Question about Pondmaster Pond - Mag 7 Pump, 700 Gph
Mag 7 pump does not work - Pondmaster Pond - Mag 7 Pump, 700 Gph
    Problem Solver:
  • 8 Answers
Prime pump till over flows connect lines make sure no leaks pump has low or no water shutoff built in make sure intake is completly submerged at all times, hit reset switch
Posted on May 09, 2010
How do I take apart model PES-80-PW
nothing to take apart on this one it's a mag drive pump , if somehow the housing requires cleaning , backflushing down the outlet pipe is about the only way to do it , unit is sealed otherwise
mag drive means that a magnet is used to couple pump to motor so a direct connection is not needed so no drive shaft seals to fail , mag drives should never never be run dry with low to no water in pond , they use the water for cooling and will fail beyond repair if allowed to melt
Mar 31, 2013 | Little Giant Submersible Fountain Pump
Microwave shuts itself up after 7 seconds
ck the cooling fan .. but 7 sec is almost to soom to get mag hot / it may be the pc control board . if fan is not cooling mag then I would rep; board .. ****
Jan 09, 2010 | Panasonic NN-H504WF Microwave Oven
Need to know the type of oil that the skilsaw 7 1/4'' mag 77 use
skil recommends using their lube 80111 for an 8 oz tube or 80112 for a pint. however any good quality worm drive lube will work. Don't use a gear lube because the worm drive has additives for anti foaming and gear wear added. Let me know if you need more help
Nov 17, 2009 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
Describe your Skil 7 1/4" Magnesium
You have large plastic screw on the saw, remove it and fill the oil to bottom of threads and that should be it.
Sep 15, 2009 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
My Pondmaster Mag 3600gph pump quit working too
welcome to pond life they rarely last more than 1 to 2 years
Jun 27, 2009 | Danner Pond Pondmaster 500 Gph Mag - Drive...
New pump not pumping
I can only imagine that something has jammed the magnet/impeller. take the screws off the volute and remove. Pull out the impeller assembly and inspect for possible source in magnet chamber and impeller housing. That is a very problem free model.
Mar 15, 2009 | Danner Pond Pondmaster 700 Gph Mag - Drive...
Steering problem
the size of the mags can be the problem .when the mags been used already the shape have change a little .
Jan 22, 2009 | 1999 Suzuki Vitara
Is power to the pump insides; if the best thing is to re place it; I couldn't repair my same pump.
Oct 31, 2008 | Danner Pond Pondmaster 500 Gph Mag - Drive...
Mag & Yel Ink don't work
replace ALL carts with new ones.
press menu then start bk-copy then fourtimes arrow up quickly one after another. machine turns to maintenance mode.
press 7 then 6 then 4 then start bk-copy.
machine will initiate the carts and refresh ink in tubes and ph and do some special power cleaning.
when finished press 7 then 6 then 3 then start bk copy.
machine will do a power cleaning.
when finished press 9 then 9 to leave maintenance mode.
run a test print.
If you cant see any yellow and/or magenta the ph is defective and needs replacing (this happens mostly because of generic ink which contains the wrong chemical mixture to keep the ph alive).
Mar 24, 2008 | Brother MFC 420CN All-In-One InkJet...
Pondmaster Pond - Mag 7 Pump, 700 Gph Logo
161 people viewed this question
Top Pondmaster Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Pondmaster Garden Expert? Answer questions, earn points and help others
