Question about Hitachi 53UWX10B 53" Rear Projection Television
The screen on my Panasonic DLP TV goes black then the picture comes back. The sound is unaffected. Is this a sign the bulb is going bad?
  • 71 Answers
SOURCE: black square in middle of tv
He, he. Somebody activated the subtitle mode on the remote. Desactivate the CC mode on your menu and it'll go away or at least if you want CC put it in CC1 Text1
Posted on Dec 10, 2007
petraman7
  • 1175 Answers
SOURCE: Panasonic PT-50LCX63 it's not the bulb this time.
I've worked on similar units. If the bulb is good then the ballast that powers the lamp has failed. The ballast is available but around 300-400 US
Posted on Mar 18, 2008
  • 298 Answers
SOURCE: Problem with Toshiba DLP Projection TV Model #52HM84
It is possible the lamps may be defective or that they may be the wrong replacement for this model, as it may have a different wattage setup with the ballast. If you want to try to order the TB25 lamp from a different vendor, you can order the original Toshiba replacement lamp for this model (52HM84) from a major Toshiba parts distributor at the link below:
Toshiba 52HM84 Replacement Part TB25 Lamp / Bulb
Posted on Apr 10, 2009
  • 2318 Answers
SOURCE: how to reset a panasonic dlp lamp hours?
Try the following:
If you need to get into the service menu, you can do so by following these directions:
With power on, hold down VOL minus button on projection display and hold down the PIP or SPLIT button (try both) on the remote simultaneously for more than 5 seconds.
You can also click here to get more instructions if the above do not work. See post # 4.
Posted on Jun 17, 2009
  • 41 Answers
SOURCE: Tv picture freezes then goes black 10seconds later HL-R5067W
Sounds like the digital board needs replaced.
Posted on Jul 11, 2009
Samsung lcd tv has sound but no picture. Samsung TV works for about 10 minutes then screen go black but sound continues
Use a flashlight on the screen when it goes black. If you can see a faint picture then the board that controls the back light has gone bad. If you see no picture then the T-Con board is bad. You can get replacement parts here: TV Parts Universal TV Stands DLP Chips ShopJimmy and fix the TV yourself. It's not that difficult.
Mar 13, 2016 | Samsung LN40B610 LCD TV
I have a 50" Samsung tv. The tv turns on and the screen comes on, then within 1 minute the screen goes black. I can still hear sound.
Samsung HL-R5087W TV screen goes blank -tv/sound on - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - About a month ago, the at various times the tv screen would go blankeven though the tv ... Try turning off the cable/sat box when the happens. ... In reply to: Samsung SP50L7HX DLP TV linked to Sky HD box - same problem .... on it comesback to normal. however, once it went off again (Black Screen) after only 2-3 minutes. ln-t4069f picture problem lcd warmup - Forums - CNET
Jun 11, 2015
Samsung LCD TV LN-T5265F Black Screen Diagnosis Help ...
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...Sign in to add this video to a playlist. ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't ... 1:26.Samsung LED TV Blank Screen & No Backlights Basic ...
Samsung TV screen goes black w/ audio still playing ...
? 1:49
https://www.youtube.com/watch?v=L9cjcsysdW4
Sep 11, 2012 - Uploaded by Roberto Ramos
TV screen begins to flicker then screen turns black while the audio continues to heard. I'm unable to see the TV Menu options when screen turns off. ... After turning the TV OFF then back ON again, the screen will flicker and then ... 1:26. Samsung LEDTV Repair - T-Con Board Replacement - No Picture on ...
Jan 28, 2016 | Samsung Televison & Video
Trying to replace lamp in HDTV and having trouble. Does not function correctly after putting in new bulb. Boots up and then visuals go black and the green power light keeps flashing. Help?
Panasonic DLP TV Bulbs
Make sure its an original Osram or Philips bulb inside the housing. If its a cheap lamp it will act this way. If it is an original lamp, then you may have a power supply issue. It shouldn't affect your TV but you may want to try resetting the lamp timer by following the instructions that came with the lamp.
TY-LA1001 Timer reset
While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
Aug 15, 2015 | Panasonic Pt-52lcx16 Projection Television
I believe the blue lamp in my 57H81 is going bad.
You need to replace convergence out chips in your Toshiba 57H81 tv by qualified tech because 3-D look picture in rear projection tv shows some thing wrong with convergence output chips.
Your tv model number shows it is rear projection tv that use 3 tubes to make color picture on front screen where as dlp tv use one lamp as back light source to present picture at front screen that is generated in light engine.
Mar 25, 2010 | Toshiba 57H81 57" Rear Projection...
The tv has power , the volume comes on ,but no picture,just black screen. The red change lamp light has been on for some time,and it is still on
I believe this is a DLP set. There is a single high power bulb that shines thru the dlp chip and onto the screen. My old Panasonic 55" (forget the model) had the bulb access on the front left side-1 phillips screw to remoce the door and another to pull the light assembly. Replacement bulbs are available plain or in the assembly-your choice. Just google your make and model plus DLP bulb and you should be good to go- I paid $85 for the bulb alone- order 2 as the life span is much shorter than what panasonic claims- there was even a class action lawsuit over this issue that covered about 10 different set.
Dec 19, 2009 | Panasonic PT-51HX41 51" Rear Projection...
Samsung 50" HD DLP TV video goes out
Common problem of a bad lamp call your local repair shop on price and availability of lamp.
Oct 22, 2009 | Samsung DLP HL-P5663W 56" TV
Screen is fine when I first turn on TV, then goes black
Sounds like you dlp lamp is going out. That's a pretty old TV and if you are still running on the stock lamp this is exactly the type of thing that will happen. The lamp model for this particular tv is the ty-la1001. You can find that over here:
http://dlplamps.com/products/panasonic-dlp-lamp/panasonic-ty-la1001.html
Mar 21, 2009 | Panasonic PT-52LCX66 Projection Television
Open Questions:
See all Hitachi 53UWX10B 53" Rear Projection Television Questions
Hitachi 53UWX10B 53" Rear Projection Television Logo
112 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
