Question about Black & Decker PHS550B Powered Handsaw withStorage Bag
We can't get the blade to go in
We have tried to get the blade in and it won't go, there seems to be nothing for it to attach to
  • 5,603 Answers
There should be a button on the right side of the saw to press in to open the clamp for the blade.
Blade changes require no tools. There will be a pin that engages the hole in the blades.
Posted on May 09, 2010
Minka aire f608 top won't screw on
Check to make sure your blades screws are tight. They could be rubbing against the glass.
Jul 01, 2013 | Minka Aire Ceiling Fan
2000 jaguar xjr fuse box
try changing the wiper relay first and check out the fuses if all is good then the motor itself may have seized or the worm drive may be worn or broken check the toothed spline where the wiper blade attaches the splines may be smooth or broken which will stop the blades moving back and forth
Feb 28, 2013 | 2002 Jaguar X-Type
Mower won't start
What kind of engine do you have? Have you done the typical checks like nothing is stopping the blade from moving under the deck, the air cleaner is ok, the plug wire is on, stuff like that? Is you gas clean? Too much compression sounds like something under the deck or something pulling on the blade, like a rope was picked up or a wire. Check there first.
May 19, 2012 | Garden
I can't unlock the blade.
Do you mean the chain won't move, or you can't get the blade off? The chain brake must be off to allow the chain to move. The chain brake handle has a housing that engages a gear attached to the chain brake inside the cover where the blade is attached. The brake must be off to remove the cover (usually held on by two nuts). The blade tension screw should be loosened to allow the blade to be removed, then retightened when replacing the blade. Tightening it pushes the blade out from the saw, so if it is tight, you won't be able to remove the blade. Hope this helps.
Aug 27, 2011 | Garden
I have a Badger 5 (5-81A). The motor is humming when it's turned on, however, the blade does not turn. The blade does seem to move freely. Tried reset and hex key but still nothing.
you have something stuck in it more than likely,, use the key ( unplug it first) and turn it backwards,, keep looking inside with a flashlight for the lodged object once you see it,, remove it,, sometimes the key won't work if its something caught in the blades themselves, so use the handle end of a broom or plunger with a wooden handle to push on the blade itself to turn the unit over
May 02, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Not cutting properly. blades seem to be out of sync.
Hi
try to spray oil the blades
if not helping
take the machine to be seviced you might need to sharpen the blades.
Jul 17, 2009 | Homelite Expand-It Hedge Trimmer...
Screws that hold the fan blade don't tighten up to the blades
replace your blades and washers and screws with a new ones.
Apr 07, 2009 | Hampton Bay 24002 Ceiling Fan
The chopping disc won't attach to the wand.
There are two grooves in the C blade which may be clogged up with food residue. What you need to do is get a sharp knife and score the two grooves to remove the residue, then the blade should have a better chance of staying on the stick.
The C blade is the one you use most, so that's why it would be having the problem. You probably don't have as much residue built up on the grooves of the Aerating or Blending blades.
Apr 06, 2009 | Bamix Deluxe Handheld Blender
Back Wiper wouldn't stay close to window
Sounds like you have a bent wiper arm. Maybe somebody in a parking lot pulled on it. You can try rebending it towards the window by removing the arm and slightly bending it. A little bend should do. I don't know why Dodge didn't make these spring loaded like the fronts.
Good luck and keep us posted.
Jan 21, 2009 | 2005 Dodge Caravan
Black & Decker PHS550B Powered Handsaw withStorage Bag Logo
1,150 people viewed this question
Top Black & Decker Saws Experts
Jason
Mike Carew
Are you a Black & Decker Saw Expert? Answer questions, earn points and help others
