Question about Garden
How do I remove the square key from the left rear tire of my Craftsman riding mower model #917270410. I am unable to get any type of vice grips or needle nose on it? Is a wheel puller required to remove tire?
    Scholar:
  • 110 Answers
In theory, the wheel simply slides off after removng the retainer.
If yours won't shift after soaking in WD40 or similar, you will need some sort of puller.
Some craftsman wheels have holes drilled in them for this purpose. If yours don't, you will need to drill some.
DO NOT attempt to hammer the wheel off. You might get away with it, but there is a fair chance that the axle shaft will come out of the transmission. If that happens, the transmission will need to be removed and completely torn down to fix.
If it really won't shift, destroy the wheel and cut it off. It's a pain, but cheaper than a new trans. You can (just about) get the tire off with the wheel still on the tractor.
Use copper-based grease on the axle when re-fitting, to prevent it happening again. I always remove the wheels once a year - just to ensure that I can if I need to!
Posted on May 09, 2010
Craftsman lawn tractor won't shift into gear
have you removed a rear tire recently? If so, you may have pushed the square key that locks the rim to the axle out
May 20, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman dls 3500 parts
When you removed the rear wheels did you remember to put the square drive keys back into the axle shafts, it is quite possible they fell out whilst you were changing the tyres, if only one is missing from either side it will not move .
Jun 14, 2013 | Garden
Can not get rear tire off
You need to take a small punch and drive it in but be careful not to lose it,or you will have to buy another before putting the tire back on.My guess is that the key is half moon shaped.Good luck hope this helps
Apr 10, 2012 | Poulan Garden
Getting Rear Wheel Off A Sraes Craftsman Riding
pull off plastic axle cover in the center of the wheel, remove large e-clip seen on the end with small screwdriver and large washer. take care not to let it fly off somewhere. lift tractor with a jack, pull off wheel then note the location of the square shear pin and save it for reverse assembly
Apr 16, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Craftsman model # 917271652 will not drive. I think the rear end is out
check the drive belt and pullys ,, also try pushing mower out of gear and in gear to see what you have,, make sure the brake not on,, hope this help you,, good luck
Aug 07, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman mower won't engage in gear
not much information to go on, but we'll try - did this just happen after having a rear flat tire fixed? if so, the square key that links the axle to the wheel fell out, easlily happens if you don't know it's there - OR, the belt is off one of the pulleys - OR, the brake is stuck - OR, the bypass lever [on a hydro] is pulled out or not releasing fully
Jul 17, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
Craftsman 19hp won't move when in gear
There is a square key about 2 " long that fits in the slot on the axle and wheel and locks them together.. You probably didn't see it when putting tire back on and knocked it out. If you go back where you removed tire, you'll find it laying on the ground.
May 27, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I cannot get the rear wheel off the tractor. Question... the ''square key''... I thought mine was missing & secured another one, but WHAT DO I DO WITH THE SQUARE KEY ? Is the original still in the hub part...
Here is what my manual says. It is for a 14 hp 42" mower deck. 6 sped transaxle.
Block up axle securely.
Remove axle cap, retaining ring and washer to allow wheel removal (rear wheel contains a square key. Do not lose).
Repair the tire and reassemble.
On rear wheels only: align grooves in rear wheel hub and axle. Insert square key.
replace washers and snap retaining ring securely in axle groove.
Replace axle cap.
If you send me your email address I can send you a picture as I do not know how to post pictures on here yet.
Apr 24, 2009 | Craftsman Garden
Clutch issues: release clutch and mower doesnt move.
"....I just took off the right rear tire to replace."
Make sure the key hasnt fallen out of the right rear tire. It has to have the key to work. Its a peice of metal about 3 inches long and flat on all sides. It should slip into the grove on the tires shaft. Hope that helps.
Apr 14, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Removing tire from SEARS CRAFTSMAN LT1000 TRACTOR.
You need to remove the black rubber cap from the center of the wheel. Remove the "C" clip from the axle and the wheel should come off. The rear tires will have a square key in it. Do not loose the key.
Jan 26, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
620 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
