Question about Husqvarna 28cc Gas Line Trimmer
I replace the gas line,fule filter spark plug and the primer. The weed eater will start and run for about a min. Then it will go off and I can not start it back
  • Husqvarna Master
  • 7,482 Answers
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please rate me, Thanks
Good Luck, I hope this helped
Posted on May 11, 2010
Weed Eater GTI 19T
If it's the one that comes 'out' of the primer bulb it is the return line that goes in the fuel tank.
Aug 07, 2014 | Poulan/Weed Eater No. Te475 952711797 17"...
Craftsman 32cc gas trimmer won't start.
Take out the plug and shoot a shot of starting fluid in it replce plug have a can of carb and choke cleaner to help it along until it picks up fuel spray by the air cleaner the carb and choke cleaner
Jul 21, 2014 | Craftsman Convertible 32cc Gas Line...
Why won't my McColluch weed eater create a vacuum
Did you check the muffler exhaust or spark arrester, to see if it is clogged from using to rich a oil/gas mixture ? Did you replace the diaphragm in correct position ? Find a new carb online, possibly ebay ?
May 16, 2014 | McCulloch 5pcs General Snap-In Primer Bulb...
Homelite weed trimmer bogs down and smothers out quits running
This could be a number of things. Clogged air filter/fuel filter/carburetor/fuel tank lid breather hole, cracked fuel line or primer bulb, or clogged spark arrestor in muffler. Here's some links that will help to change the bulb, fuel cap, fuel lines, rebuild carb, replace spark arrestor, and troubleshoot.
Homelite Tune Up
Homelite weed eater gas trimmer will not run how to rebuild weedeater...
http://www.repairclinic.com/RepairHelp/String-Trimmer-Repair-Help
Apr 27, 2014 | Homelite Garden
Hi curtis, i have a craftsman 32cc bushwacker weed eater. i had to replace fuel line in tank with filter. i also replaced the second line in the tank which is alittle larger in diamiter. i have a primer...
change the fuel lines over on the carby
you are trying to feed fuel through the primer line when the engine is running and that is why it is cutting out
Mar 12, 2017 | Garden
Husqavarna 125L E TEC weed eater won't stay running
CHECK THE SCREEN ON OUTPUT OF THE MUFFLER. ITS CALLED A SPARK ARRESTOR, THESE GET OIL FOULED AND MAKE EM A BEAR TO RUN . CLEAN IT UP AND SHE WILL RUN LIKE A CHAMP, THE CARB MIGHT NEED REBUILDING ,FUEL FILTER AND A SPARK PLUG IS THE FIRST THING TO REPLACE .. IF'N I WAS ANY HELP VOTE FOR ME ...THANKS.. JAY
May 24, 2010 | Husqvarna Forest & Garden 125l 18" Gas...
I have a weed eater trimmer that i replaced the gas lines but now when i pump the top of the carborator no gas gets to the carborator and the trimmer will not start.
REVERSE THE TWO FUEL LINES .. OTHER THINGS TO LOOK FORCHECK THE SCREEN ON OUTPUT OF THE MUFFLER. ITS CALLED A SPARK ARRESTOR, THESE GET OIL FOULED AND MAKE EM A BEAR TO RUN . CLEAN IT UP AND SHE WILL RUN LIKE A CHAMP, THE CARB MIGHT NEED REBUILDING ,FUEL FILTER AND A SPARK PLUG IS THE FIRST THING TO REPLACE .. IF'N I WAS ANY HELP VOTE FOR ME ...THANKS.. JAY
May 24, 2010 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
ECHO 2000 WEED EATER I changed the fuel line,
You may need the carburetor adjusted or rebuilt. The other possible item is "bad gas". If the gas has been sitting around longer than 30 days, it may be time to mix up some fresh fuel mixture.
HTH
Good Day.
Oct 29, 2009 | Garden
Have craftsman chain saw, runs ok for a few minutes then dies. found broken gas line.replaced fuel line,air filter,spark plug, checked muffler, also mixed fresh gas.eng acts like its out of gas. leave it...
The plugged vent gets my vote. Loosen the fuel cap when it starts to starve.
All Poulan IPLs (exploded parts list) are here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
Find your model, what little fuel system detail there is can be found on it. HTH
Lou
Oct 04, 2009 | Garden
Husqvarna 28cc Gas Line Trimmer Logo
358 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
