Question about Dirt Devil Easy Steamer Upright Wet/Dry Vacuum
Dirt devil easy steamer need directions to use
How do I use dirt devil easy steamer? Cleaning solution, amount and how to fill. Thank you, [email protected]
  • 1 more comment
  • Anonymous Mar 14, 2014
    Dirt Devil SD30035 will not turn on after switch is pressed
  • Anonymous Mar 17, 2014
    I need to know how to put bottom of dirt cup back together/it will not stay closed
  • Anonymous Mar 31, 2014
    Dirt Devil Scorpion registration
Thank you for responding to my question. I should have spent some time really looking at my little machine. It wasn't hard to figure out -once I found and read the back of the cleaning solution bottle and tried my luck following the water to cleaner ratio.. Opening, adding the cleaning solution and water and re-closing the reservoir was pretty easy. Everything worked out fine...and my carpet is...spotless. Thank you, Cmarie
Posted on Mar 28, 2008
SOURCE:
Need manual for dirt devil handheld streamer pd20005
Many Dirt Devil manuals are available here: https://www.dirtdevil.com/manual-video-search/ . The PD2005 manual did not show up here. I did find it at Manuals Lib here: https://www.manualslib.com/manual/732336/Dirt-Devil-Pd20005.html . I also found the manual on the product page on the Dirt Devil MX site: http://www.dirtdevil.mx/easy-steam-handheld-steamer . The direct link to the manual here was http://docs.wixstatic.com/ugd/5ae076_fc923157085a43cb90e2113e69a6f7be.pdf . The manual is in English and Spanish, even though the host site is in Spanish.
I hope this helps.
May 19, 2018 | Dirt Devil Vacuums
CE7100 easy steamer upholstery directions
Hi! The MCE7100 does not do above floor cleaning. It is only used for carpets. Thanks!
Jun 28, 2014 | Dirt Devil Royal/ 1700735B00 Dw Cover...
Why will my Dirt devil easy steamer not releasing cleaning solustion
Hi! You may need to prime the trigger to get the solution flowing. To prime the trigger recline the handle and pump the trigger vigorously about 30 times. Power the cleaner on and hold the trigger in for 30 seconds. Be sure you are only using the Dirt Devil cleaning products intended for use with this machine. Using something other than the specified detergent can clog the lines that deliver the solution. If your cleaner still isn't dispensing you can take it in to a Dirt Devil authorized service center for repair. I have included a link where you may go to locate a service center near you. Hope this was helpful!
May 22, 2014 | Dirt Devil Easy Steamer Upright Wet/Dry...
I have a dirt devil featherlite carpet shampooer. It has been a great one for about five years without any problems. I need to know if anyone knows where I can find the replacement filters?
Hi There,
We actually do carry the foam filter for your Dirt Devil Featherlite (also manufactured as the Easy Steamer) carpet cleaner.
According to the Dirt Devil parts diagram for the CE6000, your machine takes the following foam filter. Here's a direct link to the filter on our website:
Dirt Devil Featherlite, Easy Steamer Foam Filter Part# 1-700750-600
Here's a link for the parts diagram for your Dirt Devil Featherlite CE6000 carpet cleaner. This will give you all of the part numbers, and drawings for each part on your machine should need any further parts:
http://lib.store.yahoo.net/lib/vacuumcleanerbacgs/dirt-devil-easy-steamer-featherlite-ce6000-parts-diagram.pdf
I hope this helped. If you have any further questions or concerns, please feel free to use the comment field here on the repair page to contact me, I'm always happy to answer any follow up questions.
If you found this repair helpful, please be so kind and rate the repair helpful and / or leave feedback for me. Thanks so much!
Chris Jones
GoVacuum.com
Apr 21, 2010 | Dirt Devil CE6000 Featherlite Wet/Dry...
Lost the manual. Need carpet/solution water
Below is a link to dirt devil. just put in your model# for the manual.
However most cleaners you buy give you the cleaner to water ratio on the bottle. Also you do not need to use Dirt Devil cleaner. All carpet cleaning solution are pretty much the same aside from the fragrance. The best ratio that I have found is approximately 5oz of cleaner for every gallon of water. Make sure you use hot water. Using cold water or waiting to long to use the mixture can reduce the efficiency of the cleaner.
Hope this helps.
http://www.dirtdevil.com/CustomerService/Manuals/default.aspx?id=32173
Sep 04, 2009 | Dirt Devil Featherlite Easy Steamer Vacuum
Ok, perhaps I am an idiot!
If you go to this URL: http://www.dirtdevil.com/CustomerService/Manuals/default.aspx ...and enter the model number for your machine, then you can download a users manual. I would just give you the exact URL for the user manual, but I don't know your model number. If this helpful to you, please leave a good rating. Thank you! ;)
Aug 13, 2007 | Dirt Devil Easy Steamer Upright Wet/Dry...
Dirt Devil Easy Steamer Deluxe
Follow the plastic extension that runs from the trigger through the length of the handle. This requires more disassembly that at just the trigger. At the end of the plastic extension you will find a triangular-shaped "ramp" that pushes against a "button" plunger that opens the valve that releases solution. When you release the trigger, the triangular ramp retreats and the plunger is supposed to be pushed back out by an internal spring in the valve. This plunger sticks because of accumulated soap from evaporated solution. Try cleaning that valve and plunger by running clean, hot water through the system OR replace the valve. In the future ALWAYS thoroughly flush the system with hot, clean water after using the machine.
Jul 15, 2007 | Dirt Devil Easy Steamer Upright Wet/Dry...
Dirt Devil Easy Steamer Upright Wet/Dry Vacuum Logo
611 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
JoeVacs
gggg
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
