Question about Frigidaire 26.0 cu. ft. Side-By-Side Refrigerator
Can't find user's manual but need to install
I can't find user's Frigidaire manual but need to install PureSource2 water filter; bought it and stare at it and the water/ice fixture on front ... don't have a clue where to start.
Old Woman
    Guru:
  • 351 Answers
There are two places to look for the filter .. under thye door at the bottom of the fridge, there should be a button to push to release the filter cartridge, OR ,, with the door open in the upper right hand corner ..
Posted on May 09, 2010
I replace filter, each time the water dispenser is push the filter ejects
It sounds like you may not be getting the filter fully locked into position. Push it in firmly until it clicks.
Feb 28, 2015 | Frigidaire PureSource2 Water Filter WF2CB
Slow water flow
I would try the backwash as you suggest. Also, I had to run a few gallons of water through a new filter, for it to work properly..
Hope it helps.... good luck!
Jan 12, 2014 | Frigidaire Refrigerators
Water is cloudy
Hello Kiran - Thank you for allowing me to assist you. Where did you purchase the water filter from? Is there any type of work occurring in your area? If so, this is often caused because of a possible issue with the plumbing. Continue purging out the water and it should eventually dispense clean and clear water. If there isn't any work being done, then it could possibly be a faulty filter. Depending on where you purchase the filter from, you may want to reach out to them regarding this issue. Should you need any further assistance please feel free to respond.
Jun 16, 2013 | Frigidaire PureSource2 Water Filter WF2CB
Hi, I have a question
Hello Kiran - Often cloudy water is caused because the water was not purged. Try purging the water lines by running water through the filter for a total of 3 minutes. This can be done either in one big bucket or in various cups. If the water remains cloudy, then I highly suggest verifying that the filter is in good conditions with no cracks or damages. If the filter is working, then I recommend checking your tap water. If these troubleshooting steps prove ineffective, you may wish to contact a professional as the unit may possibly have an issue within the refrigerator lines.
Replacement water filter won't stay in place.
I too had this problem...the metal tabs in the filter housing need to be bent in toward the center to hold the new filter tighter...I also filed the tabs that rest on the spings down a bit to lessen the tension. So far so good!
Aug 01, 2012 | Frigidaire PureSource2 Water Filter WF2CB
Recently, I noticed water on my refrigerator shelves. After looking into the issue, I noticed that the leak was coming from the water filter. I purchased and installed this filter 6 months ago and did not...
It sounds like the gasket is either broken or crimped in some way . you should find the valve under the sik shut it down and remove the filter and check gaskets for crimps or breaks . It could also be just lose as well
Jul 23, 2011 | Frigidaire PureSource2 Water Filter WF2CB
Water stopped flowing on my frigidaire, replaced the filter (Frigidaire Frigidaire PureSource2 Water Filter WF2CB) and still no flow. Filter was old. About a year and a half or so. Any ideas on how to...
If you by pass the filter does the water flow? I suspect your water valve may have gone bad. Have you tested that by any chance? Also make sure the filter is in correctly and no loose lines and is locked in tightly. I would do two things: make sure the water reservoir in the refrigerator (behind the bottom drawer) is not frozen and check if 120 VAC coming to the water valve solenoid while the water dispenser calls for water.
Here is a link to a page that describes how to test the water valves.
www.appliance411.com/faq/test-water-valve.shtml
Jun 25, 2011 | Frigidaire PureSource2 Water Filter WF2CB
Hello. I recently changed my water filter (puresource2) on a side by side. The water coming out now is cloudy. It looks like little white particles floating in the glass. I didn't notice it that...
If you can find a hose that will fit the water line you can flush it out. But the most likely problem is that the filter that you bought was defective and the white particles are coming for it. If you can test it without the filter, to see if the water is clear or not, will tell you whether you should take the filter back and complain.
Jun 08, 2011 | Frigidaire FRS23KF7AB Side by Side...
PureSource2 filter popped out on its own. Bought a new one because its past due, but cant get it to install all the way. Tried with & without pushing release button that is functional. HELP!! What is...
These filters, Electrolux advises, have been re-designed. Right now, as of this writing (July 5 2013) they are giving out conflicting reports of whether a special installation technique for the re-designed filter will work (doesn't for me) or if their Service Flash RF1210 will cover replacement of the filter housing (Won't for Sears Kenmore models). I'm unable to solve the problem so have written back to my distributor about this whole problem asking them to dig into it with Electrolux.
Feb 08, 2011 | Frigidaire PureSource2 Water Filter WF2CB
Frigidaire 26.0 cu. ft. Side-By-Side Refrigerator Logo
123 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
