Question about Philips HTS3544/37 Theater System
'no disc' keeps appearing
Cd's and dvd's unable to be read;
    President:
  • 1,851 Answers
If this problem occurs only at this cd/dvd it's a disk problem. If it occurs on various disks try using a cd/dvd cleaner set, a wet one is better. Follow the instructions on the set. The main idea is to put one drip of the included liquid at the set (usually isopropyl alchohol) at a specific place (like small brush) on the disk surface and play this disk. This way the "brush" will clean up the laser lens and after that the cd/dvd player will be able to read the disks. BE CAREFULL not to put too much liquid on the "brush". In case this don't solve your problem, the cd player needs laser lens replacement by a technician.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on May 12, 2010
Unable to read disc
question is that the only disc its not reading or you have tried other disc, if you tried other disc then you should return it for the lense to be changed if not check the disc properly and make sure it has no scratch, also you can try another CD/DVD disk format. the player might be selected for particular format
Jun 12, 2013 | Computers & Internet
Describe your Hitachi DZ-MV580A DVD Cant Read Discs ERROR 2881
here is the instruction manual for it,go through it carefully and u will find the sol.
Click here to download
Goodluck,
Dont forget to rate me as fixya..
Jan 31, 2008 | Hitachi DZ-MV580A DVD Camcorder
DVD drive read/burn problem
From the description the new DVD driver is defective and should be returned if still under warranty. The only concern that I have is the replacement you got is identical to the original and that it is not a aftermarket product, because they don't have the same specifications as the original.
Apr 05, 2012 | Lenovo 3000 Y410 Laptop
My DVR RW is not unable to read any DVD or CD. It cant read CD even while booting via bootable disc. The imae icon appears in the Explorer, but it cant read the discs.
the fault is from the lens (laser) of your drive, that's why its not reading discs. The lens is weak such that it cannot load discs.
How long have you been using this drive? I think its high time you got another one.
Good luck.
May 19, 2010 | Computers & Internet
Unable to burn movie to DVD/CD
You can't burn a DVD movie using a COMBO drive or Compact disc rewriter, change your movie format from DVD to VCD and then try again, I recommend you use nero to make/edit movie and ImgBurn to make ISO image and burn it onto disc.
Dec 31, 2009 | Serif MoviePlus X3 Digital for PC...
Sony DVD+/-RW |DW-Q30A will not record cd or dvd & only play dvds
When you get no disk error, that is usually because of a problem with the optical laser lens that is dirty, faulty or opaque, and will start operating on certain disks better than others.
In that case you will hear disk spinning, whirring and clicking, but the TOC (table of content track at start of CD/DVD will not be read, therefore the error.
Whe this problem is starting you may be able to read only CD, DVD , or for example only DVD-R and not +R , or only to read and not to write and so on. After more prolonged usage , often the unit goes losing the rest of functions, and ends up not reading anything at all.
If instead there is no noise, and disk does not spin at all , then there is a faulty motor, or the motor micro-switch is bad. This situation is far less common than the lens problem.
Try first using a CD/DVD cleaner disk to clean the lens. If that does not work you will need to disassemble the drive , and clean lens directly with q tips and isopropyl alcohol, or to replace the CD/DVD lens, or the whole drive unit.
Mar 28, 2009 | Sony DVD+/-RW |DW-Q30A BG w/o SW %...
I have a Sony CRX320E CD/DVD unable to write a DVD
CD-RW drives can only read all CD-rom and CD-RW formats and read DVD formats but cannot write to a DVD, if you want to write a DVDs you need to buy a DVD-RW burner which can burn all CD-formats
Jan 16, 2009 | Sony (CDR320E) CD-RW/DVD-ROM (Combo)...
Unable to play cd/dvd on my laptop
LINK
This is a dvd player codec.
LINK to sony support for tool necessary for dvd to read
May 19, 2008 | Siemens Computers & Internet
R40 DVD Read Problem
Unable to read a CD-R or other recordable disc. DVD recordable discs - If you have a DVD recordable disc and are unable to get it to read verify that the DVD drive is not a Gen 1 DVD drive and/or that it .
Computer DVD Support The DVD technology is very different from the technology used in standard CD-ROM drives. DVD uses shorter wavelength lasers to read smaller pits and lands.
Computer CD-ROM drive help and technical information. However, DVD-RAM discs cannot be read by standard DVD-ROM drives because of the differences in both reflectivity of the medium and the data format.
Read & follow instructions/Please dont for get to Vote/Thank You.
Dec 23, 2007 | IBM ThinkPad R40 2722 Notebook
Philips HTS3544/37 Theater System Logo
254 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
