Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
High pitched whine
All of a sudden my D52w20 (which has not been used often) intermittantly while watching TV or playing X box starts making a really loud high pitched whine. If I turn it on/off several times sometimes it will stop. What's strange is when it's doing it and I turn it off and back on, the noise does not start until the picture appears, and sometimes the noise does not come back on at all, or at a different pitch or noise level.It seems to happen more often when the TV has been on for a while. Otherwise the unit works just fine. I would really like to repair this myself......Thanks for any advice.
    Genius:
  • 1,030 Answers
Ok maybe this may help .... there is a coil LL08 I believe... somtimes it creates a high pitch whine like you describe.. its stands up on the deflection board..it basicaly a large coil of copper wire....you can take silcon and put on the coil...in effect damping the ocillations...hope that might help
Posted on Mar 27, 2008
SOURCE:
My tv powers on displays the LG logo then makes a high pitched squeal sound from speakers and then flashes on screen (strobe light effect) does not display picture or sound.
LCD TV Repair Tutorial - LCD TV Parts Overview, Common ...
? 11:05
https://www.youtube.com/watch?v=tS4sIpdajVw
Aug 23, 2013 - Uploaded by ShopJimmy.com
Repair review of common LCD TV Problems and Repair Solutions ... input the tv is set to it begins making a high pitched whiningsound. .... I have a LG 47LN5750 that powers on, flashes a good picture for about 1/2 second, then goes dark. ... hi my samsung tvis not turning on is black. and I just replace the ...
#Treat At Home high pitched whine from plasma tv Tinnitus ...
www.aspenridgerentals.com/tinnituscure/?...high%20pitched%20whine%...
LG 50PK540 plasma TV Repair power supply EAY60968801 Part 1-2 ... Sanyo DP42849 with high pitched squeal after replacing power supply. ... In my second daily fix video, I solve a mystery that was making me having to turn off my speakers before I went to be ... The flash is accompanied by an high pitched sound.
TV not turning on; making high-pitched sounds - Tom's ...
Dec 16, 2015 | LG 55LE5400 TV
Tv dead. high-pitched whine when plugged-in.
Sounds like the back-light inverter board has damaged. Check it.
May 21, 2013 | Emerson LC391EM3 39 in. LCD HDTV
High-pitched whine upon cranking, suddenly sluggish, smells hot
It sounds like the water pump shaft bearing has frozen up. A hint here, always replace the idler pulley and water pump when you do the belt, they make kits for this and they have all the parts that wear out along with the belt. As long as the engine doesn't get to hot you should be ok.
Jul 02, 2012 | 2000 Honda CR-V
My rca tv has a distorted picture and a really high pitched buzzing sound
Problem is in High voltage circuit and likely either the high voltage transformer or a connection right under or around it.
Jun 16, 2012 | RCA D52W20 52" Rear Projection HDTV-Ready...
There's an intermittent high pitched noise from sharp aquos lc32 le600e
Sounds like a transformer or choke that has loose windings and they are resonating, you can pull the back and put small amounts of silicone on those components or replace the power board
Dec 19, 2017 | Televison & Video
High pitch whine when tv started then it lowers in pitch
That could be either the color wheel or one of the fans. try listening to which area of the set its coming from.
Apr 04, 2012 | Televison & Video
Making high pitch whine or squeeling
Check the color wheel and any fans running on the unit. The color wheels make a high pitch whin right before they quit as well as the cooling fans.
Jul 01, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
High-pitched sound when using surround sound
I had the same problem, check your wires on the back of the tv and make sure your, red, yellow and white wires are in the correct holes. What kind of tv do you have, as I have an Ilo, and it has like 15 different plugs in the back, you may have to get you book out and make sure you have it in the correct hole on the back of the tv... I hope this helps....
Jan 11, 2009 | Sony DAV-SC8 System
High pitch shrill when input device not DVI
use of silicon or superglue on a coil next to the flyback that solved the problem in a similar model RPTV. Easy fixes first
Jan 03, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
High pitched buzzing...
noisey yoke? Listen thru an empty paper towel roll cylinder to isolate---
Nov 17, 2006 | Sanyo DS27910 27" TV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
242 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
