screws holding the front panel, but a #2 square drive works much better. Slip new
134503600 belt around drum from front. Put front panel back on. Remove 4 screws (again the #2 square drive works best) holding the back access panel at lower left back side to allow you to finish belt installation. Belt grooves touch the drum. The worst part is keeping the spring from falling off when you put the belt tensioning wheel on. After you have the belt installed, give the drum a turn by hand to make sure everything is OK before you close up the top and reconnect power.
Dec 07, 2008 | Hotpoint NVL333EY Electric Dryer
New belt
First put the belt around the small pulley, shd be the motor pulley i think. Then ease the belt around the big pulley & gently move clockwise if the pulley is on the left side; anti clockwise if you are inserting on the right side. The belt will fall into place. Actually it is very simple.
Apr 18, 2007 | Maytag SAV4655A Top Load Washer
E Sky Flight Simulator Training Kit Logo
53 people viewed this question
Top E Sky Toys Experts
ray gallant
Are you an E Sky Toy Expert? Answer questions, earn points and help others
