Question about Mitsubishi WS-55513 55" Rear Projection HDTV
No vedio image
Old TV. Trying connect X-box to EXT-3 on front. Hear sound, but no vedio.
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
The front jacks are composite (yellow, red, white) I suspect x-box is component (green, blue, red)
Look for the one component input on the back marked DTV which should have 1080 marked on it.
SD TECH
Posted on May 09, 2010
I have a 2004 chevy trail blazer ext 4 wheel drive does not work used it last week and was fine
When you switch from 2HI to 4HI, you should hear two distinctive sounds from under the truck, one is the transfer case actuator and the other is the front differential actuator. If you hear both and you still do not have power going to the front wheels, then there is a problem with the front disconnect assembly.
Oct 30, 2011 | 2004 Chevrolet TrailBlazer
Tip
How to connect external tv box to your pc ?
simply <br /> <br /> 1- vedio connection<br /> <br /> connect the monitor data cable to the the external tv box and take the out data cable from external tv <br /> <br /> connect to your pc <br /> <br /> 2- sound connection <br /> <br /> take sound cable from tv sound out to line in pc ( don't forget to open line in , in the sound properties )<br /> <br /> 3- finally connect the the adaptor to the tv box and play all <br /> <br /> best regards <br />
on Apr 02, 2011 | Computers & Internet
How to connect a sabrent external tv tuner box
simply
1- vedio connection
connect to your pc
2- sound connection
best regards
if you see that is helpful plz dont forget to vote me
Could hear the chanels good but no pictuere
Hello
1. Check the video connection of any devices plugged into the television. If you can hear sound but are seeing no picture while trying to use something like a DVD player or cable box, the problem is probably that a wire is loose somewhere. Check the yellow video cables running from the DVD player to the TV and make sure everything is plugged in firmly and where it should be. Also check the coaxial cable running from the cable box (or cable outlet) to the television and make sure that wire is also screwed in securely.
2. Check the image settings on your television and make sure everything is set properly. Certain settings like "Picture" or "Brightness," if set to one extreme, can make the picture appear completely black. This could cause you to simply hear television shows but not be able to see them. Reset all picture settings on the TV to their original factory default settings to see if that fixes the problem.
3. Try another channel. If you're watching TV and not getting a picture, the first thing you should do is check a variety of random channels to make sure it is a problem with your TV and not with your television signal. If it is a problem with the television signal it is the fault of the TV station or cable service provider and there isn't anything you can do yourself to fix it.
4. Try the DVD on another DVD player. If you're trying to play a DVD and can't see any images, make sure the disc isn't defective. Try it on another DVD player or a computer DVD drive and make sure the disc works in the first place.
5. After all the steps and it does not come on then you would need to visit a technician.
BEST OF LUCK
Dec 15, 2010 | RCA TruFlat 27F520T 27" TV
Have sound but no vedio on x-box 360
well all i can think of is that you mite have it on the wrong input or you vedio cables may need to be replaced. some friend of mne had to chage out there cables to so hopefully this helps you if not im sorry.
good luck :)
EnVy
Apr 04, 2010 | Buck Legendary: The Box for Xbox 360
My monitor won't work the power button flashes on and off and my screen stays blank and it just sits there with the power button flashing on and off repeatedly
ITs the Vedio card issue, the power on your screen is on but the image is not there coz the vedio card is not shooting any picture, check the vedio card connection, the one comes from computer to screen , make sure is well connected and on the right place, if it doesnot work, open the computer and make sure your vedio card is pluged well and not out of place, if all this doesnot work change ur network card. but before that when u put ur pc on did u hear any beeps? if yeah let me know how many beeps you hear and if its short or long so i can help you. Regards
Jun 14, 2009 | CTX S762A 17" LCD Monitor
Technics DVD Stereo SC-DV290
never done this myself, but I would guess you take phono jacks from your TV (L & R out) and plug them into the back of the sound processor, iether VDP(AUX) or VCR(EXT) IN
then go to your remote and press (vcr(ext)/vdp(aux) repeat pressing until you hear you tv
each time you press button it should go through a selector menu
TUNER->DVD->TAPE>VCR(EXT)->VDP(AUX)
hope this helps
Feb 02, 2009 | Technics SC-DV290 System
Xbox and tv = no sound
Yes, those cables are quite common. Check any electronics retailer like Best Buy or Walmart.
Aug 25, 2008 | Microsoft Xbox 360 Console
Am setting up a bose GSX 3-2-1 home theater
Need to know the TV connections. On newer TV's there RCA jack connection or ext speaker connections. Usually the external TV speaker connections hook to the woofer and the rest of the speakers are connected to the woofer. The woofer acts as the sound system for the rest of the speakers. With this method you need to mute the internal TV speakers by a swiich on the TV or internal TV setup menus and select ext speakers.
Jan 26, 2008 | Bose Cinemate Digital Home Theater System...
Mitsubishi WS-55513 55" Rear Projection HDTV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
