Question about Delta & Single Handle Shower Faucet
Delta tub valve how to replace
I got the retainer clip off but don't know what is still holding valve in
  • 31 Answers
Depending on how old the valve is; it could just be held in by mineral deposits over time. Once the circlip is out, AND THE WATER PRESSURE IS OFF, just re-attach the handle and pull it out. The handle should give you the extra grip needed to get the assembly out.
Posted on May 09, 2010
How do I relace the drain flapper valve (528625P) on the bottom of the upper drawer in my Fisher Paykel 603?
9.9.1 Remove the drawer front
9.9.2 With the tub opened release the tub clips and push back the
drawer rails.
9.9.3 Carefully release the four wiring cover clips from the front
lower section of the tub taking care not to damage them.
9.9.4 Release the three clips on the underside of the tub which
retain the wiring cover.
9.9.5 Pull the tub fully open and lift it up at the front (this makes it
easier to remove the wiring cover from the rear of the tub).
9.9.6 The wiring cover may now be carefully moved forward to
release it from the rear of the tub.
controller.
9.10.6 Unclip the drain hose cuff from the motor assembly taking care not to misplace the non-return flap valve so you know where it sits.
Replace flap valve and refit in reverse order.
Not sure why you need to take the top drawer out if you have already got the bottom drawer out and only need to replace the valve in bottom drawer.
Apr 18, 2014 | Fisher and Paykel 23 in. DD-603SS Built-in...
I have a Delta Tub/Spout Pull Down Diverter that has a pretty persistent drip. The HOT and COLD handles are turned off and seem to be as tight as they can be. After doing some research online I believe...
If your Delta RP17453 Pull-Down Diverter Tub Spout stops dripping after 5 minutes, your ok. If it never stops dripping, you need to replace delta faucet cartridge(s) behind the handle(s). This is were the water turns on and off and stops the water flow to the tub spout.
Delta faucets are some of the easiest to repair, and parts are usually available at any hardware store or home center. If you have a two handle faucet, replace both delta seats and springs and stems. If you have a single handle Delta faucet, replace the entire cartridge.
Jan 26, 2011 | Delta Faucet Delta RP17453 Pull-Down...
My Moens One handle tub shower shot out at me and i could not stop the water for nothing what would make it shot out
If it is an older valve there is a small copper retaining clip that holds the cartridge in place. If this clip broke it could blow cartridge out or come out when you pulled it to turn it on.
If that is the trouble you can see the slot in the top of the valve body where the retaining clip goes.You will need to get a new clip and put the cartridge back in and insert clip to hold it. If you find that you have the hot and cold sides reversed simply turn the stem of the cartridge 180 degrees and you should be in business. Thank you
Jan 02, 2011 | Moen & One Handle Tub & Shower Faucet
Low pressure on hot water side
I would recommend that you replace cartridge. To do this shut off water supply to tub or whole house as needed, Remove valve handle cover,remove handle screw and pull off handle. Remove chrome cover from around valve body. There is a small brass or copper clip that fits on front side of cartridge to hold it in place. Carefully remove this clip as you will need it for reassembly. Grasp end of valve stem with pliers and gently try to pull cartridge ftom valve body, If it is stuck you can purchace a moen cartridge puller at most hardware stores. Follow directions on how to use puller, remove old cartridge,install new one . install clip moving cartridge slihtly to proper position so retainer clip will slid into position. replace chrome cover and handle and screw and cover. Turn water back on and you should be done. Hope this helps. Thanks
Nov 18, 2010 | Moen & One Handle Tub & Shower Faucet
How do i install a new cartdridge for a delta single handle faucet in my tub
Remove the shower control handle. If the cartridge is threaded there will be a nut on the top. Remove with a crescent wrench. If there is no nut then there will be a retaining clip and the cartridge will then pull straight out. Installation is the reverse procedure.
May 31, 2010 | Delta & Single Handle Shower Faucet
Can't get the collar off in order to put in a newcartridge
There should be a set screw on the bottom of the handle or you have to pry off the center cap to reveal a screw. Then there should be two screws that hold the backer plate on. Remove those. Once handle and plate are off there should be a retaining clip that holds in the cartridge. Make sure your main water valve is turned OFF.
Hope this helps
Jan 27, 2010 | Delta & Single Handle Shower Faucet
P0734 and P0761 codes related to 4th gear ratio and solenoid c shift problem
Its more than you think. 1. Inspect for a broken retaining clip by removing the valve body and then the valve body separator plate. Inspect the forward clutch control valve, spring, retaining clip, and valve body casting for damage (Figure 1).
2. If the clip is broken and the forward clutch control valve and/or valve body casting is damaged, replace the main control. The retaining clip has just been revised to prevent the chance of breakage. The revised Retaining Clip (F8DZ-7F194-AA) has circular cutouts on the side of the clip in place of the square cutouts on the previous design level clip (Figure 2).
3. Inspect the new main control (if required) before installing it and replace this retaining clip for the forward clutch control valve and spring if it's not the new design (Figure 2).
4. Any time service is required on any AX4N transaxle main control, inspect the retaining clip for the forward clutch control valve to be sure it is the latest design level, and replace the retaining clip if it is not. The revised clip is larger and will remain centered in the valve body casting groove. too repair estimate..400-800 dollars...Hope this help..Big shops will hurt yo pockets
Dec 16, 2009 | 1996 Ford Taurus
I have a dipping faucet in my bathroom tub. I
Turn the water off to the residence and then remove the handle. After you remove the handle you can remove the retaining nut. When the retaining nut is removed you expose the internal parts that can be taken to your local hardware store and the parts matched. Usually, there are two small washers with springs up in the manifold that will need to be replaced. You can take your old parts in and usually buy a rebuild kit for it. If you aren't experienced, I would hire a plumber to replace the internal workings. It can be difficult if you cant get the retaining nut off.
Apr 07, 2009 | Delta & Single Handle Shower Faucet
Re Coleman liquid gas 321B lantern
The clip needs to go on with the "clicker" to the left as you look at the valve head on..
Oct 20, 2008 | Sport & Outdoor - Others
GE WJSR 1070A Leaking
It sounds like you have a leaking pump. The pump is easy to replace:
#1 Use a shop vac and pull all the water out of the drain line. This will keep you from having to clean up about 1 gallon of water off of the floor.
#2 Lift the front of the machine enough for you to get under and see.the pump just inside the front of the washer.
#3 Lift the 2 retaining clips off of the pump. This will allow you to pull the pump off of the motor.
#4 Remove the 2 clamps off of the hoses.
#5 Install the new pump into the hoses, and reinstall the clamps.
#6 With the retaining clips installed into the motor housing, install the pump.
#7 Attach the retaining clips, and set the washer back on the ground.
You have now replaced the washer pump.
If you have any questions, let me know
Please rate this solution
Jan 24, 2008 | GE WJSR1070A Top Load Washer
Delta & Single Handle Shower Faucet  Logo
80 people viewed this question
Top Delta Home Experts
Mike
john h
Tim Whalen
Are you a Delta Home Expert? Answer questions, earn points and help others
