Question about Uniden 5.8GHz Cordless Phone
Uniden DECT 6,0 phone will not ring when we receive incoming calls. We can call out using the phone. I have tried unplugging all phones in the house and just plugging that phone back in.
SOURCE: model 28112ee2-4 dect 6.0
SOLUTION: My handsets stopped ringing after power was stopped to the main base, too. I put one on the main base and that one started working but the others still didn't work. So I put the other phones on the main base while I called from my cell and let it ring. The other phones started to ring and work again.
Posted on Oct 18, 2008
SOURCE: Uniden DECT 6.0 2080-2 rings for no reason
These DECT 6.0 phones work on 1.9 Ghz frequency and should not have any interference other than from another DECT 6.0 phone that can be within 150 ft of your phone. That means that somebody, a neighbor that has a DECT 6.0 phone close by is causing this problem. It also means that they are also getting these phantom phone rings. The best solution? Go to a 5.8 Ghz phone and your problem should go away.
Posted on Apr 24, 2008
divatif
  • 39 Answers
SOURCE: uniden 5.8Ghz phone.
You need to reset the main base unit. Unplug the power from the back of the base. While the power is disconnected, press and hold the delete key while reconnecting the power. Wait for a long beep tone. When the display shows 88 or P, press play button one time. If you have a phone without an answering machine, disconnect the power from the back of the base, press and hold find hs button while reconnecting power.
Posted on Mar 17, 2009
  • 37 Answers
SOURCE: Disconnects incoming calls after one ring
The problem may be a short on your line. (Have the local Teleco check your line.) If you have other phones, you may want to check them for dial tone(DT) when this happens. If you have no DT, your cordless may be the problem...unplug, and let charge overnight. If problem continues, replace the battery in cordless, or discontinue use.
Posted on Apr 29, 2009
SOURCE: our incoming calls are not ringing?
wen i receive incoming calls there is no ring or message alert
Posted on Dec 30, 2009
Uniden dect 6 0 manual
Try pressing the intercom button (base) above the number 1, on the handset the intercom button is below the # button.
Intercom?
Whenever the phone is in standby, you can make an intercom call
between stations without using the phone line.
You can make an intercom call from any station, but only two stations
can be in an intercom call at any time.
If an outside call comes in during an intercom page, the phone cancels
the page so you can answer the incoming call.
?f an outside call comes in during an intercom page, the phone cancels the page so you can answer the incoming call.
If an outside call comes in during an intercom call, press
speaker on the base or talk/flash on the handset to hang up the intercom call and
answer the outside call
see page 15/16 of the manual at the link below.
http://www.uniden.com/pdf/D1688-2om.pdf
Sep 03, 2014 | Uniden D1688-2 Dect 6.0 1 Corded 2...
Uniden cordless dct646-4 phone
Check the ring volume and settings? There not much else I can think of.
May 28, 2008 | Uniden Cordless Phone
Uniden user guide
Select the model of your Uniden DECT 6.0 system from the list beginning at http://www.uniden.com/scat/dectphones_mnl to download a copy of the manual.
Aug 23, 2014 | Uniden DECT 6.0 Cordless Phone ID
Phone rings once, but then stops ringing and I can't answer the call
If you have a landline, most likely you have a short in it. Not enough to kill line, but, when the 90 volts a.c. comes in to ring it jumps short. The short answers the phone.. It doesn't stop out going but can cause static. Check the line at the box outside. if bad there call your phone company, if good there, trouble is in house
Oct 03, 2017 | Uniden DECT 6.0 Cordless Telephone...
Have uniden dect 6.0 it is stuck on silent mode; will not ring
Since you declined to specify the model of your Uniden DECT 6.0 phone, I can only direct you to select it from the list beginning here to download a copy of the manual.
Feb 03, 2012 | Uniden DECT 6.0 Cordless Telephone...
Our incoming calls are not ringing?
Dec 10, 2009 | Uniden Cordless Phone
One ring - noise like fax to caller, phantom call to receiver
Try unplugging all sets and call in. Do you still have a faxlike tone, like from an ALARM system or something else down the street?
Aug 21, 2009 | Uniden DECT 6.0 Cordless Telephone...
Apr 29, 2009 | Uniden DECT 6.0 Cordless Telephone...
Mar 13, 2008 | Panasonic KX-TGA101S Cordless Handset
Uniden 5.8GHz Cordless Phone Logo
137 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
