Question about Philips 42PF7320A 42 in. Plasma HDTV
My philips tv only has pink and green tv - Philips 42PF7320A 42 in. Plasma HDTV
2 Suggested Answers
  • 10 Answers
SOURCE: pink and green with double writing
this is a internal problem you should call 1-888-PHILIPS (744-5477) to set up service. It is usally a main board problem
Posted on Jan 08, 2009
I hooked up my Vizio LED LCD to my Philips surround sound and my DVD picture is pink. What do I do?
This sounds like a problem with the component video connection (the red/green/blue cable; sometimes labeled Y,Pb,Pr). You can get a pink screen if the Green (Y) or the Blue (Pb) aren't plugged in correctly. Recheck those first.
Mar 01, 2011 | Philips CCC130AT 13 in. TV/VCR Combo
Distorted picture and pink and green color only
Are you using the 3 wire component video input. If so commonly the wires are switched or one is bad. be sure wires are color matched on both ends.
Nov 24, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Pink and green at top told needs to be aligned
More likey you have a convergence problem. Goto www.TvRepairKits.com for examples.
May 12, 2009 | Philips 55PW9363 55" Rear Projection...
Pink and green with double writing
Jan 08, 2009 | Philips 52PFL7432D Television
My Philips 51PW9363 has pink and green colors only!!!!
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 05, 2009 | Philips 51PP9200D Television
Philips big screen hd tv
TV repairs are generally much too expensive to undertake given the great prices out there for new ones with warranty.
I would not bother with it.
May 03, 2017 | Philips Televison & Video
Philips SAA7130 TV Tuner/FM... Problem
(Have u got a small cable with both side 3.5mm pin like head ph cable cord if not buy it) NOW FoLLOW THE STEPS1)plug the cable between tv card jack(green slot) to line in jack (computer pink slot)2)plug ur spker to line out jack(green slot in computer)3) double click on small spker icon (left side to ur screen near clock)4) click options menu>Properties>chose audio out option 4m drop box(see image)
11_2_2011_5_27_42_am.jpg5)click rear pink in >okAnd all done have fun
Jun 26, 2008 | Philips SAA7130 TV Tuner/FM Radio/Video...
Philips big screen tv
Does the power light light up when power is pressed? Does it blink? If so how many times does it blink? Have you checked the fuse?
May 19, 2008 | Philips 60P8341 60" Rear Projection...
About the microphone that comes with the Philips SIC4750/27 Webcam
The pink plug is your microphone, the green plug is the speaker..Behind your system you will find something like this..
Just connect the pink one in the pink slot and the green one in the green slot..If you want to listen through the PC speaker dont connect the green one..
Nov 04, 2007 | Philips J44414
Philips 42PF7320A 42 in. Plasma HDTV Logo
111 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
