Question about Remote Start System
We had a Viper remote starter with alarm installed into our Envoy. The car will not start with the key. It will start with the remote start but as soon as you hit the brake pedal it cuts off.
  • 175 Answers
Did you bypass immoboliser? when you put your brake on it will cut off as this is a fail safe and designed this way
Posted on May 09, 2010
Which buttons do i push on the viper key fob to remotely start my 2002 ford f150 crew cab. the truck turns over but will not start
you push the ******(star)******* to start it .if it is not starting but starts with a key either wires have come off of remote starter or the remote starter has gone bad.
Mar 03, 2015 | Ford Cars & Trucks
Cant start car with key
It sounds like you might be having an issue with the transponder or "chip" in that key. When you turn the key and it doesn't start you probably see a flashing key icon on the dash with a circle and a line through it. When you remote start the car it is using a by pass module to trick the car into thinking you have a valid transponder key in the ignition when it starts up. Go to a locksmith and have another key cut and programmed to the car.
Jan 29, 2014 | 5901 Security Remote Start System
Camry 2002 Remote Starter Conflicts Car Starter
You need to call Viper and talk to their tech support. It sounds like the viper is actually disabling the starter. If you have all of your paperwork from the alarm system there should be a book that can help walk you through the reprogramming mode. Maybe your key fob is not synced to the alarm system. I have a clifford alarm which is still a viper. I have to press the star button 3 times in a row if I want my car to start remotely. hope this helps some.
Nov 09, 2013 | 2002 Toyota Camry
Lost my remote viper remote starter. Car alarm goes off when open and car won't start. What do i do to disarm the alarm since the car won't start?
Common issue.
Open doorAlarm will be going offLocate the antenna (should be on the windshield)Find the little black push button on the antenna.Turn key to the ON/IGN position (where all lights are on)WITHIN 5 SECONDS push the black button 1 time and release (unless your installer changed the number of pushes it should be 1)Within seconds the alarm will ceaseStart your vehicle.
If any other issues, send me a message.
Aug 25, 2011 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Bought viper 5501 yesterday.started car with remote but when i put key in ignition car stops running when key is removed car starts automaticly
Make sure you turn the key to the on/run position, then once you place your foot on the brakes to put the vehicle in gear the remote will beep and recognize the alarm.
Aug 20, 2011 | 5501 LC3 SST LCD 2 Way Car Remote Starter...
I received two of these systems in the mail and I am going to attempt to install it myself. I have been reading up and wanted to know if there are any detailed install instructions that I can find....
Not sure if you have this already, but here's a link to the wiring diagram for your vehicle: http://www.modifiedlife.com/2003-buick-rendezvous-remote-starter-wire-diagram/
Notice: All Viper Car Alarm Systems, Remote Starters and Keyless Entry Systems Require DEI Professional Installation for Warranty!! I'm sure you already have the owner's manual, but here's a link to Viper's http://www.viper.com/Support/ Last but not least... this is what I found online in regards to installing your Viper 5701 2-way Alarm w/ remote start: http://forums.evolutionm.net/evo-audio-security/364122-diy-viper-5701-install-ct9a.html
Hope some or all of this helps you!
Dec 15, 2010 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
My friend has a 1998 chrysler sebring with a viper 160xv remote start. Everything has worked fine until a few days ago when it would not start. In order to start it you have to have the key in the on...
the problem isnt with remote starters, or with viper products. the problem is with under qualified persons attaining products they have no qualifications to operate.
TAKE THE CAR TO A DEALER(VIPER ALARMS) and they can fix the problem.
remote start was designed for people who want to start their car from afar and could actually comprehend that the multifunction remote was not only a keyfob to lock a door , or start a car, but it is also capable of remotely accessing certain programming features of the viper alarm, and whilst in some goofballs pocket........while he was sucking down goldslager was unintentionally reprogramming the viper alarm, and setting it into various modes of operation.
your lucky you didnt accidentally program it into carjack mode. lmfao
Jul 31, 2010 | 1998 Chrysler Sebring
Lost my Viper key fob alarm is on and cannot start truck. any solution to disable?
Your alarm should have a button that was installed called a valet. What you want to do is put your key in the ignition turn it to the on position (Don't start it) then with the car in the on position hold down the valet button until the led light on the alarm goes solid and you should here the alarm beep twice. now your alarm will be disabled. To reable the alarm do the same thing.
Feb 12, 2010 | Viper Security and Remote Start System...
Parking lights will not come on when I use the remote starter
Most alarm installers use in line connectors or crimp-on connectors. If you can identify these connections looking under the dash, you will have to give it a little twist. Usually this allows it to make contact again.
Jan 11, 2009 | Viper Security and Remote Start System...
Viper remote starter sets off alarm.
Whoever hooked up your system did not hook up the factory alarm disarm and arm wires. Your car thinks it is being stolen as a result of this. You need to get a wire diagram of your car and hook up the proper wires.
Dec 12, 2007 | Viper (VGC421) Remote Control
Remote Start System  Logo
111 people viewed this question
Top Viper Vehicle Parts & Accessories Experts
Kevin Daniels
oneStan
oneStan
jason
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
