Question about Jenn-Air JGW8130DD Gas Single Oven
Can't release door after cleaning
Oven cold, door locked, fan won't turn off. Model SVD48600
    President:
  • 949 Answers
Sorry you are having trouble, unfortunately this is not an easy one to fix.
If the oven is cold then the sensor is telling the control it that oven is still hot or the control is stuck in the hot position.
There is not an easy way to unlock the oven without pulling the unit out and taking the top off to get to the latch.
I have attached a link to the service manual if you wish to attempt it.
If not I would suggest turning off the circuit breaker to the oven and letting it sit overnight. See if that will reset the issue, if not you will have a big job ahead of you or a costly repair.
Sorry I do not have good news for you on this one.
maytag_library/docs/16010191.pdf
Posted on May 09, 2010
Scholtes FE46 and the door is locked. Also no clock/timer lights. Temp/function and oven work but is locked even though completely cold.
Here are a couple of things to try:
  1. Unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door.
  2. Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever (is so equipped) or opening the door.
Read through the following for mire info:
Appliance411 FAQ After self clean range oven door won open
Mar 25, 2016 | Ovens
Self cleaning lock handle does not unlock
Unplug power, wait one hower and plug cord back.
That should reset the oven, if it does not, the oven timer control is clearly defective and should be replaced , you find parts here.
Oct 08, 2008 | Thermador Ovens
Self clean door lock will not release
what model do u have can u try to push relly hard the lever ove rto right again
Jan 21, 2008 | Viking 30" Professional Select Built-in...
Locked after self clean cycle
you may have a bad door lock . in this case replace. but first reinstall the door and run a new clean cycle and see if it unlocks .. mm
Jul 14, 2010 | GE JKP45 Electric Double Oven
Model SVD48600 door won't open after clean cycle. Fan also locked on. Powered off overnight; no change: "Locked" still displayed
That is a very complicated unit for the average handyman. It has electronic controls and a relay board, sensors and a locking mechanism. First thing I would check is the locking mechanism and the switch on it. Do this first and let me know if you find one of the switches defective or shorted. While there, check the light switch which is bi-functional being used for the light and also to tell the ERC the door is opened or closed.
Jenn-Air self-cleaning ovens have a special setting that allows you to clean the oven without chemicals or scrubbing. The oven heats to a temperature higher than used for cooking. The intense heat burns food spills and other residue off oven's inner surfaces.
Instructions
1. Remove the broiler pan and any utensils to prevent them from being damaged. Take out the oven racks, since the high heat might discolor them.
2. Wet a cleaning cloth or sponge with hot water and detergent. Wash off splatters or spills from areas that won't be affected by the cleaning process, including the oven door liner and the oven's front frame. Wipe up any excess grease or spills on the oven floor.
3. Close the oven door and press the "clean" pad on the unit's touch pad.
4. Enter the amount of cleaning time. For example, two hours is appropriate for a lightly soiled oven, three for average and four for heavily soiled. Cleaning should start immediately. The oven will remain locked during the cycle.
5. To delay cleaning, hit the "stop time" pad and enter the desired stop time. For example, if it is 9 p.m. and you want the oven to clean for three hours starting at 10 p.m., key in the numbers 1,0,0.
6. While the cleaning function operates, use the scouring pads to wash the oven racks and other utensils. Once the cycle ends and the oven unlocks and cools, you can use a damp cloth to pick up any loose or burnt debris inside. Replace the racks, broiler pan and utensils.
Tell us news.
May 09, 2010 | Jenn-Air JGW8130DD Gas Single Oven
Cleaned oven and now the fan will not quit and door is still locked has been over 2 1/2 hours since cleaning over.
the timer in the control panel is still regeristing heat! and when the sensor weakens with age it keeps the circuit closed till all heat is gone in the oven area~ to get the door open? unplug the oven or trun off the pwoer to it!! for 15 minutes then turn it back on and it will release you just need to replace the oven heat range sensor for the self cleaning cycle
Jan 23, 2010 | Ovens
The lock on self cleaning oven door will not release
Once the cleaning button on the oven is pressed it take 15 minutes for the uven door to unlock.
Jul 30, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Oven Door Locked After Cleaning
Go to electric panel. Turn off the oven breaker, open door, now turn breaker back on.
Jan 16, 2009 | Ovens
Kenmore door locked
Try pushing and holding the door shut. Then moderately tap on the door where the latch is and it may come loose. Usually it is mechanical and not electrical here. Could also be if you have a self cleaner on it, that it is reading that you are cleaning the oven. If the first thing does not work, then turn off your breaker for about 15 seconds and then back on. Sometimes it may reset itself and put it back in working order.
Nov 04, 2008 | Kenmore 47783 Electric Single Oven
Jenn-Air JGW8130DD Gas Single Oven Logo
114 people viewed this question
Top Jenn-Air Ovens Experts
 Fix Your Board
Fix Your Board
Dan Webster
Dan Webster
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
