Question about Aquabot Pool Rover Above Ground Robotic Pool Cleaner
My rover jr has power to the control box but when i press the button the robot doesnt move
2 Suggested Answers
SOURCE: pool rover JR running slow
This has happened to me several times. Hair can get caught on the impeller. This causes the flap inside the jet to not close completely. Unplug the unit, remove two screws off the jet exhaust and gently remove the hair.
Posted on Aug 28, 2009
Nabi jr has a green android laying on it's back with red exclamation make, want do anything. How do I fix it?
1. Turn tablet off. You may need to use two hands in this process to press and hold buttons properly.
2. Turn on the tablet with power button, wait a full 2 seconds from the time the tablet starts showing the red Motorola logo, then press and hold the down Volume key. (you should not hold down the power button after it turns on and logo appears)
3. "Android Recovery" will appear on top of screen if timing is done correctly. Release volume button. (if you continue to press volume down at that message, the message will cycle through "RSD, Fastboot, and back to Android Recovery. Make sure message states Android Recovery before you go to next step). If stuck at a RSD protocol or Fast boot screen, reboot the tablet by holding power button then pressing the volume up).
4. While screen states "Android Recovery", Press volume up button, the screen will say "Entering Android recovery mode" and a few seconds later an Android robot graphic will appear alone on the screen. Release buttons.
5. Hold down power button and then press the volume up key together to see the Android Recovery screen menu selections.
6. Use the volume buttons to move up and down through selection in this menu.
7. Using the volume down button, scroll down to "Wipe data/factory reset"
8. Tap Power hard key to select option.
9. Scroll down to select "Yes, delete all user data".
10. Tap the power button to select. Wiping and formatting data will take a few minutes.
11. You will return back to the Android recovery screen menu.
12. Tap the Power button to "Reboot system now" which will power-cycle tablet and eventually power back on to the Initial Set-up / Welcome screen present when you first turned on your tablet
Oct 27, 2014 | Tablets & eReaders
Pool rover junior won't back up
Try this: Take the Rover out of the pool and lay it down, wheels down. With your garden hose, shoot a strong jet of water into the impeller opening, alternating sides, 3-4 times each side. There's probably some material stuck in there.
May 30, 2014 | Aquabot Pool Rover Above Ground Robotic...
Blows fuse when turned on
Mine is doing the same thing, but I have searched and not found any solutions...
Jul 06, 2012 | Aquabot Pool Rover Above Ground Robotic...
Hi, When I push the start button on my prowler 720 control box, it automaticlly goes from green to red. When disconnect the prowler from its control box it stays green. Is there something on the prowler...
The power cord pins are numbered, 1 through 4. So are the transformer plug holes (the female pin holes in the "power pack"). For example, if you don't match number 1 to number 1, the green power light on the transformer will light for about 5 or 10 seconds, but the robot will sit there... well, like a powerless robot. Match the pin hole numbers and you have a working robot!
Apr 22, 2011 | Pentair Prowler 720 Pool Cleaner
Reset button not working
you will have to press and hold the reset for up to 30 seconds with the power on. sorry if you have tried this but it should work. if it doesnt then there is usually a restore factory setting button somewhere in the setup utility i thing with us robotics you access it by type either 192.168.0.1 or 192.168.1.1 into your internet browser. ok hope that helps. let me know how you go.
Feb 09, 2011 | U.S. Robotics (USR8054) Router
My son just received a robosapien for Christmas. I put batteries in it and the remote. The eyes only light up. The robot does not move or speak. The robosapien my son received is about 2 feet high,...
Sometimes the robot may get stuck in sleep mode. Press the power button on the robot's back (by his shoulder blade) once, and if nothing happens, wait 2 seconds and press it again. The Robosapien should begin its wakeup procedure.
Jan 06, 2011 | Wowwee Mini Robosapien Humanoid Robot
I bought a wowwee mr personality robot for my son for Christmas. It talks and responds with words, but it will not move. The remote also will not turn it on-only off even when the button is in the on...
should be under warranty
with receipt of purchase return to place of purchase
confusing instructions indeed
try using robot with the power source plugged into it robot wont shut down like it does on battery
reset button on robot base
point the remote controller towards the robot’s IR receiver so that he receives the signal properly.
You can turn off Mr. Personality from a distance using the remote controller; Table 2 describes how.
NOTE:
If you want to turn him on after having turned him off using the remote controller’s power button,
you need to restart him using the power button on the
robot (press it OFF and then ON again).
one online site offers a repair service
Manual WowWee Mr Personality Toy Robot
Mr. Personality - The Old Robots www.theoldrobots.com/images7b/Mr._Personality_Manual.pdf
Apr 28, 2017 | Wowwee Toys
How deep does the water have to be for the pool rover jr.?
If this is the type of cleaner that runs with a long hose connected and has one end stuck in the skimmer, the pool will need to be completely filled to normal level. The pool is filled with crud right? Use a long extension pole with a leaf net on the end to get out all the stuff you can. There is no way around the hard work. Don't be surprised if you need to use quite a few bags of powdered chlorine or jugs of liquid chlorine to clear the water up. Don't give up, it's gonna be hot this summer.
May 23, 2010 | Aquabot Pool Rover Above Ground Robotic...
Pool rover JR running slow
Mar 13, 2009 | Aquabot Pool Rover Above Ground Robotic...
INK SYSTEM FAILURE Ink system has failed. Unable to copy, receive faxes or print. Refer to printer documentation. error: 0xc19a0013 Press OK This is the error in which I am receiving and I need to...
Try the following reset:
Hold the OK and the Help button at the same time. While holding them down, plug the power in. Continue to hold both buttons until the unit shut off.
After shutting down, release both buttons and power on the printer.
Alternatively follow instructions on this document from HP.
May 07, 2008 | HP Photosmart C6180 All-In-One InkJet...
Aquabot Pool Rover Above Ground Robotic Pool Cleaner Logo
79 people viewed this question
Top Aquabot Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you an Aquabot Pool and Spa Expert? Answer questions, earn points and help others
