Question about Pentair Pool & Spa
We have a pentair 250 NT DDTC heater. The fenwel control red light is flashing and according to the code it is air flow fault. To get the heater running, we jumped the air pressure switch and the heater worked. We changed the air pressure switch and the same thing happened. Do we have an air flow problem? Where can we check to find out where the air flows.
  • oaiona May 09, 2010
    I'm not paying to be told to call Pentair. You're the expert. What do you recommend
  • oaiona May 11, 2010
    Your response was better than the other from the expert which was to call tech support. Thank you so much!
    Guru:
  • 415 Answers
There is tubing connected to the air pressure switch. Inspect for kinks, water logging, or cracks and correct as necessary.
Inspect your exhaust vent and your fresh air intakes. Clear any blockages.
Ensure you have air pressure at the exhaust termination point.
Inspect the motor and wheel for tightness and cleanliness...correct as necessary.
Check blower and blower housing gaskets, correct as necessary.
This is a good jumping off point. I look forward to hearing back from you with your findings. :-)
Also, here is a copy of an Operator's Manual that may be helpful to you.
Posted on May 09, 2010
    Master:
  • 497 Answers
I have a phone number for you to call, Call Pentair's Technical Service Department at: (800) 831-7133... GOOD LUCK..
My nt400 ignition control box flashes once indicating an air flow fault. how do i fix
most likely needs a blower, to verify test the air flow switch first,
also cloggec duct will do the same
May 17, 2015 | Pentair Minimax NT Heater
Hello, I have pentair minimax 250 pool heater. When turning on the temperature, ddtc cycle to off. Nothing happen, no clicking noise, blower doesn't turn on , no error code on LCD. No led light in the back...
check main power supply for proper voltage, check primary and secondary sides or transformer, 24 vac getting to display screen???? 120 vac getting to blower???
Nov 27, 2013 | Pool & Spa
Error code e04
If the fan was seized, it is likely bad, even if you freed it. If it doesn't sound the same, or is not as loud as it used to be, it is also most likely bad. If it doesn't move enough air to close the air pressure switch, then you will get an 04 fault, which is an air flow fault. HTH
May 23, 2010 | Pentair Minimax NT Heater
Heater will not turn on.
If the heater does not even attempt to light, it's most likely the Digital Display Temperature Controller (DDTC) Circuit Board.
Nov 08, 2009 | Pentair Minimax NT Heater
I get one flash which is an air flow fault on my mini max nt. . . I have reset but still does not work.
check for spider webs if nothind bypass the flow switch just to check do not leave that way if heater work the flow swithc may be bad
Aug 19, 2009 | Pentair Minimax NT Heater
Pool & Spa Logo
57 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
