Question about Brother HL 1440 Laser Printer
No memory in 4040cdn
Bought printer only printed about 1300 pages.. printer says print unable e1 and no memory left. It worked a week ago. Turned on computer other day and can't print. can't delete spooled jobs because printer doesn't think there is anything to delete... I need help, I don't want to have to buy another printer.
  • 7 more comments
  • yoshi027 May 09, 2010
    Hello sorry I am using mac os 10.6
    Thank you for the quick response. I'm at my wits end. I pushed cancel button and the job cancel has been running for the last two hours with no end in sight.. SIGH
    Sorry I'm sending this again because I'm not sure if it went through.
    I'm using MAC OS 10.6
    Thank you.
    Hi I went to applications/utilities but I do not have printer setup...??
    sorry I meant I do not have print center
    Hi I have tried print&fax setup/delete many many many times and it does not work. But thank you for the quick response.
    Hi ginko, I tried what you said but it doesn't work. I've been trying over and over again. I can't believe that after only 1300 sheets I have no memory! I've printed way more on my other printers with the same amount of memory! this is frustrating. Thank you for trying. I also don't have any stores anywhere in my location that sell printer memory and I need printer by today.. Guess I may have to go and buy another one.
    Hi ioktay,
    I did try this method, however you can only reset tnr not memory... I noticed that the picture on this post says HL 1440 laser printer.. I just wanted to make it clear I have a HL 4040 CDN. Thanks for your help.
  • yoshi027 May 10, 2010
    Hi issken, Thanks for the comment. I guess I should have mentioned this earlier.. yes there is a way to take out the covers to ADD memory, however the INSTALLED memory is sautered in... i.e. I can't even lift it out of the slot to "reset". I've had it with this printer.. I'm going to the dumpster with it very soon. I also don't understand why i would have a memory problem since the manual/box say up to 35,000 pages a month of printing! I've only printer about 1000....
    Just bought it 3 weeks ago
  • 1,472 Answers
Yoshi027
It sounds like there may me a problem with the memory on your printer. I would recommend reseat the memory chip. After you do this and still have trouble you may need to replace it. If you go to page 95 at the link below it will tell you how to access it.
http://download.brother.com/welcome/doc002227/cv_hl4040_useng_usr_c.pdf
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Posted on May 10, 2010
  • Will Hartford
    Will Hartford May 10, 2010
    yoshi027
    How long have you had the printer for? You must have an early version of the printer if the memory is sodered in.
    Issken
  • Will Hartford
    yoshi027
    When you bought it 3 weeks ago was it new from a store. If so and you can not return it I would call Brother to get an RMA to get the printer fixed or replaced.
    Issken
  • Brother Master
  • 19,396 Answers
The printer went out of memory. If the problem persists you will need to replace or to increase RAM memory.
To empty the printer cue, disconnect printer from computer and disconnect printer power cord.
Restart computer, and with printer still not connected, try again emptying the printer cue.
If that does not work remove the printer from Installed Printers in control panel, and reinstall the printer software using the printer CD or the drivers from Brother printer driver download.
Keep the printer USB disconnected while starting the driver setup. The installation program will tell you when to connect the printer.
Here a RAM upgrade: Brother HL HL-1440 - 8MB (1X8MB) 60NS NONPARITY 72 PIN FAST PAGE
Regards.
Posted on May 09, 2010
  • 493 Answers
What is your operating system?
(Windows XP, Windows 7, Mac, Linux) Which one?
If you send me your comments I will send you a script according to your operating system to delete the print que easily.
Waiting your comment.
ioktay
  • 5 more comments
  • Ibrahim OKTAY
    Ibrahim OKTAY May 09, 2010
    Hi again,
    If your operating system is not Windows XP, Please do not do the followings, write me your operating system as comment.
    If your operating system is Windows XP then do the followings to stop the print spooler and its files. You will run the script file which I send you and that will automatically stop the service. (delete print que)
    1. Please download and save the file named "DeletePrintJobs.cmd" from this link directly to your C:\ folder in your PC which I uploaded for you. (You must have admin password for your PC to do that)
    Then open the command prompt. To do that:
    2. Click Start, and then Click Run.
    3. In the Open box, write (or copy and paste) the following text :
    C:\DeletePrintJobs.cmd
    4. Click OK
    Notice that the Command Prompt window opens to run the command script file that you created. Notice also that this window closes automatically when the command script file has finished running. If you do not see the Command Prompt window open, check that you saved the command script file by using the correct name and that you entered the correct command script file name in the Run box.
    5. Restart your computer.
    6. Try to print.
    Hope this helps.
  • Ibrahim OKTAY
    The command prompt window and your command will be as in the picture below after you save the downloaded file to c:\.
  • Ibrahim OKTAY
    Please do the followings for the Mac OS:
    1. Open "Print Center" in Applications > Utilities
    2. Click on the "Print Center" menu,
    then press and hold the option key and select "Quit Print Center".
    A dialog box asks you if you're sure you want to delete your printer and any jobs waiting to be printed. Select "Yes".
    3. Open Print Center again and re-add your printer.
    Hope this helps.
  • Ibrahim OKTAY
    I mean, if you find the menu to delete or uninstall the printer, then if you reinstall it, all the print que will be emptied.
  • Ibrahim OKTAY
    In your computer the menu to delete the printer may be as below :
    - System Preferences >"Print and Fax" icon
    - Select Printer from the list
    - Remove the printer > Click "Yes" to remove (To remove click the "-" button )
    _ Then restart you computer, re-install the printer
    Hope this helps
  • Ibrahim OKTAY
    I've read somewhere that you can access a resetting menu, opening the case and by pressing "cancel" and "reprint" at the same time. You may check to see any submenu in the list related to the memory of the printer. (All varius parts can be reset in this menu)
    Only for your info.
  • Ibrahim OKTAY
    Ibrahim OKTAY May 10, 2010
    Hello Yoshi again,
    Sorry I just wanted you to try something.
    If the memory module (chip currently plugged in the memory slot) in your printer can be taken out then replaced back in its module may help if it is possible.
    Of course if the standard memory module is not built in type.
    What happens if you change the slot of the current memory. First you can try without memory to power on the printer then reinstall the memory module., etc.
    Only brainstorming to help you. Because I wonder why it didn't worked.
    Maybe helps.
My 1300 hp printer still all lights on how to resolve problem
HP LaserJet 1150 and 1300 Series Printers - Understanding and Troubleshooting Control Panel Light Patterns This document explains how to interpret the light patterns on the HP LaserJet 1150 or 1300 series printer control panel. It lists the error conditions, describes the possible causes, and provides steps to resolve the conditions. Description of the control panel The control panel contains two lights and one lighted button. Patterns of light indicate printer status.Figure 1: Location of control panel c00007297.jpg 1 - Ready light 2 - Go button and light 3 - Attention light Figure 2: Light conditions c00007298.jpg 1 - Light off 2 - Light on 3 - Light blinking The following table explains the lights on the control panel. See "Status light patterns " below for an explanation of the light patterns.Light or button Description Ready light Indicates that the printer is ready to print. Go button and light To print a demo page or to continue printing while in manual feed mode, press and release the GO button. Attention light Indicates that a printer media input tray is empty, a print cartridge door is open, a print cartridge is missing, or other errors. Status light patterns This section describes the meaning of the light patterns. If a problem persists, see the flyer that came in the printer box for contact information, or click here to go to "Contacting HP support" below . Ready Light pattern c00007299.jpg Description The printer is ready to print. Action No action is necessary. To print a demo page, press and release the GO button on the control panel. Processing Light pattern c00007300.jpg Description The printer is receiving or processing data. Action Wait for the job to print. Continuable error Light pattern c00007301.jpg Description The printer is in manual feed mode. OR The printer is out of memory. Action The software controls manual feed. If manual feed mode is not wanted, change the setting from the printer properties. See the User Guide for information about changing printer properties. OR Take one of the following actions:
  • The page being printed might be too complex for the printer memory capacity. To continue printing, press and release the GO button. The printer might print a partial page, or the quality might be lower than normal.
  • Lower the resolution. See the User Guide for information about understanding print quality settings and changing print quality settings.
  • Add more memory. See the User Guide for information about installing DIMMs (HP LaserJet 1300 series only).
If the problem persists: Attention state Light pattern c00007302.jpg Description The printer is in an error state that requires operator intervention or help. The door is open, the media is out, the printer cartridge is installed incorrectly, or the media is jammed. Action
  1. Check that the printer cartridge door is completely closed.
  2. Load media into the correct input tray.
  3. Check that the print cartridge is correctly installed in the printer. (See the user guide for information about changing the print cartridge.)
  4. Check for any media jams and clear them. (See the user guide for information about clearing jams.
  5. Check that the left side panel is completely closed. If the left side panel is completely closed, open the left side panel and push the door sensor. Occassionally, if the left side panel appears closed, the sensor will still remain in the open position, generating this error. Pushing the sensor will shut the door tight, returning the printer to the normal mode.
Mar 19, 2013 | Office Equipment & Supplies
Lexmark 4039 laser printer is printing left side of the page faint
check the cartridge it has a toner pcr and cylinder inside maybe its defective or the ic chips
Feb 19, 2013 | Lexmark 4039P 4039 Plus Laser Printer...
I bought the printer a couple of weeks ago and have only printed a maximum of 20 pages. Now when I try to print, the "error" light keeps coming on but I've looked and it doesn't say what the...
Try opening the printer and checking for a paper jam.
It's also worth removing the toner cartridge and placing it back again, therefore forcing the printer to go through the diagnostic cycle again. Sometimes that solves the issue.
Hope that helps!
Mar 14, 2011 | Brother HL 2140 Laser Printer
Ran out of toner a week ago...stopped printing....did my print jobs and/or faxes go somewhere to retrieve later when toner replaced?
Your print jobs may still be in the spooler of the printer. Check the computer (Windows 7, Start > Devices and Printers. Windows XP, the title was Printers (IIRC)). The incoming faxes will be stored in memory; it can store up to 320 pages. (If you have other faxes in memory, the number of incoming faxes that can be stored will be less. Clear the memory after replacing the toner and printing the stored jobs. Press Menu until you see Maintenance then the left and right arrow to select the item to clear. Then press Enter to clear that area. When done, press Clear/Stop.)
I hope this helps.
May 17, 2010 | Ricoh AC205 All-In-One Laser Printer
Printer name :hp Laser jet 1300 the print
this printer prints a multipage document on 1 page everytime
Oct 21, 2009 | HP LaserJet 1300 Printer
Put new cartridge in and now it won't print
Your new cartridge is invalid. The internal Chip/memory of the cartridge is damadged.
Contact your suppier and ask to change cartridge.
Best Regards
Jun 10, 2009 | HP LaserJet 1300 Printer
Printer ERROR "Unable to Print 50! Unable to Print 30!" ???
WONT PRINT UNABLE TO PRINT , PAPER JAM
CLEANED PAPER JAM, CANT SEEM TO FIND ANY THING MORE TO DO TO IT
Sep 04, 2008 | Brother MultiFunction Center MFC-440CN...
"Unable to Print 50" BROTHER MFC-440CN
my brother mfc-440cn printer says, "unable to print 51" on the screeen after if off (which it woudn't let me do. I had to unplug it. It just won't work.
Aug 26, 2008 | Brother MultiFunction Center MFC-440CN...
Hp 1300 printing blank margine lines
hello it was your printer fuser asembly problem and in fuser u have teflion flim which was demange so u need to replace teflion flim
Aug 20, 2007 | HP LaserJet 1300 Printer
Image memory overflow
Hi Sidewinds you need to purchase additional memory for your copier. A basic copier only has 20mb of printer memory hope this helps regards Dr Bob1 (uk)
Jan 31, 2007 | Panasonic Workio DP-4530 Copier
Brother HL 1440 Laser Printer Logo
115 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
