Question about Maytag Refrigerators
Flashing digital display on door. continuous operation of ice chute door
  • 10,319 Answers
You have a defective ice maker. Contact Maytag Customer Service at (800) 344-1274 or go to www.maytag.com.
Posted on May 09, 2010
I have Samsung refrigerator RFG298 series the ice maker stopped working and sounds like a dog barking when it's running any ideas what it could be ?
Possibly the gear drive faulty in the ice maker, or it could be the dispensing chute has ice blocking it from closing properly. Completely empty the ice tray and make sure there is no ice anywhere in the tray, guides or ejection chute to the front door. On some, there is a little button under the icemaker for testing and forcing an ice maker operation. Press it and see if the ice tray rotates and reloads with water.
Nov 20, 2016 | Samsung RFG298HDWP French Door...
Ice maker freezing up at water chute.
It's probably the water fill valve seeping which requires replacing that valve on the back of the refrigerator.
Jul 21, 2013 | GE Profile PSW26P Stainless Steel Side by...
GE Monogram -- Ice freezes IN THE CHUTE and blocks the chute
My ice cube chute kept freezing, and I realized the Access Door was stuck open. I was able to replace it without taking the door apart.
Sep 26, 2009 | U-Line CO2075F-B Echelon Refrigerator Ice...
GE Monogram refrigerator icemaker problem
This is normal if you have previously used the crushed ice mode. The refrigerator will continue to dispense crushed ice for some time until the reserves are depleted. If this continues for a longer period then shut down the refrigerator and remove the dispenser compartment, clean any remaining ice and reinstall it. Start the power supply and wait 5 hours for the ice to form. Use the cube mode and you will surely obtain ice cubes.
Aug 27, 2009 | GE Monogram ZISS480DRSS Stainless Steel
GE Profile 26.6 cu. ft. side by side is frosting in the shoot
Oddly enough, the problem is with your ice dispenser. What happens is that the door at the bottom of the ice chute is probably not sealed. This is likely because there is a solenoid that is supposed to hold that door open when you push your cup against the dispenser arm, and THEN, close it again when you release. If the chute door is not sealed, warmer, moist air from outside the refridgerator will be canstantly drawn up the chute where the moisture will freeze as frost. Gradually, this frost builds up in the chute until there is no longer enough room foir the ice to fall. You can usually look up at the chute from outside and see that the door is not sealed. In my case, I left it unsealed because the door would not open to let the ice out. It took me about 3 months to figure out that this was causing my frost-clogging problem. The solution is to replace the solenoid that is supposed to open and close the chuite door. If you remove the despenser panel, you will see that this solenoid is probably all rusted up and not working. The following link will allow you to enter you model number and see a diagram of the offending area. http://www.pcappliancerepair.com/model-display.php
Jun 10, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Door dhute not opening to let ice fall
on the right hand side of the door chute there is a little metal barrel that needs to be attached to the end of the arm that holds the ice door. this is attached to the spring that opens and closes the door chute.
Apr 16, 2009 | Maytag MSD2732GR Side by Side Refrigerator
Ice chute door on maytag refrigerator
the door is opened by a solenoid. it is bad or it is not getting voltage due to bad control or wiring
Apr 24, 2008 | Maytag MFD2560HES Bottom Freezer French...
Ice Jam in Chute - Whirlpool IDI SxS
first check would be to see if the flapper door is closing all the way in the dispenser area. best way is to remove the ice bucket and shine a flashlight from the front up into the disp door area and look for light around the door from inside the chute.
another check would be to make sure the door delay mechanism is connected an not allowing the dispenser door to close to fast trapping a cubes in the door and causing an air leak in the chute..
Keep in mind if you use alot of crushed ice frost build up is faster than with just cubed.
Dec 10, 2007 | Whirlpool ED2FHEXN Side by Side...
Refrigerators Logo
19 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
