Question about Pioneer EQ-6500 9-Band Car Equalizer
I need to no how the wires get hooked up - Pioneer EQ-6500 9-Band Car Equalizer
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 155 Answers
Bottom right( red wire 12 v dc on/off ignition switch)
2. top right( blue wire with inline fuse to amplifires)
3. bottom left( black wire ground)
4. top left( blue wire stereoi need to no how the wires get hooked up - 2_bing.gif remote wire)
Posted on May 09, 2010
I put a Pioneer AVH 1400 DVD in 06 solstice have it hooked up working but no sound through speakers I have hot ground remote and speaker wires hooked up what other wires have to be hooked up 4 sound
If the car had an amplified sound system prior to removal you will need to turn on the factory amp. You need to hook up the blue wire with the white stripe. You may have a dedicated wire that you need to hook it to or you may have to hook it directly to the 2 blue wires for the power antenna. Now you may not have a power antenna but hook them up anyway. If that doesnt work you have a dedicated amp turn on wire. If you find that and it still doesnt work check your fuses for the amplifier with a digital multimeter. Replace any blown fuses that you cant find
Apr 17, 2016 | Pioneer Car Audio & Video
Wires been cut in my 1994 honda and i bout a cd player what wire i hook up to make it play
the easiest way to do it is to get a wiring harnest adapter from like walmart, and hook up that way. i have a 92 honda civic and thats what i did. if you need a wiring diagram, you can get one from the honda website. but they may charge for it.
Feb 29, 2012 | Kenwood Audio Players & Recorders
Where do you connect the memory wire on a jvc kd g110 car stero.....what color is the memory wire ?? what does hook red wire to acc fuse mean??? what wire does the red wire on the radio connect to on...
The yellow wire is most likely the memory wire as it needs to be connected to a constant 12 volt source.
"Hook red wire to to acc fuse" means you need to hook into the fuse block under an Accessory Fuse. (ie: something that can't be turned on unless the car is running or the key is in the "Accessory" position)
The red wire is explained above. It does not connect to the harness.
Just remember that the yellow wire needs to be hooked to a constant 12 volts and the red needs to be hooked to a circuit that is only active when the car is running or switched to the "ACC" position.
Mar 02, 2011 | JVC KD-G110 CD Player
Hampton bay ceiling fan
Your black wire hooks up to your fan. The blue wire hooks up to your light. And your white wires hook up with the white wires from the fixture, and the bare copper wire hooks up to your green ground wire. Please contact me if you need further help. Good Luck, and I hope this works for you. Jim
Apr 07, 2010 | Hampton Bay 24002 Ceiling Fan
Need a basic diagram to wire a ceiling fan.
Depending on how your place is wired will dictate the solution here.
The light box in your ceiling should have two or three wires. Black and White, or Red, Black and White.
If you have two wires (one switch to control everything):
Black is power - hook this to the fan's power wire (and the fan's light wire if applicable)
White is neutral - hook this to the fan's neutral wire.
If you have three wires (two separate switches):
Red is power for the light - hook this to the fan's light wire if applicable
Black is for the fan - hook this to the fan's motor
Sep 18, 2009 | Hunter 52" Ceiling Fan With Light And...
No power to amp
you need to hook up the rem wire, that runs from head unit to amp its usaully a blue wire on the head unit and there should be a rem input near where the power leads are on the amp
Mar 21, 2009 | Kicker ZX400.1 Car Audio Amplifier
I have a three wire lead out of my junction box (bare wire ground/white/black)and my new GE JTP 30 electric oven has a four wire (extra red). What is the wire configuration needed for reinstalling?
hook from the range the green and white wire to the bare copper wire from the house
hook the black wire from the range to the black wire from the house
hook the red wire from the range to the white wire from the house
Apr 24, 2008 | Kitchen Ranges
Pioneer EQ-6500 9-Band Car Equalizer Logo
888 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
