Question about Bose 501V Speaker
What causes crackling in speakers? I have Bose 501's and one of the 8 inch is crakling during lower tones.
  • 5,603 Answers
The usual cause is that excess power has been sent to the speaker cooking out the voice coil which will then rub the magnet pole pieces.
A less likely cause is contamination in the speaker.
Driving high power to the speaker will deform the voice coil. DO NOT believe what the manufacturer rates these speakers. You need to use an amplifier with no more capability of output than 1/4 the rating.
For the 501V speakers each side amp should be rated at no more than 25 Watts to each side.
Very loud bass notes at higer levels will make quick work of these speakers.
The cure is to have the speaker "re-coned" at a speaker repair facility AND use smaller amplifier driving them.
Posted on May 09, 2010
Cracking speakers when tv turns on
If other electronics are too close to a TV this is a common problem. Try moving the 2 items at least 2 foot away and see if that helps.
You may not want to leave them there, but at least you will know if that's the problem!
Mar 01, 2014 | Bose Cinemate Series II Speaker
Crackling sound coming from bose sound bar
my bose cinamate soundbar has a crackle in the center speaker ??? Why is this???
Dec 10, 2012 | Bose CineMateR 1 SR System
Bose l1 crackle
Rotate the volume controls. Does this cause the crackle? Try working the controls through several turns up and down.
Also check that the lights on the top are not solid red. This would indicate that the inputs are clipping (the input signal is too strong) or the volume is turned up too high.
If that doesn't solve it call Bose® Product & Technical Support at (877) 335-2673 (U.S. and Canada only)
Monday-Friday: 8:30 AM - 9:00 PM ET
Saturday 9:00 AM - 5:00 PM ET
or write to them
Ask Bose for Help Forum
May 18, 2012 | Bose L1 Speaker
Crackling and saturation in frequency of surround speakers
I have the same tuner with the same problem. I have 2 pairs of Bose Acoustimas speakers and a pair of their sub woofers. I found it was the vibration from the subwoofers were causing so much vibration even using monster wire the crackling was caused by wire vibration at the speaker or subwoofer. if you are using twisted wire with a banana plug on the end or straight twisted wire into the speakers the constant vibrartion eats into the wire. Just pull the wires out re twist or tin (solder) the tips or move to a different location on the banana plug and really twist it will getting a bite into the wire. If you are using straight banana plugs use a screwdriver in the 4 slots to make them fatterso they stay tight. if they are RCA jacks pinch down the 4 outside tabs so they grip harder. Viva La France.
Feb 12, 2012 | Onkyo TX-SR503 Receiver
Hello........ looking for a schematic for Bose 501 series 3 speakers. I need to replace the fuse in line with the tweeters.... its blown & does not have a value on it (unmarked, quick blow, twin lead,...
Did you find a solution? Dunno if it's much help, but I just today picked up some 501s - Series I I think - ugly heavy brown material grilles - but with a manual! No fuses in these, but booklet recommends installing your own in-line fuse holders (!?). Specifies a BUSS AGC-3 fuse for amps under 50wpc; or a MDL-2 fuse for amps over 50 wpc. Can be placed is series with either or the two signal wires. Very strange.... Robin
May 14, 2011 | Bose 501V Speaker
My sound crackles i changed the speakers on my dell inspiron 6400 and it still crakles during audio I believe the sound is built into the mother board any suggestions other than get a new laptop
Well, try a set of headphones and listen. If it is still cracking, then you do indeed need another motherboard, because your audio pre-amp has blown a diode causing your waveforms to break apart mid-wave. That may not make perfectly clear sense to you, but, try imagining a wave on an ocean. it goes up, then goes down. In your pc's case its going up then dropping sharp and abruptly like a cliff. Since the driver is working, we know it is not the audio chip itself. It is my opinion that the audio preamp is malfunctioning.
Oct 26, 2009 | Dell Inspiron 6400 Notebook
Bose speaker crackling
THERES THREE THNGS THAT COULD BE WRONG, 1 THERES A BAD CONNECTION, 2 ITS BEING GROUNDED OUT WITH VIBRATION, 3 ITS BLOW.
Nov 12, 2008 | Car Audio & Video
Bose 501V Speaker Logo
918 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Ben Armstrong
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
