Question about Car Audio & Video
Adding in line filter to radio and did not disconnect battery.....had a spark and now radio does not work....fuse is fine and radio makes a sound (mechanical) when attached to power....but does not turn on...
  • 1 more comment
  • moore_iv_jam May 09, 2010
    if it is the radio...how can i isolate the problem to make sure it is the problem??
    yes..it has a cd player..but there is NO power what so ever....
    yes...thanks.
  • 2,427 Answers
Chances are you blew eighter the output circuit or the power filter circuit.. The sound u hear is a humming capicator.. or wheering IC,, now you have 2 choices..
a.) remove radio ,, open it up and determine which parts need changing,, and replace them or take the radio to a shop and get it repaired..
b) replace it..
I usually stick with b cause for some reason when i get my stuff repaired they dont work as they once did,, i get lower performance and they have other issues or get damaged rather quickly..
Posted on May 09, 2010
  • 674 Answers
I hate to be the bearer of bad news, but if you had a spark chances are the radio is done for.
  • Brian Niten May 09, 2010
    Does it have a CD player? See if one will play. I had a similar experience installing a car stereo. The radio was toast but the CD player still worked. Other than that you will need to take it to someone that can trouble shoot it as I did. I had to pay for the trouble shooting to find out the repairs would be more than a new radio.
I changed h2 and catylic converter,in line filter,muffler,mass air flow censor,and battery still no power could it be fuel pump regulater? fuel pump still pumping
That would have been an expensive exercise. Try resetting the engine management electronics. Disconnect the cars battery completely with your headlights on. Leave the battery disconnected for at least 30 minutes. Leaving the headlights in the on position will kill any residual power left in the car. Obviously, the clock, the radio etc will also lose their settings. make sure you have the Radio pin code BEFORE you disconnect the battery as you will need it to restart the radio. reconnect the battery and try the car again. Resetting the electronics will put it back to factory setting. Hopefully , this will cure your problems. Ive done it a few times on my Ford and its worked fine. If not sure, try looking online for "resetting Ford ECM" there are many videos and info showing this and how to do it.
Sep 17, 2015 | 2002 Ford Taurus
Windows, Locks, And speakers not working. No blown fuses
On some cars when you disconnect the battery for whatever reason certain electrical areas will not be restored to operation after the battery is reconnected. You need what they refer to as a radio code to restore radio and other circuits to operation. The code should be in car manual. If not contact the dealer for the radio code for your car.
Sep 01, 2015 | 1995 Nissan Maxima
Why did my radio stopped working?
double check all your connections. you can always bench test the radio with a car battery and any speaker. find your 2 hot wires and 1 ground. (1 hot wire is for memory, but with some radios it will need power also to bench check) make sure all your radio fuses are good, run a set to the speaker, then run the wires to the battery. if the radio powers up, the problem isn't the deck. this has worked for me several times.
you can skip connecting the speaker, but I prefer to make sure everything works before I reinstall.
Jul 05, 2014 | 2002 Ford F150 Regular Cab
Radio quit working
Sounds like someone shorted the wires...you need to look into the entire butcher job and see what wires were touched. Disconnect everything the butcher did and then see if your battery is still drainning power.
Dec 03, 2013 | 2006 Chevrolet Malibu
The sound just turned off,radio is still on but theres no sound
Check your in-line fuse by the battery and the fuses on the amp they might be blown. Also make sure your power and ground wires still have good connections they might have come loose or or disconnected.
May 19, 2011 | Pioneer GM-6300F Car Audio Amplifier
I transmit fine but unless im close to someone when they talk the static over rides them and i can not understand them and i am also picking up alternater noise
Interference / noise elimination can be a test for how much money you want to spend and how deep you're willing to look. CB radios are AM and prone to noise. Here are some things you can try to eliminate or determine the source of the noise. Understand that there are only 2 ways for noise to enter the radio: power leads or antenna lead.
Connect the power leads directly to the battery - not the accessory terminal of the fuse block - nor "tap" into an existing 12 V power line you happen to find. Turn the radio on to an unused channel - it should be fairly static free. Turn the ignition key to the RUN position. It should still be clear - but if you hear a sudden spike of noise that lasts a few seconds before stopping, the static is likely to be coming from your fuel pump in your gas tank. The pump runs to pressurize the fuel lines to the fuel injectors when the key is turned to START. The Ford Explorer is notorious for this - but cab be reduced by following this link. It may work for your car, too.
Turn the ignition key to start the engine and let the engine run at idle speed. Listen to the radio as you vary the RPM from idle to 1000 - 1500 and let settle to idle again. Popping sounds that keep time with the speed of the engine is likely yo be ignition noise. This is caused by the high voltage (10,000 + volts) ignition system that provides spark for combustion in the cylinders. You vehicle may have more than one location where spark occurs. The spark plugs, distributor cap, rotor and coil are the primary sources of ignition noise. Replace broken, cracked, or otherwise damaged components and change the wires and spark plugs to "radio resistor" types. If a rising and falling whine is heard, the source is likely the alternator.
If there was no change - disconnect the antenna from the connector at the back of the radio. If the sound magically goes away - the vehicle and radio power are filtered very well - the noise in entering via the antenna lead.
Install a "filter" on the radio power leads - as close to the radio as possible. The power leads act like an "antenna" for all kinds of under-hood noise sources and carry it right into the radio.
Install a "filter" on the radio power leads - as close to the radio as possible. Since the power leads act like an "antenna" for all kinds of under-hood noise sources and carry it right into the radio, they should be stopped before they enter the radio. A coil (called a "choke") inserted between the power source and the radio along with a capacitor between the 12V + lead and ground is an effective filter. These filters are commercially available everywhere and also on eBay.
If the noise is getting in the coax cable, make sure your antenna is well grounded. Resist the temptation to use a "mag mount" as the ground is poor if not non-existent. Some have had some luck using snap choke cores but I haven't used them myself.
Lastly, don't expect to remove ALL the noise. You'd be the first to do so. Some methods work better than others. You can find a wealth of info by googling "CB Noise Filter" or "12V filter" (no quotes)
Please rate this if it was helpful - good luck!
Aug 23, 2010 | Radio Communications
2000 VW Beetle - had to jump the battery and when it restarted the radio doesn't work and the fuses are not blown and it doesn't show SAFE or anything on the radio.
2000 Beetle radio has a 10amp fuse at its rear left. have to remove radio to get to it. removing and returning radio is not easy. let me know if you need help with that as i have done this repeatedly on two different 2000 beetles and finally have it downpat. of course you need radio code, have found an article on how to disable VW radio anti-theft code but have not tried it yet.
Oct 09, 2009 | 2000 Volkswagen Beetle
2004 KIA TROUBLE WITH START UP AFTER FILLING UP WITH GAS
The fuel filter may be at the end of it life time and need to be replace. I believe the fuel filter is under the battery bolted to the frame rail. Its a cylinder shape with a fuel line on both end with quick connect fittings. IN the fuse box, remove the fuse to the fuel pump or the fuel pump relay with the engine running, this will depressurize the fuel line. The fuel line on the filter are quick connect fittings, depress the tab's on the fuel line and push towards the filter and the line should just pop off. If you find it to hard to depress the tabs, use a pair of pliers. But be careful not to damage the fuel line. Install the new filter, place fuse or relay back in for the fuel pump. start the engine and look for leaks. If the check engine light came on, disconnect the battery to clear the light, but make sure the radio is turned off before you disconnect the battery for 5 min. Reconnect and everything should be good to go. Hope this helps. keep me posted.
Jun 05, 2009 | 1999 Kia Sportage
Engine turns over but won't start
A few suggestions...
If the battery terminals are clean (and they probably are, as you just replaced the battery), and the starter sounds like it's cranking, then there are usually two other things to check for. Gas and spark.
You need both to make the engine run. It's a little involved, though for most do-it-your-selfers, it's a-run- of-the-mill process. You have to see that fuel is getting to the cylinders by disconnecting a gas line and very briefly, repeat, very briefly, crank the engine. If any gas spurts out, you're getting gas to the cylinder. If not, there's a problem with the fuel system. Be sure there is no spark or open flame anywhere nearby. Take the car in to a shop.
The other most likely possibility is that your cylinders are getting no spark. You have to disconnect a spark plug wire and see if you are getting a spark. This is a little more involved. Get a fix-it manual for the in-depth procedure. When checking for a spark, make sure there is no open fuel lines around!
Dec 18, 2008 | 2006 Suzuki Forenza
Car Audio & Video Logo
47 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
